Question about Canon Rebel XT / EOS 350D Digital Camera
HELP 350d still not turning on/screen not working
Hey guys, I'm having a weird problem with my Canon 350d ... when I turn it on, sometimes the CF red light comes on and stays on, sometimes just the battery indicator LCD bit comes on, and sometimes it seems to work OK.
Whenever it works OK, I can focus and take a photo, but the CF light then stays on as if it is constantly trying to write the photo to the card.
I have tried removing the battery and the backup battery, and have checked the CF card (no photos are being written).  Any ideas, or do you think it's fecked?I am unable to get the screen to turn on (even in the menu functions) and hence I am unable to select shoot w/o card and take any photos.  On the relatively few occasions that the camera starts up, the autofocus works correctly, the shutter seems to be working OK, but then after releasing the shutter, the camera gets stuck with the CF light on, and the number of shots remaining flashing constantly.  I tried this yesterday and after about 2 hours the light was still on so I removed both batteries.  I have tried formatting the card and even after getting stuck taking a photo, no data is written to it
  • mail278 Feb 10, 2009
    Yeah, tried all of that ... thanks for your help.  Send it off to Canon maybe?
    £175 - they must be off their heads!  Thanks for your help John!
    Novelist:
  • 155 Answers
Hmmm... doesn't sound too good does it? Have you tried another CF card? I know you said it doesn't work even without a card but...
Also one last thing to try is to tkae out both batteries, the main one and the slim watch style backup battery that sits right next to the main one under the cover labelled CR2016. Leave them both out for an hour and see what happens. NOTE this will probably reset your camera to factory defaults and may reset the photo numbering counter back to zero. Worth a try?
Posted on Feb 10, 2009
  • John LeFebvre Feb 10, 2009
    Canon charge approx £175 for a service (so I've heard), it would be cheaper to buy another 350D from your favourite auction site or maybe even try for a 400D. Good luck.
Broken cf slot in canon 350d camera
CF pin assembly is soldered onto the main circuit board. Replacing this requires a soldering work station with a good heat gun
Mar 24, 2014 | Canon Rebel XT / EOS 350D Digital Camera
Tokina canon eos 350D error 99
1.Remove the battery, lens and CF card. Allow the camera to sit without power for 20 minutes and then reinsert a fully charged battery.
2.Turn the camera on and push the shutter button as if you were taking a picture.
3. If you don't get the error message reattach the lens and insert the CF card.
4. Check the below canon eos 350d service manual link:
http://goo.gl/ELh523
it will help you to save a lot of money
Hope it helps, Thanks
Apr 08, 2013 | Tokina AT-X 124 PRO DX Lens for Canon
Camera will not turn on
Try changing batteries is the first thing you should try, the memory card isn't really important if your Eos isn't working.
If your Eos works, try looking on the lcd screen. It should give you an error code. Go to canon's website into the camera section and look up the code.
If that doesn't fix the problem, if you are still under warranty, I would suggest you to contact Canon for fixing it. If your under warranty, it should be free. If your not under it, you might need to pay.
Sep 08, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Have canon 350d, yesterday came up with CF err. Tried 2 diffrent cards, same thing. Friend tried my CF cards worked fine in her camera. Please help
Please look inside your cardholder and you have seen a lot of small pins.
If one or more of the pins are bending or missing it gives an error on the camera display
regards Rob NL
Apr 19, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Err 99 in canon 350D
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Apr 06, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon 350d not turning on/screen not working/
Does the camera work properly with the CF card removed? If it does than the CF card is the problem. Try formatting the card with the camera or getting a new one.
Feb 09, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon Rebel won't turn on, red light next to "CF"
Assuming you have tried another card you know to be good...
Remove the memory card, main and backup battery, switch the camera on for 10 mins. While you are waiting look into the memory card slot with a torch and make sure none of the pins at the bottom are bent.
If there is this will mean opening the camera to straighten it or sending it in for repair.
If not refit backup battery and main battery and cross fingers..:)
best of luck
May 25, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Err CF
TRy and reformat the CF card through the camera. Youll lose the pics for sure but you cant see them anyway. You can also check for bent pins in the CF slot. Sometimes if you shut down the camera in mid write to the card, itll mess up the cards FAT (file directory)
Feb 24, 2008 | Canon Rebel XT / EOS 350D Digital Camera
I'm having 3 different problems with my Canon Rebel XT
According to Canon, Error code 02 means that "There is a problem with the CF card. Try any of the following: Remove and re-insert the CF card. Format the CF card, use a different CF card."
Are both CF cards the same brand? Sometimes some brands have conflicts with the camera, you might try using two different brands.
It may not be the card, did you try on the third attempt to remove the battery and put it back in? There may be a problem with the contact points where the CF card plugs into the camera, or in the transfer system itself.
Dec 01, 2007 | Canon Rebel XT / EOS 350D Digital Camera
350D, focuses but won't take photo!
Does it do as you describe with a different lens? Have you ever had "error 99" or any other "error" show up in the upper LCD panel?
May 01, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
213 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
