Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
Does not print
At first it was printing the pictures in blue tones. Cartridges checked and found to be full. Now does not print the document at all. It goes through the motions, spits the paper out and it's blank. I took the cartridges out, put them back in. Did a "deep cleaning" on them. This printer has hardly been used.
  • 45 Answers
You have a defective printhead. Contact Kodak for a new one.
Posted on Feb 10, 2009
Even though my black cartridge is full, my black and white documents are so light they are unreadable. My color cartridges are close to being empty. Can this be the cause?
printers use all cartridges to get the correct colour even black
best get a new colour cartridge then realign the printer with a test pattern
Apr 05, 2015 | Office Equipment & Supplies
How i replace ETB for hp cp4025
Replacing the Transfer Belt (ITB, Transfer Kit) HP Color LaserJet CP4525 CM4530
1. Open the printer's right side door.
2. Use the blue lever (see callout 1 in picture below) to lower the secondary transfer assembly.
3. Grasp the small handles on the transfer belt assembly (circled in blue in picture below), and begin gently pulling the assembly out towards you, until a set of 2 larger handles pop free on the sides of the transfer belt assembly.
4. Now grasp the larger handles on the transfer belt assembly, and continue pulling the transfer belt straight out of the printer until it is completely removed.
5. Avoid touching the surface of the new transfer belt. Install in reverse order, sliding it securely into the machine.
6. After replacing the Transfer Belt, it's a good idea to perform a Full Calibration (or even several Full Calibrations in a row, if you are having print quality issues). Full Calibrations help with print quality by aligning the color tones, the drums, and the color plane. Each Full Calibration takes about 4 minutes. To perform a Full Calibration: Press MENU to enter the menus. Press Down Arrow to highlight CONFIGURE DEVICE. Press Checkmark to select CONFIGURE DEVICE. Press Down Arrow to highlight PRINT QUALITY. Press Checkmark to select PRINT QUALITY. Press Down Arrow to highlight FULL CALIBRATE NOW. Press Checkmark to select FULL CALIBRATE NOW. Wait for the printer to calibrate (usually takes 4 minutes or so), and then print a test page. If print quality still needs improvement, repeat the Calibration. If multiple Calibrations don't help, some of the toner cartridges may need replacement.
5e5fcf65-5757-40c3-a110-1a2864982d2e.jpg 554a3a0e-c038-46ec-983d-7467c3deeccf.jpg 7883eb6b-6a29-43fd-b69a-0ff825f60373.jpg bb2de9b0-8f0f-4f6a-a69f-ed1001f8bd09.jpg
Jul 15, 2014 | HP Laserjet Cp2025n Printer
Colour printing has a blue tone. Colours are not
This is problem may be one of the cartridges is dry or there is low level of ink .you did all the possibilities check only thing is pending the you can replace the cartridge and see the result.
Have a nice day and do not forget to rate please...!
Feb 06, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Although the cyan prints on a test print it is not
Epson Requires Genuine Epson Cartridges. !!!!!!!!
Hello, In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. That sounds like your problem. Also in Purchasing the Brother's . Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a chip, that will detect if it is Generic or Genunie. When using Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, but you have to fill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. Don’t waste too much ink in cleaning it.
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Jan 23, 2010 | Epson Stylus DX8400 All-In-One InkJet...
R1900 adds blue-green tint to my photo prints
Epson doesn't like Generic Cartridges.
Hello, In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. That sounds like your problem. Also in Purchasing the Brother's . Color that should be Yellow, will turn out Green, etc. These printers have a chip, that will detect if it is Generic or Genunie. When using Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. Don’t waste too much ink in cleaning it.
Jan 22, 2010 | Epson R1900 Printer
Print half of full page
If the printer starts to print and stop in the middle check the eletricity of your place, this may have a variation. If the printer prints a half page and give you the paper, with no jam, check the cartridges and then the main board.
Aug 13, 2009 | Lexmark X5470 All-In-One InkJet Printer
Won't print from small black ink tank
The large cartridge is for text and black pictures and the small one is for toning colours so you need to replace it. I found an absolute bargain on e-bay (2 packs of complete cartridges for £12-$18) when a set of origionals are £24 each set.
May 24, 2009 | Canon PIXMA MP600 all-In-One InkJet...
My printer won't print black ink even though the cartridge is full
try to clean the nossles with software from the manafactures website
May 06, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Lexmark x5470 printer printing blue horizontal lines on coloured documents
hi
try to perform maintenance of your printer
on the setting
and open your printer clean up the nozzle
use alcohol and cotton buds and then placed it back properly!!
Nov 10, 2008 | Lexmark X5470 All-In-One InkJet Printer
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
