Question about Dell 3110cn Laser Printer
Problem printing with Dell 3010cn Laser
When printing on the dell 3010cn laser there is a line running all the way down the right margine of the paper that does not print. we replaced the drum about 2 months ago and have replaced the printer cartridge too.
Check for damage to the fuser located right were the paper exits. damaged fuser can cause lines
Posted on Feb 10, 2009
Dell documentation does not index "fuser". If you don't know where the fuser is, it's the device through which the paper exits to the paper-catch tray. I was going crazy trying to figure out how to "reseat fuser" as the error message instructed.
Posted on Jul 28, 2009
Why is there a black line on my Dell 3010cn printouts
You need to stop the print before it is finished to determine the source of the issue. Most likely sources are the black drum or fuser. Please note: as I hope you will stop the passage of paper before it passes the fuser assembly, the toner will not be fixed to the paper and can/will be smeared. Also, visually inspect both drum and fuser for the line. If you do see the line replace that assembly.
Oct 16, 2014 | Dell 3010cn Laser Printer
Hi, I have a Dell printer, and it says "MPF Load Error" every time I try to print something. How do I fix this?
Verify the Paper Type Matches the Type Set in the PrinterĀ“s Operator Panel
To verify the paper type matches the type set in the printer's operator panel, perform the following steps:
  1. Press the MENU button.
  2. Press the down arrow until Tray Settings appears and press the return%20arrow%203100cn.jpg button.
  3. Press the down arrow until Paper Type appears and press the return%20arrow%203100cn.jpg button.
  4. Press the down arrow until the specific paper tray (Tray 1, Tray 2, or Multipurpose Feeder) appears and press the return%20arrow%203100cn.jpg button.
  5. Press the down arrow to select the specific paper type, as shown in Table 1, and press the return%20arrow%203100cn.jpg button.
  6. Press the MENU button.
Print from the Multipurpose Feeder (MPF)
To print from the Multipurpose Feeder (MPF), perform the following steps:
  1. Click the Start button, point to Programs, point to Accessories, and click Notepad.
  2. Type the word test.
  3. Click File and then click Print.
  4. In the Print window, verify that the Dell 3000cn / Dell 3010cn / Dell 3100cn printer is selected in the Select Printer dialog box.
  5. Click the Preferences button.
  6. In the Printing Preferences window, click the Paper Tray tab.
  7. Click the Paper Source drop-down and select MPF.
  8. Click OK.
  9. Click Print.
Aug 19, 2011 | Dell 3010cn Laser Printer
My Dell 3010cn has does not print the far right hand part of the page any longer. I have replaced toner, drum and looked for blockage. What could be the problem?
It is most likely be due to dust/ toner dust accumulation at the laser reflecting mirrors inside the copier, which partially blocks laser beams and results in faint print. Therefore the printer requires cleaning/ servicing by a professional.
Hope it helps! Good Luck!
CreativeTECH
Mar 03, 2011 | Dell 3010cn Laser Printer
Dell 3010cn error code 077 303 Close paper cover paper cover is open. Which is the paper cover and what can I do to get it going?
The Paper Cover is located on the top of the printer. It is the vented panel just behind where your printed documents come out. It lifts up to clear paper jams, and documents won't print until it is closed. Just push the panel down until it clicks in place...that should do it!
Jan 03, 2011 | Dell 3010cn Laser Printer
All printing on my Dell 3010 CN does not print about 2cm all the way down the right side of A4 paper this includes all colours and black
check your print settings and margin settings on the document. this should work ..
Thanks If this helps then kindly rate me.
Oct 30, 2010 | Dell 3010cn Laser Printer
White stripe on right as if black toner needs
You probably got a piece of paper or something in the image path or the paper path. If it is a nice clean line it is more likely to be in the image path, if it is smudgy line it something may be scraping the toner off the paper before it gets to the fuser. Check the paper path.
Dec 26, 2009 | Dell 3010cn Laser Printer
My DELL 3010CN is printing a thick black line on the right hand margin on all pages printed.
Often Toner sticks to fuser. When the fuser heats the toner comes off onto the paper. Should reduce over time unless toner is spilling onto the fuser in the same place.
Change fuser and toner
thanks
Apr 08, 2009 | Dell 3010cn Laser Printer
How to solve repeated paper jams in Dell 3010 laser printer
Replace the pick rollers. If you're out of warranty it'd be mighty expensive to have Dell replace them, but, if you call them, they can get you access to a website (I can't remember the name...sorry) that has walk through tear-downs with pictures of each and every step. (Only do this if you're handy and have time)
Otherwise, replacement is the next option.
Typically Jams on this unit are from worn rollers. :)
Good luck.
Oct 20, 2008 | Dell 3010cn Laser Printer
Printer
Firstly, BE SURE TO USE LASER PRINTER TRANSPARANCIES. The cheaper inkjet kind will melt in the fuser.
Then, in all 3: driver, software program and on the printer itself using the front panel, change the paper type to transparency.
Good luck.
Jul 15, 2008 | Dell 3010cn Laser Printer
Dell 3110cn Laser Printer Logo
844 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
