Question about Vizio L32 32 in. LCD HDTV
Why wont my laptop run on my lcd hdtv made by Vizio
When i plug in the VGA cable to both the tv and the laptop i turn on my tv then my laptop everything is working fune until windows actually starts up then my tv says ''no rgb signal the power will be turned off'' Please if anyone can help it would be greatly appreciated.
    Sniper:
  • 96 Answers
This happens to almost every laptop I know. Here are several solutions:
1. You need to manually enable video on tv by pressing two buttons on your laptop keyboard. The first is "Fn" (at the left bottom). The second depends on your laptop manufacturer. Look at the function keys. F1....F12 for the LCD/CRT or the corresponding sign. Press and hold Fn and press second button. Sometimes you need to press second button several times. This means you need to cycle through all available options to enable Laptop's screen and TV screen at the same time (clone).
2. Intel Extreme Graphics video cards sometimes doesn't support a procedure described above. You need to find intel video card options manager running at the sys-tray (right bottom of your screen near the clock). Right click on it. Select Graphic Options -> Output to -> Laptop + TV clone (or something similar)
Note that not all video cards are capable of showing the movie on media player at the same time. You need to choose Laptop or TV
Posted on Feb 10, 2009
  • 362 Answers
You must redirect the video output from the laptop screen to the TV.
It usually takes a keystroke combination, depending on your laptop it is hold the FN(function) key(lower left on keyboard close to the Ctrl and Alt key) and press on of the F1-F12 keys on top of keyboard.
You can try one combination at a time until it switches. Your FN key may have a Flying Windows icon and the F1-F12 key may have a TV icon on it.
Let me know if you get it working and please rate this solution.
Lone99star
Connect Dell Inspiron 6400 to VIZIO E601i-A3 60-inch 1080p LED HDTV using VGA Connector
When you connect the vizio try changing the resolution settings on your laptop to see if that makes a difference. Could be that your video card output is not really compatible with the higher requirements of the Vizio.
Sep 20, 2017 | Vizio 60" E601I-A3 Full HD LED-LCD TV
How to connect lap top to viziom370nv
You need a VGA cable for the video going from the laptop to the TV as well as a 3.5 audio cable if you want to use the TV's built in speakers instead of the laptop. Don't forget to press the correct keys on the laptop for an external monitor.
Dec 29, 2012 | Vizio L32 32 in. LCD HDTV
Vizio HDTV E3DB420VX wont turn on
If your power indicator isn't lighting up, you don't have your 5vdc standby power. You're most likely looking at a power supply issue. Did this happen after a T-storm???
May 11, 2012 | Vizio 42 Class 120hz - 3d Hdtv Lcd...
I have a vizio vf552xvt lcd led hdtv and i wood like some help with connecting my computer dell xps 8100
You can connect your computer in your television by using VGA connector cable or HDMI cable.Then set the TV into PC in by selecting at the menu setting.
Jul 04, 2011 | Vizio VF550M 55 in. LCD HDTV
What do I need and how do I connect my Toshiba L305 model PSLB8 050302f to my hdtv to view online tv?
I dont believe that laptop has an HDMI port on it. If you have an LCD TV then your TV may have a VGA or DVI input on it. You can connect your laptop to the TV by using a VGA to VGA or VGA to DVI cable. If you your TV doesn't have one of these input ports, then you're not going to get your laptop connected to your TV.
Mar 03, 2011 | Toshiba Satellite Pro L300 Notebook
How do i connect my laptop to the visio l32? both
If your laptop and Tv have a HDMI connection..then you will just need the one cable to display both audio and video. A HDMI cable will look like this. http://images.google.com/imgres?imgurl=h? ______________________________________? Check your tv, to see if it has a VGA input..it will look like this http://en.wikipedia.org/wiki/File:SVGA_p? If so, you will need a vga male to male to run the video to the TV. it will look like this.. http://www.tigerdirect.com/applications/? To get your audio to work...you will need to run a stereo mini in the laptop to stereo RCA to the TV audio inputs. It will look like this.. http://www.tigerdirect.com/applications/? Cheers
Nov 04, 2009 | Vizio L32 32 in. LCD HDTV
Trying to connect laptop to Samsung HD LCD TV using VGA cable.
I had the same problem with my Samsung series 6 32" Lcd. After many hours of trying different settings and banging my head on the wall I found the solution. What the problem is your VGA cable not supporting the high resilotion of your Samsung TV. The simple solution is to buy a new VGA cable that supports HD. Take a look at this site you need something like this one! Hope this helps.....C
http://www.clearly-av.co.uk/PGM1110.html
Sep 19, 2009 | Philips 32PF7421D 32 in. LCD HDTV
Lenovo T60 interfacing with Vizio HDTV using RGB cable
The X1400 supports Full-HD resolution. Full-HD/True-hd (1920x1080)
The best output would be via DVI but you are limited with the VGA port.
I would purchase a Grand Hi-Wire PC to HDTV converter from www.globalcomputer.com. Item # G126-1036 @ $139.99
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 04, 2008 | Computers & Internet
Vizio L32 32 in. LCD HDTV Logo
237 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
