Question about Samsung BD-P1400 Blu-Ray Player
Player says no disc
When i put disc into player it just says no disc
  • Samsung Master
  • 19,396 Answers
That is because of a dirty or defective lens.
Try first using a lens cleaner disk, like the ones here.
If that does not work, the unit must be disassembled, and lense cleaned with q tips and isopropyl alcohol or cleaning solution. See below:
How to Clean the Laser Pickup Lens on your DVD Player
How to safely clean a DVD lens?
Clean DVD lens, or replace player?
Clean CD or DVD ROM lens with a brush?
Cleaning your DVD drive
How to clean a DVD player
How do I clean my DVD player optical lens isoproponol alcohol
Posted on Feb 10, 2009
Why my dvd wont play on my player
Does that disc work on other players? Do other discs work on your player?
If you tell us more about the player, the disc, and what happens when you try to play the disc, we'll be able to make better guesses about what the problem is. Can you play other discs? Does that disc work in other players?
Not having specifics, here are some ideas, in the order in which they popped into my head:
1) That's a Blu-Ray disc and you have a DVD player.
2) The disc is dirty. Take a wet cloth (or paper towel), put a little dish soap on it, and gently swipe the shiny side of the disc from the center of the disc to the edge (don't wipe the cloth around and around the disc). Rinse the disc with cold water. Wipe with a soap-free wet cloth. Rinse again. Wipe with a dry cloth (or paper towel).
3) The disc is scratched. Some players handle scratched discs better than others. There isn't much you can do here. There are kits that can repair some scratches, but the kits aren't free, and they don't work a lot of the time.
4) You are putting the disc in upside-down. The side with the printing on it has to face up.
5) Your DVD player is dirty. Open the disc tray and blow as hard as you can into the player. Try not to blow any spittle into the player.
6) Your DVD player is broken.
7) Your disc is NTSC (Japan/US) and your player is PAL/SECAM (the rest of the world). Or vice versa.
8) There is some thing about region codes which is some kind of copyright protection scheme that means not all discs will work with all players.
9) Your disc is a CD, not a DVD. (I think most DVD players can play CDs, though.)
10) Your disc is DVD-ROM, meant to be used in a computer.
Mar 02, 2015 | Televison & Video
Says "No Disc"
If you have put a dvd disk in your dvd player, and it says "no disc" then try cleaning it with a dvd cleaning disk. It could be that the eye of your dvd player is dirty. You can get a dvd cleaner at any department store.
If you have put a dvd disk in your dvd player and its a home made or "burnt" disk and your player says "no disc", it usually means that the disk is the wrong format to be played on your dvd player. Try another disk.
If you have not put any disk in your dvd player, and it says "no disc" its just telling you that there is no dvd inserted for it to play.
Jul 13, 2011 | Sanyo DWM400 DVD Player
When I put in any DVD Disc, you can hear the disc spin. I opened the unit and put a disc in and could see it spin and you can see the laser light come on to try and read the disc. After about 10 sec or...
Is this a blueray player? If it is, the disc you put in probably isn't formatted to the blueray. If it is a standard dvd player there is probably something wrong with the player. You have two options. One, to take it in for service or two, to get another dvd player. If you have another dvd player in your home, try the disc you can't play from the one player and put it into the working player. If that works, then something is wrong with the dvd player you are having issues with.
Apr 03, 2011 | Televison & Video
Reads "wrong disc" when I insert any disc
Tru cleaning your lens,(pysically) give it a blow ,or similar
May 03, 2009 | Spectroniq PD-1100 DVD Player
My dvd player is reading no disc
Either your lens of the dvd player is dirty or the dvd's you put in have no data on them
Mar 30, 2009 | Philips Magnavox DVD/VCR Dual Player
No matter what disc I put in it wont play and Bad Disc comes up on t.v. I know the movie discs are good ones.
Hello marciafoxmar,
If you know for a fact that the discs you are putting in, then there is obviously something wrong with the DVD player. When you put a DVD in your player, can you hear it spinning the disc at all? If your DVD is not even spinning the disk, I'm afraid your DVD player might be toast. If it does spin your discs, try a lens cleaning disc (available at pretty much any home electronics store or large chain store that sells home electronics). If that does not help, let us know and also let us know if you would be comfortable opening your DVD player.
Mar 02, 2009 | GoVideo DV2150 DVD Player/VCR
Any disc put into dvd player shows up as BAD DISC
your DVD player lens needs to be cleaned by a lens cleaner...
Feb 09, 2009 | Conia DVD8500 DVD Player
I put the disc in the player ithen tries to play then it says disc not valid .
Same here!!! We've only used it maybe 8 or 9 times. And it's been worthless for the past month because of it. It reads everything "no valid disk" and nothing will work. And I tried e-mailing customer support several times, with no luck.
Nov 21, 2007 | Durabrand DUR7 Portable DVD Player
Troubleshooting pdv-0800
The usual reason for a drive to report "No Disc" is that the Reader eye is dirty or past its servicable life. this will be shortened in a Smoky or Dusty environment, A Cleaning disc (Preferably wet and dry) in the drive may solve the problem if the drive is dirty, if not then a replacment reader or drive are the only options.
If the Player is still within warranty I suggest you send it n.
Nov 04, 2007 | Polaroid PDV-0800 Portable DVD Player with...
Dvd player model dz111
there is a disc cleaner disc and a cleaning solution. put the liquid on cleaner disc and insert it.play for some time. now put a new dvd or cd and try
Oct 24, 2007 | Audio Players & Recorders
Samsung BD-P1400 Blu-Ray Player Logo
1,101 people viewed this question
Henry  Thomas
Henry Thomas
