Question about Electrolux EL7020A Oxygen 3 Ultra Canister Vacuum Cleaner Bagged Vacuum
EL7020A ELECTROLUX VAC SHUTS OFF AFTER 10 MIN
I HAVE A EL7020A ELECTROLUX VAC THAT THAT SHUTS OFF AFTER 10 MIN. AND HAS POOR SUCTION.
    President:
  • 389 Answers
The symptoms you describe are typical of a vac that has a blockage (hence poor suction). It cuts out because it's over-heating. You need to check the hose, the filters and anywhere else where something may have got stuck. Blockages are often caused by things like paper clips, but can be caused by something as apparently harmless as a piece of paper which gets stuck and then debris builds up behind it and causes a log-jam.
Posted on Feb 10, 2009
How do I get reverse suction with the electrolux epic 6000?
I have no idea just what reverse suction would be or how to get it from ANY vac. If you're looking at getting the blowing air from the vac instead of suction, then simply move the hose from the suction end to the exhaust end.
May 25, 2014 | Electrolux Vacuums
Electrolux el7020a brush motor wont run
take the cleaner apart and make sure that the wires are all hooked to the on and off switch that got to the beater bar that is the main part of the problem improper wireing
Mar 22, 2014 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Need user manual Electrolux 1572F
Hello, this is Ava with Think Crucial.
You may find the User's Manual for your Electrolux model by clicking the link below.
https://www.searspartsdirect.com/partsdirect/user-manuals/EL7020A-ELECTROLUX-VACUUM-manual
You can purchase a wide variety of high quality Electrolux replacement parts for your Electrolux vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Electrolux
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Sep 08, 2013 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Electrolux cyclone power 1900w no suction with main attachment
If you've tried several different attachments and they all exhibit the same poor suction problems, you should completely check the parts of the vac that are common to all the parts that have the problem.
Since the motor creates good suction without attachments, I suspect the problem is the hose. Either an obstruction or a crack. Typically, if you block the end of the hose, the pitch of the motor's sound will go up slightly - like it it is spinning faster (it is). You can keep removing parts from the vac intake until the motors sound decreases - and that will indicate the part that has the obstruction. If it is a hose, you should clear the obstruction with a "snake" or other object like a pole.
If the motor sound does not change, then there is likely a split or crack somewhere between the intake of the vac and the device. You'll have to check it carefully - or if possible - connect it to the output of a vac and seal / cover the end. Feel along the length of the hose, etc. for air being blown out. Repair the opening and you should be "good to go"
May 12, 2012 | Electrolux Vacuums
Electrolux EL7020 SHUTS OFF Constantly!
That problem have 2 causes..#1 is loose electrical connection inside or on the power cord..#2 is worn out carbon brush inside of vacuum motor..
Carbon brush is the one of the most serviceable parts of a vacuum cleaner because our vacuum cleaner motor is very hard working parts so the brush inside will possible worn or not connected to the armature of rotor...
Jan 12, 2012 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Vacum shuts down when suction starts
Try turning the knob on the top of the vac all the way to the right.
Jul 04, 2010 | Electrolux Guardian Bagged Canister Vacuum
My vacuum is constantly shutting itself off. When
It sounds like you have a blockage somewhere and the air is not passing over the motor to keep it cool. There is usually a thermostat mounted either on or near the motor. The blockage can be anywhere from the elbow ( the swivel part of your carpet sweeper if you have a canister vac) up thru the hose.If you have a canister vac, use a broom handle to push through the hose to clear the blockage. DO NOT ! use a coat hanger or anything that will cut or tare the hose. There are electrical wires in it that have 120 volts and causes quite a shock !
If you have an upright vac, start with the duct hose that comes from the part with the brush up to the hose and on to the main canister of the vac
If this does not work, take your vac to a reputable vac shop for repair. Hope this helps,
Joe
Nov 16, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Electrolux Oxygen Canister Vac
Did you check the powerhead drive belt. Procedures for replacement are on the electrolux website and also in the owner's manual.
Nov 18, 2007 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Electrolux EL7020A Oxygen 3 Ultra Canister Vacuum Cleaner Bagged Vacuum Logo
337 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
