Question about Maytag Neptune MDG9700A Gas Dryer
Will not dry clothes.
I have this dryier and it seems to cycle but not very long.
I put it in service mode and watched the temperature. It feel to about 69 degrees then started the cycle and rose to about 91 degrees before the burn shut off then repeated. What could cause this to happen? How hot is the temp suppose to rise before it shuts off? Any help would be greatly appreciated.
    Problem Solver:
  • 7 Answers
Check your air flow the problem could be a pinched or clogged vent pipe.
Posted on Feb 12, 2009
Dryer works OK on timed dry but doesn't dry the clothes in Auto dry.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum 9 this is why in some cases the dryer will operate at lower cycles like gentle or low heat but not at higher settings?)
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :
http://www.ehow.com/info_12203962_check-dryer-thermistor.
GOD IS So GOOD !!!! AND THAT'S WHY MY ADVICE IS FREE
How to Check Dryer Thermistor eHow
Jan 07, 2016 | Dryers
Elec. clothes dryer turns but won't dry
If dryier is 220 V, phase is burnt out, so it's working on 110V, not enough to heat the air. Check your breaker and electric system or dryier.
Jun 02, 2015 | Dryers
Takes 4 ever to dry clothes. Will run & run when on auto dry.
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.Normally, this is what happens during an automatic cycle: The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees. When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.) The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Jan 09, 2011 | Amana NDE5800AY Electric Dryer
I have a Whirlpool Gas Dryer LGR6646BI-12 the clothes feel warm but not hot and they are still damp
The Dryness Level allows adjustment of how damp or dry the clothes are at the end of the cycle.
  1. Make sure the correct Cycle has been selected for the type of fabric being dried.
  2. If the correct cycle is selected and the clothes are still coming out too damp, use the Auto Dry Level button (Kenmore) or Dryness Level button to increase the Dryness level.
  1. If the highest Dryness Level setting was selected and the clothes are still damp, the Customer Focused Drying Mode settings that are built into the machine can be adjusted.
Dryers come from the factory set to Drying Mode 1 (default). Drying Modes 2 and 3, include additional drying time.
Note: This change will affect ALL Auto Dry cycles.
  1. Machine MUST be in Standby mode before beginning. (Standby mode = Plugged in, Power off)
  1. To select drying modes, momentarily press the Auto Dry Level button (Kenmore) or Dryness Level button (Whirlpool) again. The dryer will beep, and the display will flash and show the next drying mode number.
  1. With the door open and the display flashing the desired drying mode number, press the Start button to save the drying mode and exit diagnostics.
  1. Press the Pause/Cancel key at any time to cancel changes and exit from this mode.
Hope this works............
May 01, 2010 | Dryers
My kenmore dryer heat element goes on and off. The clothes take hours to dry.
It seems to run forever If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system. Normally, this is what happens during an automatic cycle: The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees. When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.) The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Dec 31, 2009 | Kenmore Dryers
Doesnt seem to be cleaning good. should i not be putting so many clothes in it? should I use more soap? I feel like the clothes barely get wet!
These washers use very little water. (about 2 inches in the bottom of the wash tub) The actual amount used will vary based on the volume of clothes and the type. (snythetic clothes do not absorb much water, but put in a load of cotton towels, for example, and the clothes absorb the water, causing the water level to drop, and the machine will add more water to return the level to the set point, which usually takes a several short fills, over a couple minutes)
To see that the clothes are indeed wet, just pause the machine a few minutes into the cycle. The door will unlock, and you can feel how wet they are. When the cycle completes, these machines spin so much faster (about twice as fast as most top loading machines) that the clothes feel very dry. (thus reduced drying time, and additional energy savings) Because of the lower water usage (about 12 gallons vs. about 45 for a top loader) make sure you only use 1 to 2 (max) tablespoons of HE detergent per cycle, and only 1 teaspoon of fabric softner if you use it. (don't use fabric softner on towels) Using too much addatives will cause odor issues, and possible performance issues.
Sep 03, 2009 | LG WM-1832C Front Load Washer
Takes too long to dry or keeps running when clothes are dry
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
May 07, 2009 | Kenmore Elite Oasis 6809 Electric Dryer
The dryier does not heat
the problem are your gas coils are faulty
Jul 26, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Dryer takes too long to dry my clothes
My dryer has been taking longer and longer to dry my clothes. Sometimes it takes multiple cycles before the clothes become dry. They seem to be getting warm, but are not drying as quickly as they use to.
Jul 08, 2008 | Whirlpool ET8CHEXSQ Dryer
EZ 3612 CEE Water Not Draining Completely After Dry Cycle
ChicagoRandy,
You may be loading the washer with too many items. 8 pounds (wet) is the max for an Equator EZ3613 CEE. Mine would drain, but then wouldn't spin, leaving the clothes soaking wet. Here's what worked for me:
I turned it OFF, unplugged it for a while, emptied it of all items, plugged it back in, turned the dial to RESET, turned it ON and watched the Mode light flash quickly for a while, then watched it for over a minute, flashing about once a second, to ensure it really had reset itself. Then, I turned it OFF, turned dial to Cotton 1, turned it ON, and it performed the cycle properly when empty. When this strategy worked, it told me I had put too many items in it for it to spin.
April 5, 2008
Mar 19, 2008 | Equator EZ 3612 CEE Front Load...
Maytag Neptune MDG9700A Gas Dryer Logo
79 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
