Question about Sierra Wireless AirCard 580 (AC580EVDO)
My aicard is not working with my desktop bur works with laptop
Trying to connect my air card with my desktop computer, it will work for ten seconds and stop.But with my laptop, it works perfectly.
  • 126 Answers
Welcome to,
ok as u said that it is working fine with the laptop not with the desktop,then what u can try is that reinstall the driver for the aircard and install the aircard utility,and then try and connect,enable the wireless zero configuration of the sohould connect...good luck
Posted on Feb 14, 2009
How to connect dual monitors to one tower
Most video cards have at least two outlets, usually a VGA and an HDMI or DVI (some have all three) plug in a monitor to each one, right click on your empty desktop and select display. You may have to hit "detect monitors", to have two separate monitors select "Extend" my desktop, to have both mirrored select "Duplicate" my desktop, save changes, you can also select which will be the primary.
Dec 03, 2017 | Tower Computers & Internet
I have a Konica Minolta Biz hub 350/250/200. I am trying to set it up for scan to desktop. I am able to ibstall printer, am able to print, I can ping the machine from the desktop, But I am unable to ping...
try scan to mail. your own mail adres. some seconds delay bur for me it worked fine
for mailserver give the same as on your e-mail client (like outlook). not the pop but SMTP
Jul 07, 2014 | Konica Minolta bizhub C250 All-In-One...
Monitor turned pink
Video-cards generate "primary" colours (red, green, blue), and "mix" those colours to produce millions of "secondary" colours.
First, try replacing the "data' cable between the LCD and the video-card.
Second, if your LCD works correctly when connected to some other desktop or laptop computer, then the video-card in your computer is not working properly -- not sending one of the "primary" colours to the LCD. Replace the video-card.
Jul 17, 2010 | Samsung SyncMaster 931B 19" LCD Monitor
No internet connectn for desktop but wireless works with laptop.
If your running xp, make sure the netowrk card is not disabled, make sure you rnot using a cross over cable. use the cable you got with the routers. Try reinstalling the network card, goto dell support andenter you model to get the drivers.
1 thing to check. goto start ,control panel.
double click on netowrk conections.
right click on the main conection witch is the card in your pc, goto properties. andin the list internet protocol (tcp/ip) click this. and pres properties.
make sure in here obtain ip addres is automatically. and obtain dns is auto too.
Try this let me know how you get on.
Dec 01, 2009 | Dell Dimension 4550 PC Desktop
Trying to set up a second computer for wireless
What wireless mode is you router operating in? Does it support the cards on your other systems?
Do you have mac address control enabled?
Try disabling security temporarily to see if you can connect; your wireless connection may not be setup to authenticate properly.
Nov 16, 2009 | Belkin Computers & Internet
Power supply has shut down, with the power -on LED flashing on and off. It rather looks as if the power supply is trying to start up and then immediately shuts down.
what system is it connected to laptop or desktop? if a laptop try using the Fn+ Monitor buttton may be in a different mode .. if desktop try another monitor if it works then the issue is something else or if it still does not work then it could be a loose video card try reseating the Video card
Oct 06, 2009 | Hyundai ImageQuest 19 L19T LCD TFT 19" LCD...
Can't get my wireless laptop to work. How do I connect the router to the computer?
First what type of router do you have? What is the model number?
Second ensure that your wireless switch (if your laptop has one) is set to on.
Go into view network connections and ensure your wireless card is enabled.
From you Desktop ensure that you are connected as described in the previous post.
Depending on your router make and model type in the ip address to the router.
Default for linksys is usually
DLink is usually192.168.0.1
From here it depends on your specific router.
There should be a wireless setup wizard.
Apr 23, 2009 | Computers & Internet
Trying to put a hard drive into a working computer
I am assuming you mean a Dimension 5100 (desktop) and not an Inspiron 55100 (laptop). The Dimension uses SATA drives and as such your second, working system will need an SATA port to connect to. You should take the data cable from the non-working system with the drive since, if there is an extra SATA port on your working system, it will more than likely not have a cable attached to it. Each SATA port only supports the connection of a single drive. There may not be an additional SATA port on the working machine, in which case you're SOL (unless it uses the same HAL as the other, but that's another story).
Feb 23, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Cannot connect a second pc
Are you connecting the machine that doesnt work wired or wireless??
Do you know what wireless card you have if it is wireless?
Dec 26, 2007 | Linksys Wireless-G WRT54GS Router...
Two units conflict when connected thru Firewire 400
Windows XP and most pcs running it does not natively support firewire,as it was developed by Apple computers. Most Firewire ports on PCs are 4 pin. Your PCI card ( and I take it, its a desktop youre referring to ) should have a 6 pin connection. Firewire connections also have a 7 watt supply via the bus. You may need to open the computer and see if the molex jack on the card is being powered by your computers power supply. Two firewire drives, especially the power hungry Lacie quadras, may be to much consumption for the card. Hope this helps.
Sep 23, 2007 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Sierra Wireless AirCard 580 (AC580EVDO) Logo
194 people viewed this question
Top Sierra Wireless Computers & Internet Experts
Jerry Umali
William Covington
Level 1 Expert
Are you a Sierra Wireless Computer and Internet Expert? Answer questions, earn points and help others
