Question about Sony Cyber-shot DSC-W80 Digital Camera
Lens cover opens only a **** on Sony DSC-W80
The lens cover on my Sony Cybershot DSC-W80 will only open a little **** every time I turn it on. I have to gently pull on the cover with a fingernail to prompt it to complete opening. When I do this very gently, it then finishes opening on its own. Any ideas of how to fix this, or am I going to have to have it repaired? Thanks!!!
  • timebider Feb 10, 2009
    I do have a precision screw driver set; as for technical skills, well, it depends on the degree of technicality required! But I'm good at following instructions, so if you have them, I'd be most grateful if you'd share. Thanks so much!!
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    If you have "technical skills" and "precision screw driver set" then you can fix it by yourself as I'm ready to provide you info how to do that.
  • 10,594 Answers
Please read carefully below procedure how to remove "Barrier Block" (what you call Lens Cover)..
Turn camera power ON so Lens will extend.
Take out battery so lens will remain extended.
First silver ring needs to be removed with help of tweezers as shown in below image..
Now you will see 2 screws at front of lens, unscrew to remove barrier block (lens cover) as shown in below image..
You need to have new barrier block with following part number..
A-1205-001-A BARRIER BLOCK ASSY
Subject part is available in Part Store
Install new barrier block as shoLens cover opens only a **** on Sony DSC-W80 - e397a80.jpgg image..
Insert battery and power up camera to check does barrier block works fine.
Need further info, let me know.
Good luck.
Posted on Feb 10, 2009
Sony cybershot dsc w80 wont turn on or retract lens. My camera suddenly stopped working one day, do not recall dropping it, etc. My mother has the same camera and I tried her battery and it still doesnt...
From your description, I would say something is stuck inside the lens mechanism of your camera. It could be a grain of sand or any small particle like a piece of fabric from a camera bag.
Hold you camera lens facing the ground and gently - moderately tap it repeatedly. You can also try spraying a compressed air into it.
Thanks for using Fixya!
Oct 26, 2011 | Sony Cyber-shot DSC-W80 Digital Camera
Turn the power off and on again
Is it model with automatic cover of lens, like the DSC-T3 has? Problem is probably with lens cover. Try to move it (or help while it is trying to open/close) by your finger. It does sometimes if it is dirty (inside). I gues because you did not write the model name and number and on the picture is DSC-T1, but it has only 5.Mpix. If you have model with telescopic lens it is probably damaged gears of lens.
Sep 17, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Sony Cybershot T1
yup your viewfinder is officially in need of replacement
"For a period of one (1) year from the original date of purchase of the product, Sony will, at its
option, repair or replace with new or refurbished product or parts, any product or parts determined to be defective.
call the Sony Customer Information Service Center
1-800-222-SONY (7669)"
Aug 11, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
When i turn on my camera it says Turn the power off and on again
Hey, my camera the dsc- w80 did the same thing. When I turned it on, the lens opened 3-4 times and then it said "turn the power off and on again".
When the lens opened an closed, I pulled on it with my fingers and twisted it. I kept doing that: Turned the camera on and off, kept pulling and twisting the lens and now my camera works again!
May 15, 2008 | Sony Cyber-shot DSC-W100 Digital Camera
Cybershot DSC W80
Can you please send me copy of dsc w80 software cd - if its too large to email, zip and store at mediafire.com or other file storage site.
THANKS!
Apr 14, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
My sony cybershot dsc-p200 lense is stuck.
Sony Cybershot DSC-P200 worked great then the lens stuck in the open position.
Read on this site some one suggested gently manipulating the lens and tapping it then turning it on. It worked!!
Apr 07, 2008 | Sony Cyber-Shot DSC-P200 Digital Camera
Cannot open lens and take photos
sir, this is internal lens barrel,or gears problum,this is repairable
Feb 07, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
Sony cybershot dsc p5
probly has salt spray sticking the lens cover shut
Sep 19, 2007 | Sony Cyber-Shot DSC-S60 Digital Camera
Sony Cyber-shot  DSC-W80 Digital Camera Logo
286 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
