Question about Sony God of War for PlayStation 2
Underwater mission when you get to an underwater mission,how do i overcome the obstacle where you have to swim fast to pass the moving chain walls?Can't i just skip this mission?
    Problem Solver:
  • 9 Answers
Unfortunately you cannot skip this mission, just follow the path to the left, pay close attention when your path is shown to you, it will take you where you need to go.
Posted on Sep 11, 2009
When do tsunamis happen
Tsunamis happen when there is an underwater earthquake, causing the ocean floor to move violently up or down. When the ocean floor moves like that, the water above it has to go somewhere so it spreads out in a very fast wave. The wave is a tsunamis.
May 27, 2014 | Computers & Internet
Cant move on from mission 1
it is not problem with ur game i think with ur skill. if u are thinking impossible see on youtube on how to pass the mission.
Aug 25, 2011 | Computers & Internet
As I pedal my Trek 800, the pedal slips or skips about one eighth of a turn. It seems like the chain is skipping a link or two ??
Your chain may have a stiff link or links. It is important to keep your chain lubed. TriFlow is highly recommended. Watch you chain as it passes through the jockey wheels on the rear derailleur, you should easily find the stiff links. Use WD40 to break it loose and work it with pliers.
Jul 01, 2011 | Cycling
How can i fast to lvl up ninja saga in lvl39
just keep coming back every day doing special missions, and lottery. make sure you recruit friends from the ninja saga wall to make it easier to pass missions. levelling up in ninja saga is a very repetitive process just keep doing levels over and over its the only way.
hope this helps
Nov 30, 2010 | Video Game Consoles & Games
I have two holes in the bottom of my pool how do I fix them
The easiest way to patch a hole in a vinyl pool liner is with the water still in the pool. With an inexpensive underwater repair kit, some swimming goggles and a few hours to allow the patch to cure, you will be back to enjoying your aquatic playground. jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); Difficulty: Easy Instructions Things You'll Need:
  • Pool repair kit (underwater) Rag Scissors Swimsuit Swimming goggles
  1. Step 1 Locate the tear in the liner. You may need to get into the pool and examine the surface wearing swimming goggles.
  2. Step 2 Read the patching kit instructions thoroughly before starting the job.
  3. Step 3 Clean debris from the area around the tear using a rag.
  4. Step 4 Use scissors to cut a patch for the hole. Use the vinyl from the repair kit to for the patch. Be sure it is at least 2 inches in diameter and will cover the entire hole.
  5. Step 5 Use applicator brush that comes with kit to apply adhesive to the back of the vinyl patch. Do not apply too much adhesive or the patch will not cure properly.
  6. Step 6 Fold the patch in half. The adhesive should be on the inside of the fold.
  7. Step 7 Enter the pool2_bing.gif water and relocate the area in need of patching. If hole is accessible from the outside of the pool, there is no need to get into water.
  8. Step 8 Hold patch underwater as close to the hole as possible. Unfold patch while underwater and apply to the hole.
  9. Step 9 Press the patch firmly while smoothing it from the center to the outside edges. This will help remove any excess air bubbles or water from under the patch surface.
  10. Step 10 Let patch cure as indicated on repair kit instructions.
Mar 29, 2010 | Intex Complete Easy Set Pool Kits at...
My Husqvarna 16 in chainsaw is no longer working. The saw starts but the chain will not turn on the bar. Manually moving the chain results in the chain clicking and skipping over the sprocket. Could a...
Did the chain come off while at speed? The chain catcher causes burrs to form on the drive links when occurs. Without the catcher the spinning sharp chain contacts your leg. Were you wearing chaps? We don't need no stinking PPE!!!
Use a flat file on the drive link flats to remove the burrs.
34be72d.jpg 5ab118d.gif Chain Adjustment
  1. Make sure the chain brake is off (gloves will protest your fingers).
  2. If necessary, loosen the bar nuts that are clamping the clutch cover in place (or whatever holds the clutch cover and bar on). They don't need these really loose - finger tight will do.
  3. Ease the tension adjustment until the chain is obviously loose.
  4. Using one hand, hold the nose of the bar up.
  5. While holding the nose up, adjust the tensioner so that the center of the chain just touches the underside of the bar, add a touch more.
  6. Continue holding the nose of the bar up & tighten up the bar nuts / bolts / quick-release system. HTH
Lou
Nov 12, 2009 | Husqvarna Chain Saw 20" Bar
Cobra GPS 500
Regardless of which GPS unit you use, finding sufficient satellites can be difficult if you are working in an area with trees/mountains/hills or other obstacles. Here are some suggestions to locking onto satellites:
1.) Mission Planning. If you think you're going to be working in a tricky area, but sure to check mission planning. This software allows you to input a location and obstacles, and gives you the times when satellites will be best.
2.) Wait. It takes the GPS units varying amounts of time to "find" satellites, but if satellites are visible, the unit should lock on within 5 minutes.
3.) Move. If possible, move into an area that has a clearer view of the sky.
4.) Face south. This is especially important if you are using the GeoXT. Turn the GPS antenna so that it is facing the southern sky. The majority of satellites have their orbit so that they appear in our southern sky. There are also satellites in the east and west, and almost no satellites to the north.
5.) Rotate around. If facing south doesn't work, slowly rotate the GPS around 360 degrees.
Oct 22, 2008 | Cobra GPS500 GPS Receiver
Sony God of War for PlayStation 2 Logo
110 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
