Question about Motorola Mobility RAZR V3
The bluetooth sistem dosent work and it said that the files eighter
When i go to the bluetooth ,i press find me them the other cellphone accept mine he transfer the song that i want and when the song is all ready on my phone it said file is damage in other words it doesn't want to accept anything mp3,image,videos etc. i even transfer songs from my pc to the phone ,i plug the phone with the usb i use the software (motorola phone tool) and when i download the whole song it doesn't appear on the phone i did the same thing to my brother's (razr v3 is the same as mine) and the songs appears in his ,please if anybody knows what is going on or what happen to my cell pleace let me know
Hi there, The problem might be that some of the files in your mobile might be corrupt 4 fixin this problem just go to the settings and then click on initial setup and go for the master clear but this might clear all the prevous data ........ thank u
Posted on Aug 01, 2007
SOURCE:
Turn on bluetooth on asus laptop
Try to receive files by entering the bt-setting at your computer. Press receive file.. from your device instead of trying to send from the device.
Jun 18, 2014 | ASUS Computers & Internet
Hi, i have a 2008 hst & iphone 4, the bluetooth was working great, it has stopped working, it connects but when i make or recieve calls it dosent connect to bluetooth
Hi James, I am not an expert on iPhones or Bluetooth, but suggest you go into the main set up menus on both devices and then disconnect both and then search and re match and accept them. It should work correctly then. Regards John
Dec 13, 2011 | 2008 Land Rover Range Rover Sport
How to download music from computer to cellphone?
There are 2 Methods
1 is via Bluetooth other option is using a USB data cable
via Bluetooth - Switch on BT on both PC and phone. - Click on BT icon in the phone and select send a file or you may send directly by selecting the file. - Accept the file receiving via phone.
Via USB cable
- Connect the cable. - Select Mass Storage from the phone , when prompted. - Copy files to the newly installed removable drive (Which is phone's memory)
Mar 07, 2011 | Nokia E63 Cell Phone
How to connect to laptop?
You can connect Nokia 2690 using bluetooth and using Nokia connectivity Cable CA-101 which will fit to the USB port of your laptop.
(NOKIA connectivity cable)
Procedure on how to connect:
1. Bluetooth (This will work with the laptop with bluetooth)
First, remember to turn on the Bluetooth feature and make it discoverable by other devices (My Phone's visibility -> Shown to all) on cell phone, so that it can be detected by laptop.
Then, click on the add devices in the control panel of your computer. Click start> control panel
2. Add Bluetooth Device Wizard window will appear, tick My devices is set up and ready to be found and click Next.
3. The wizard will then search the Bluetooth devices nearby, and will show the found devices. Here the wizard found my cell phone named David. Click the device you want to add, after that click Next.
4. Ok. Here the wizard will ask whether you need a passkey to add your device, so that the communication data between laptop and cell phone will be encrypted later, here I would recommend you to either select Choose a passkey for me or Let me choose my own key. In this example, I select choose a passkey for me.
The wizard will then show the passkey and you need to key in to your cell phone. After that, the laptop will try to install the Bluetooth device. If you have Bluetooth program for your cell phone, you can install it as Windows Vista might have problem to install the device . For my case, I install Nokia PC Suite on the laptop, so I can transfer wallpapers and videos later.
Note: Also your cell phone will get the prompt to accept connection from laptop, and you need to click yes.
5. At last, click Finish to complete the Add Bluetooth Device Wizard.
6. And now, you will see the new bluetooth device added which is your Nokia 2690 phone.
Here's another way on how to connect your cellphone to your laptop.
2. Hard Connection using Nokia connectivity Cable CA-101
carloadrian_7.jpgYou can get this from any nokia stores.
Procedure:
Just connect the other end of the wire to your cellphone and the other end to the usb port in your laptop. Follow the onscreen instructions in your cellphone.
Check your laptop if your cellphone has been detected, once it's connected you can then access your pictures or other files in your cellphone. You can even transfer files.
