Question about Zanussi IZ12 Front Load Washer
Zanussi jetsystemiz12 start /pause button flashing wont start
Was working ok up till now i have cleaned filter out i even put on a new door lock thinking that was problem it just stopped after a wash was put on it filled up a small bit then stopped and start button started flashing
    Scholar:
  • 106 Answers
Water leaks out the front door even though the rubber boot is ok and in place. The retaining clip is pretty flimsy though. Can't seem to position it so as to seal the door.
check for any dirt in between the rubber bush and the door, there also chances that the lock spring being damaged or loosened too much. did you clean the dirt collecting filter usually placed in the bottom corner of the machine where coins and other things caught by the washing machine?
Jul 31, 2015 | Washing Machines
Hotpoint 6kg washing machine Aquarius wash light indicated door lock indicator flashing machine won't fill any ideas thanks Brendan checked filter ok
Many or even most washing machines will not run if the door lock switch is not working. Open and close the door a few times to see if the light stops flashing. You could press on the door where the latch is and see if that makes a difference.
Jun 04, 2015 | Hotpoint Washing Machines
My washing machine is stopping in the middle of its cycle the door locks and the light blinks I tried cleaning out the pump and it started working and then it stopped again
check for drain pipe blockages ours was stopping, i put hose out window and it worked fine so I cleaned out the drain and all ok now.
May 16, 2013 | Washing Machines
We have a kenmore he2 plus. I put in a load Of laundry and when I came back to put laundry in dryer, washer has no power and the door is locked. How can I get the door open and fix the washer
Maybe the filter is clogged and not draining the water. Have you tried cleaning the filter?
Various control lock features on differing models:
Press the end of cycle signal button for 3 seconds
OR
To reset press the DRAIN/SPIN button and hold it for 15 seconds.
OR
Press and hold the END OF CYCLE button for 15 seconds to reset the control.
OR
Press options and select for 10 secs till LOC is no longer displayed
OR
Unplug washer
Remove lower kick panel
Reach up and locate bottom of door lock switch
Grab the teardrop shaped tab
Pull gently till yall hear a click
The door will be opened
How to video
Sep 09, 2011 | Kenmore Washing Machines
Hoover hpe 236. water not draining, stops mid cycle, lights flash
Have you checked the pump filter, and or that the pump is actually working. if it spins o/k with no water in, then I would suspect a draining problem.
If filter clean and pump o/k, then it could be a control module fault. if this were the case, then it would probably be wiser to purchase a new washer.
Hope this is of some help to you.
Jan 16, 2010 | Hoover Washing Machines
My Whirlpool AWO3761/S Wont Wash Or Do A Full Spin But A Slow Spin Works Ok When I Start Any Program It Goes As Normal Starts Filling Rotates the Drum One Way Then Stops The Timer Clicks Like It Is...
Sounds like a problem with the door lock, door switch or the door switch actuator. Door lock is usually a single assembly with the switch. Check the pin on the door first. Model # is probably mistyped, won't come up, so can't tell anything specific.
Oct 13, 2009 | Whirlpool Washing Machines
Candy CNA 145 stops
Found that pipe leading from the drum to the filter was blocked. Machine at first appeared to be draining but on closer inspection was not draining fast enough. Machine now working perfectly. Hope this helps anyone who may have a similar problem.
Jul 27, 2008 | Washing Machines
Door locking is flashing so it wont start a cycle
Try pressing "end of cycle" button; wait a couple of minutes to open your door, do not force. Then shut door to restart your new cycle..........
Rate me pl. if helped. If not click 'thanks for trying', this prob will come up for others to solve.
Jan 13, 2008 | Washing Machines
Door locked,wont spin or drain.
humming noise suggests a foreign object in the pump. crack open filter and drain water into a shallow tray. repeat till empty. remove filter completely and clean it. check if something stuck in pump impellor. this should be visible by looking into the filter hole
Jun 22, 2007 | Bosch WFMC 3200 Front Load Washer
Zanussi IZ12 Front Load Washer Logo
573 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
