Question about Roper RAS8445KQ Top Load Washer
Washer wont aggitate, spin or drain
Number on lid is sm 8525493
  • 105 Answers
Your drive belt sounds like the problem related to all these, provideing you hear the motor running, and timer is advanceing
Posted on Feb 10, 2009
I need to no how to lift up top to put cover lid switch on
Posted on Feb 14, 2009
Will not aggitate or spin,
lid switch remove back panel switch on rt rear corner could have microswitch or fuse depends on mdl #
Feb 04, 2010 | Maytag Washing Machines
My washer won't spin or aggitate. I have a GE
Check the belt and clutch in the front under the lid run a butter knife under the lid and pop the front off and take a look.Have a great Thanksgiving.
Nov 25, 2009 | General Electric WHDSR209DWW Top Load...
Washer wont spin
Unplug for 2 minutes, then plug back in, open and close lid 7 times slowly. This will reset the electronic motor.
Jun 17, 2009 | GE WBSR3140DW Top Load Washer
Washer fills and drains but won't aggitate or spin
Seven flashes means the washer did not sense a lid opening. Check the lid switch.
May 30, 2009 | General Electric WJRR4170GWW Top Load...
Washer won't drain or spin
sounds as if you have a lid lick/door switch issue, the machine is not recognizing the door being closed and for safety reasons will not enter spin/drain.. open anc\d close lid a few times slowly, cam you hear a "clicking noise" whe njust about closed?? id assume not replace teh lidswitch
Jan 21, 2009 | Kenmore 88732 Top Load Stacked Washer /...
Kenmore 70 series
First thing is to remove the 2 screws from the console, they may be hidden in the front or bacl of console. After removing screws, lightly push the base of the console towards the front of the washer and pick up. This will expose your lid switch connection. Using a jumper wire, jump out the black and white wires then try advancing your washer into spin/drain. The culprit will usually be the lid switch assy.
Apr 04, 2008 | Kenmore 24032\24036 Top Load Washer
Whirlpool Washer wont spin or drain
check your lid switch. if it will aggitate and not spin or drain.. then your lid switch is your answer
Oct 29, 2007 | Whirlpool LSR5132PQ Top Load Washer
Water won't drain out
Possible lid lock, check the lid is locked when it should be spinning or pump jammed and check the draim filter. Regards Advisor
Sep 01, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer will nor drain or spin.
Lil, start by checking the drain pump. Remove the front panel by pushing in on the clips on the left and right side just below the top. The panel will pull toward you. You will see the pump on the right. Start the washer in spin and with a meter see if you have 120V to the drain pump. If you do and its not draining, you have a bad pump. Part number for the pump is WH23X10013. back.
Oct 19, 2006 | GE WDSR2080D Top Load Washer
Roper RAS8445KQ Top Load Washer Logo
371 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