I hope this helps.
Please rate this solution. Don't forget to leave your comments/suggestions on how I can improve my service.
Thanks..
Jan 27, 2011 | Nokia 2690 Cell Phone
I want to transfer my files from pc to mobile via bluetooth
If you want to transfer files from pc to the mobile device. Make sure the pc has a bluetooth turn on. Most of the laptops have a built in bluetooh , but for desktop computers you need to purchase a bluetooth adapter.
Once you have the bluetooh turn ON on your computer. Turn on the bluetooh on your mobile device.
From your computer. Right click on the file that you want to transfer and select send to bluetooth. Click on search for bluetooth device and then select the name of your cellphone ( or name you assigned for the bluetooth on your cellphone)Once you click the name, just go next . You will get a message saying accept bluetooh file on your cellphone, just accept the file and your done.
kevin angell
Jul 03, 2010 | Computers & Internet
Blinkin/flashin cellphone after receivn a file via bluetooth
This may bring serious results. The file must have been containing virus. Try servicing from an enjineer.
Aug 12, 2009 | Verizon Communications LG VX8350 Cell...
My blackberry bold can not receive any data via bluetooth from another type of cellphone or bluetooth dongle, however it can transfer data via bluetooth to others, what's wrong ? I tried to search through...
I had the same exact problem wondering why in the world can I send but not receive?! I even turned off the firewall thinking it had something to do with it but it didn't. I did a bit of digging around on the internet and found a solution. I have a Pearl 8110 and I found this info for the storm and added some minor info in brackets. Just tried and it works ;)
Here you go:
1. Open the Media app.
2. Select a media type (e.g. Music)
3. Press Menu.
4. Select Receive Using Bluetooth.
5. Select Yes. (It will then ask you the location you want to save to but of course by default it will select the proper folder)
6. Select Save. (Transfer will begin
Feb 03, 2009 | RIM BlackBerry Bold Smartphone
Install game on sgh-d9001
If you want to install games or other files on your cell-phone,
first activate bluetooth on your computer. Scan your house for any devices.
Soon, your computer will pick up your phone (if it is on, which it should be).
Your computer will ask you if you want to pair your cellphone to your computer, say yes!
In a few seconds on your cellphone you will recieve a password box. Look back at your
computer, there should be a password. Type this password in on your cellphone.
Then Wait................
After a while your computer will say something like pairing complete or successful.
now is the easy bit. Seeing I am an eleven year old, trust me it's easy! Go into your
blue tooth application and press send file. A list of bluetooth devices will appear, choose your cellphone. Then pick the file you want to send. A progress bar will appear on your computer screen.
When this happens, your cellphone will ask a question such as "Exchange object with Jack's
computer?". Say Yes. In a few minutes your object will be on your cellphone.
I have only tries this with music and photos, but if you are interested in games, I suggest you
send the un-zipped file to your cellphone. (just click the file twice on your computer wait and then send the new file)
Dec 22, 2008 | Samsung SGH-D900 Cellular Phone
Upload a photo into my computer
There are two ways to transfer your pics-
1. Bluetooth (wirelessly)
2. USB Cable
Since the USB part requires you to have Motorola Phone Tools, i'm not touching that part.
For Bluetooth, your computer needs to have bluetooth. If not, you can get it from any computer store for about $5. It looks like a regular pen drive. Once attached to a PC, it installs itself. and after it's done, you can just right-click the blue 'B' icon in the system tray, click on receive a file, and immediately send it from your cellphone.
How to send files thru Bluetooth from Razr:
open multimedia>pictures
open the picture you want to send
press the 'menu' key (top, middle)
select 'Copy'
select 'Yes" when it asks to turn Bluetooth on
Now, on your computer, do the right clicking part that i told earlier
search for new devices on your Razr.
select your computer's name.
This is the standard method of sending files to and from a PC & cellphone.
Jul 22, 2008 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
42 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
vince
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
