Question about NetGear RangeMax WPN824 Router
Power light keeps blinking and cannot log into WPN824 router
I did a firmware upgrade on my V3 and immediately afterwards, the system no longer connected to internet. I'm figuring, the upgrade didn't take but now I cannot access the router to attempt the upgrade again. Reseting doesn't help. Is there a recovery utility or something for this router??
Appreciate any help, Bob
  • Bob Meadows
    Bob Meadows Feb 11, 2009
    ok, the hard reset isn't doing any good. It's like the router isn't recognizing the reset.
    How do I go about setting up a "static" ip for the ping test??
  • 441 Answers
Firmware upgrade is very important. You have to make sure that you were able to do it properly.
You have to do a hard reset on the router. Press and hold the reset button for 30 seconds while the router is turned on. Try to see if your computer is able to get a valid IP address. If not, set up a static IP address on the computer and see if you can ping the router, if not then the router has gone bad.
You have to replace it.
Posted on Feb 10, 2009
  • Serwen Bagadiong
    Serwen Bagadiong Feb 12, 2009
    Control Panel>Network Connections>Right click local area connection then click properties>Look for internet protocol TCP/IP>Double click Internet Protocol TCP/IP then choose Use static IP.
    Note: If the default IP address of the router is (depending on the type of router that you have).
    Set the IP address to, Subnet mask:, Default gateway: Click OK all the way out.
    Go to the command prompt by clicking on Start then click Run. On the Run command box, type cmd. You will see a black box with a blinking cursor.
    Type the following: ping
    If you will not get 4 replies then it means to say that your router is dead. If you will get a reply saying ping statistics, packets sent 4, received 4, lost 0 - then you can still update the firmware of the router using the firmware upgrade utility of the router. You can try to access the router page and see if it is still working, if not then use the firmware utility if there's any.
How do i upgrade my netgear router - wpn824v3
Please follow steps to upgrade firmware on router
1.connect your computer to router with enthernet cable internet explore and type there " or then press enter will asked you for user name and password
default user name is"admin" and password is "password"
4.once you log into router setting page then click on
router upgarde which is under maintainence click on brouse and select firmware file then click on upgrade
Hope it will resolve your issue
Thanks for using Fixya
Jun 01, 2010 | NetGear RangeMax WPN824 Router
Linsky freezes
occassionally, you have to get use of restarting it (unplug and re-plug). the industrial types are more stable
Aug 20, 2009 | Linksys Wireless-G Broadband Router
Need my passphrase for my netgear wpn824 wireless router
Are you trying to setup your router? If so..
Here is a list of Netgear WPN 824 Models. :) USERNAME PASSWORD
Netgear WPN824 v2 (Netgear Firmware) admin password Netgear WPN824 v3 (Netgear Firmware) admin password
Netgear WPNT834 (NetGear Firmware) admin password
Jan 07, 2009 | Computers & Internet
NetGear RangeMax WPN824 Wireless Router (WPN824NAR) Wireless connection drops in and out regularly but frequency of this is unpredictable duration is usually a few seconds. Works find on direct ethernet...
Upgrade the Firmware of the router :
First you should check the version of you WPN824 (v1,v2 or v3). If there are no Version after the model number, it should be a version 1. Download the Firmware of your router given the correct version at this link :
This is assuming that other wireless laptops has the same problem onyour wireless router. If other Laptops works great on your wirelessrouter without dropping any wireless connection, then you shouldconsider upgrading the wireless adapter on you own laptop.
***(If you haven't tried connecting otherwireless laptop wirelessly to the netgear, then you should try it firstto be sure that the netgear is the problem)
Steps on how to upgrade Netgear firmware :
  1. Download the correct file depending on your location and unzip the file to a convenient place such as your desktop.
  2. Log in the router at or (or ) (Which ever will work)
  3. Default User name : admin / password : password
  4. Click Maintenance > Router Upgrade.
  5. Click Browse and locate the file you just downloaded.
  6. Click Upload. While the firmware is loading, do not interrupt the upgrade process.
***Therouter reboots when the upgrade is complete.
***Tocheck that the upgrade was successful, log in to the router again at check the firmware version.
Oct 26, 2008 | Computers & Internet
Testing my RangeMax WPN824
-- who is your internet service provider
-- what is the operating system of your computer?
There is a possibility that the router setting might set back to its default settings. you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router
if you are still having trouble configuring your device, call supportrix and use supportcall as your promo code to avail their 1 time free technical support.
Jun 09, 2008 | NetGear RangeMax WPN824 Wireless Router...
Power indicator keep on blinking
blinking power light after firmware upgrade sometimes indicates that the upgrade is not sucessful or the firmware that you load is incorrect.
-- try to reset the router for 30secs and check if the power light is still blinking
-- if its still blinking check your pc's ip address while connected to the router
-- if the ip address of your pc is invalid (169.x.x.x.) turn to manually assign static ip address to your computer and check if you can ping your routers ip address
-- if you can ping the routers ip address, upload the correct firmware to your router
-- if you cant ping your routers ip address still, reset the router again and try to ping the routers ip address once again
-- try to change port and cables
-- if still unable to ping the routers ip address, chances are that the router might be defective now
Apr 29, 2008 | Linksys Wireless-G WRT54GS Router...
Firmware Upgrade Failed
Firmware upgrade is a simple but a delicate procedure. Make sure you are loading the correct firmware. You should get your firmware from the website of your router. Installing a THIRD PARTY firmware to your router voids the warranty of your router. Here is a tip for a successful firmware upgrade. BEFORE FIRMWARE UPGRADE(push the reset button of the router for 30 seconds then unplug the power of the router for 10 seconds). Upgrade the firmware. After the upgrade push the reset button again for 30seconds, unplug power for 10 seconds.
Mar 10, 2008 | Linksys Wireless-G Broadband Router
You can reset your Netgear router/wireless wpn824 router to the factory settings from within the router manager. The reset procedure removes all user-configured settings and returns the router to the original factory settings.
For this reason, only reset the router if you encounter problems that can't be solved with other methods.
Step 1: Check that your Netgear router/wireless wpn824 router is properly connected with your system or not. If it is OK, then press reset button on Netgear router for at least 10 seconds. The 'test' light should flash during this process.
Step 2: Now open browser and enter Netgear's IP address into the address bar. Generally, '' is the Netgear router IP address but you can find specific IP address in Netgear wpn824 router manual.
Step 3: Now enter your default username and password to log in to router.
Step 4: Click 'Erase' button under the 'Revert to Factory Default Settings'. This process will erase all your previous changes that have been made to the router and restore the configuration settings to factory setting. Don't interrupt the process until the process is finished.
Once the router's 'test' light has stopped blinking and the configuration page you are on has refreshed, the wpn824 router has been reset.
Feel free to get instant online Netgear router
support at to fix Netgear router/wireless router issues.
Dec 15, 2007 | NetGear RangeMax WPN824 Router
Diag led
wat about the powerlight in the router....
Oct 24, 2007 | Linksys Wireless-G WRT54G Router
NetGear RangeMax WPN824 Router Logo
779 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
