Question about Whirlpool Washing Machines
Directios for changing agitator dogs
I have the agitator removed from my la9100xtw0 Whirlpool washer.
The upper part of the agitator does not work I have read here this the
''agitator dogs'' need to be changed. Pleaase explain the steps for this.
I have also split the agitato inro it's 2 halves. Do you need special tools?
  • 20 Answers
Take the cam out take the yellow bushing off, put new dogs in, put yellow bushing back on, put agitator back into washer, put cam back in with dogs inside it, facing down, put bolt back in and cap. new dogs usuaully come with instructions.
Posted on Feb 13, 2009
Agator doesn't work
Is this a whirlpool washer? The agitator dogs need to be replaced. Remove top cap on agitator, then plastic cover inside it, then remove bolt, then pull agitator off. Top can separate from bottom by standing on bottom and pulling up on upper. Go to Repairclinic.com to find agitator dogs.
Nov 19, 2011 | Whirlpool Washing Machines
Upper portion of Whirlpool agitator not turning
Your agitator dogs are worn out. Remove the agitator and seperate the upper section from the lower section. There are 4 small teardrop shaped pieces that are the agitator dogs. They have either come apart over time or at least the teeth have worn off them.
Post back with any questions. Please verify the model number. I couldn't pull up a parts list for it. I know the last digit should be a 0 (zero) instead of an o.
Thanks/Mike
Jan 07, 2008 | Washing Machines
Tip
Whirlpool: How to replace the dog kit of direct drive washers
How to replace the dog kit in agitator
To replace the dog kit in the agitator, remove the top cap/rinse dispenser and the inner bolt cover. Remove the 7/16" bolt and lift the agitator out of the washer. Separate the upper and lower pieces of the agitator and replace the dog kit inside the upper part of the agitator. Make sure the 4 pieces remain in place while putting the agitator back together.
on Feb 12, 2010 | Washing Machines
Whirlpool washer agitator not working
You most likely need to replace the dogs in the agitator, two piece agitator design. It should spin one way and catch the other on the teeth of the dogs. It will spin freely either way when the dogs are wore out. This is for the top half of the agitator, bottom is fitted to transmission shaft. You pop the top cover, remove the 7/16 bolt and both halves together to change dogs of agitator. Pull halves apart to change dogs. Fairly simple.
Jul 31, 2011 | Whirlpool Washing Machines
I have a Whirlpool washer... model number # LSQ8243HQO The top part of the agitator is loose. The bottom part is strong. I think I need what they call dog ear replacements. Can you help me?
yes sounds like the dogs to me.
to replace them,remove the cap at the top off of the top of agitator by pulling it up (no tools required) then remove the clear plastic cover by pulling on one of the two tabs in it,remove the bolts using 7/16" socket and pull the agotator out of the machine by gripping it at the bottem.seperate the upper portion of agitator by pulling it upand the dogs will be located under the clear plastic,to replace them seperate the top barrel of agitator a cam that holds all (4) dogs will come out remove the retainer over the dogs install new ones and reassamble in the line up upper barrel and main agitator you will (2) tabs on main agi. and (2) corosponding slots on barrel line them up and snap in place
Jul 14, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
How do I replace the CAM-AGIT on a Whirlpool Washer Model #395165
you have to remove the cover inside the upper agitator first, then you will see a plastic cover inside the top. it has 2 raised handle type tabs to pull on, then remove the cover and under it you will find a 7/16 bolt to remove and that will allow you to pull the tophalf of the agitator and change the agitate" dogs "
Dec 31, 2009 | Washing Machines
How to remove agitator cam from the upper part of the agitator?
Had same problem with my washer. Check to see if there are little plastic tags holding top/bottom of agitator. after replacing dogs just ensure that you realign with tags so they do not break off.
Oct 10, 2009 | Whirlpool LSN1000LW Top Load Washer
Agitator not working
Hi, This agitator is a 2 piece agitator. Can you see if the lower half on the agitator is working properly? If the lower part is working and the top is not, you will need to change the agitator dogs. If neither half are working, you might be having transmission issues.
To change the dog kit, re,ove the top cap on the agitator and locate a 7/16" bolt. Remove the bolt and the agitator will lift out. Pull the agitator apart and the dogs are 4 small plastic pieces inside the top half of the agitator.
Please let me know if this helps you or if I can assist you further.
Thanks
Vic
Sep 13, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool LA9100XTW0 stop agitating ...
most likely the "agitator dogs" in the upper portion of the agitator. here is the kit you need to fix it:
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=2744&PPStack=1
it is a 5 minute job.
May 16, 2008 | Whirlpool Washing Machines
Washing Machines Logo
203 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
