Question about Poulan Pro 42CC 2 Cycle Chainsaw, 18"
My poulan wont start any suggestions
I have cleaned all the parts and replaced the spark plug, i have not used it in over a year
    Scholar:
  • 63 Answers
Plugged fuel line or carb due to sitting with fuel in tank. Drain tank and back flush line, changing filter if there is one. Inject some compressed air into fuel line from carb.jet screw hole, thus blowing out line toward tank. May have to also use some carb.cleaner in same area.
Prevention: Always shut off fuel line and run carb dry before storing unit. If storing a long time, remove all fuel as gasoline will not keep long, esp. in the carb.
Best wishes!
Posted on Feb 10, 2009
I have a Poulan Pro 295 20 " chain saw that wont start.No spark from plug.Think the magneto is bad. Model no.952-051310 . Need opinion and part no. Thanks.
Do a basic test first, remove the top cover, pull the earth cut out wire from the terminal on the ignition unit ( this will iliminate any problems with the switch, or wires ) now try for a spark, remember that they work off speed of rotation so give it a good pull, make sure you use a good clean plug, well earthed against the cylinder. If there is still no spark, you will need to replace the unit, part no. 530039143
Feb 17, 2011 | Poulan Pro Chain Saw 46cc 20"
I have old poulan weedeater featherlite grass trimmer. wasn't used for many years. I replaced lines and bulb which were dried out and cracked. opened up & cleaned up carb -gaskets seemed to be in...
Did you check for spark? Try starting fluid to see if you could at least get a hic cup? Almost sure that your issue is carb related and you may have to replace it if it is not an ignition problem.
Sep 19, 2017 | Poulan Garden
Poulan pro blower wont crank after using normal method in manual to start. 2 years old and never any problem before. replaced spark plug and no luck. primer bulb appears to be sucking gas from the tank,...
Maybe time for somek maintenance. Pull the carb and take the cover off the end without the hole in the cover. Careful with the gaseket and diaghram (which may also need replacing). Look under the diaghram for a small hole about 1/4" diameter. There will be a very fine mesh screen in there. Make sure it is clean and spray the holes you see with a non-flammable brake cleaner. Most carb cleaners and such are TOO harsh and do more harm than good with these carbs. Look around because that area is where fuel goes to the other side of the carb to be metered and sent to the engine.
Aug 12, 2010 | Poulan Garden
One year old Poulan weedeater starts right up but will only run with choke about half way on. Warm it up that way but it does not run any better. New gas, new spark plug, clean air filter. The weedeater...
CHECK THE SCREEN ON OUTPUT OF THE MUFFLER. ITS CALLED A SPARK ARRESTOR, THESE GET OIL FOULED AND MAKE EM A BEAR TO RUN . CLEAN IT UP AND SHE WILL RUN LIKE A CHAMP, THE CARB MIGHT NEED REBUILDING ,FUEL FILTER AND A SPARK PLUG IS THE FIRST THING TO REPLACE .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
May 25, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Chaged gas and spark plug. Get no combustion
Make sure your getting a spark at the plug. Not much to these machines but verify good spark before anything else.
Nov 07, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Poulan weedeater bv200 wont start//new spark plug
Check the fuel lines for cracks/breaks. If they are o.k., then:
Youwill need to disassemble the carburetor and spray with carb.cleaner.Make sure the small screen is free of debris. (Should be able to seedaylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
Oct 20, 2009 | Garden
Poulan Pro 18 inch saw. Once the unit is warm it
start saw when cold and work it hard. if it stalls or quits remove spark plug and hook the plug wire to the plug and ground to the cyl head have switch on and pull the start rop briskly a few times or use a test plug. if there is no spark disconnect ign switch from from the ign wires and pull rope a few more times.spark?= replace ign switch,no spark until engine is cool,replace coil.
Sep 23, 2009 | Poulan Pro Chain Saw 46cc 20"
Poulan saw wont start has spark and fuel
Look for a pinched/bare stop-switch wire (I assume that you don't have spark now). Also, check the ignition coil core gap to the flywheel magnets (I use card stock to set the gap). Make sure the plug wire was not damaged again.
Aug 25, 2009 | Poulan Pro Chain Saw 46cc 20"
I have an 18'' Poulan chain saw that won't start.
Take the wire of the spark plug,and see if it shocks you when the cord is pulled.If not there may be something wrong with your coil.(loose wire for example)If it does shock you,you may want to check out your piston rings,or the little air/fuel mixture valve between your carburetor,and cylinder.
Jun 05, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Poulan Pro 42CC 2 Cycle Chainsaw, 18" Logo
273 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
