Question about E-Machines T3990 (RBT3990) PC Desktop
Cant install full 2GB of memory in my emachines t3990
I purchased (2) 1 gb memory sticks both the same. They are 1gb ddr400. I can install either one or the other with one of the original 256mb sticks and it turns on fine. I tested both 1gb sticks and they work. When I install both 1gb sticks together though my computer screen will not turn on. My computer is rated for 2gb. It is a emachines t3990. It has an intel motherboard d865gvhz. I was told a BIOS update may fix my problem, however I go through all the steps and when it reboots it says it was unsuccesful installing it. Any assistance would be great, and if you need more info let me know. Thanks
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 16 Answers
Try removing the cmos battery and put it again and booting up.. since you have bought same kind of ram i dont think it could be a problem.also check for the jumpers in *********** board where you can reset your bios. be sure to read *********** boards manual before this
Posted on Feb 10, 2009
What memory do i need for a emachine 5210
You have 2 slots and each slot will take 1GB modules of PC 3200 DDR400 Ram. So with 2 of them you will have 2GB of PC 3200 DDR400 total.
May 19, 2012 | E-Machines eMachines Desktop PC
Just installed 2 2GB cards (Corsair VS2GB800D2) to replace the 1 1GB card in my emachines EL1200 series. Computer will not boot. replaced the old card and it booted right up.
Will it boot with only ONE of the 2GB memory-sticks installed?
Will it boot with ONE of the 2GB memory-sticks AND one of the 1GB memory-sticks?
Look closely at the 1GB memory-sticks.
Does the label show 'DDR266' or 'DDR333' or 'DDR400' or 'PC2100' or 'PC2700' or 'PC3200' ?
Do the 2GB memory-sticks have _identical_ information?
It's definitely _not_ acceptable to have "slower" RAM (smaller numbers) in the new RAM,
but it _might_ be acceptable to have "faster" RAM (larger numbers).
Nov 12, 2010 | E-Machines eMachines Desktop PC
I want to upgrade my RAM on my eMachine t3504. I currently have 256 in each of my 2 slots. Can I upgrade one of the slots to 1 GB and leave the 2nd at 256 or do I have to upgrade both slots?
Yes you can upgrade 1 of the slots to 1GB, as long as 1GB stick of memory is the 256MB stick then you can have both, to check the memory you will have pull them out of the slots and have a look on a little sticker on one side of them. You are looking for i.e DDR400/333/266 if the 1GIG memory matches one of the values mentioned above, say it is a DDR400 and the 256 is a DDR400 then they are compatable if not you will have to just leave the 1GIG stick in by it self in DIMM socket 1.
Apr 03, 2010 | E-Machines T3504 PC Desktop
Want to upgrade memory to 2 GB. Desktop will not post up with 2x1GB cards. Every 2-3 seconds it makes a sound/tone. The fans would turn on but there is no signal to the monitor. However, it will post up...
There is no reset just because you added memory.
If you have 2- 1GB sticks, try both , one at a time.
Your system spec's and manual tell nothing which dimm banks are suppose to be used , and if you can install 2-1GB sticks,
all it says is it can handle 2GB.
Now it says 512MB, sticks, this could mean you can only use 4-512MB sticks to get too 2GB,.
Now it does not tell which dimms are used if you have 2-1GB sticks,
You have 4 slots, the first two and the second two, most times, you either use the second bank of each pair, or the first slot of each pair,
but as I said, your system does not say.
So you can try both ways and see if one of them work.
Sorry I can't be of more help,but you system has a poor manual
on memory placement.
Feb 14, 2010 | E-Machines T3302 PC Desktop
Memory upgrade issue
Most ram has to go in pairs. Buy another stick of the 1GB, and it will run fine.
Jan 23, 2009 | FIC K8-800T Motherboard
Upgrade ECS FSB800 memory from 1 GB to 2 GB wont work
This board will support up to 2gb as shown below extacted from the website product page.Don't forget that if you have ddr 333 memory installed originally, you can only add the same clock speed memory, i.e. ddr 333. If you add ddr333 and ddr400 you will have problems as the clock speeds do not match. If you are matching clock speeds, the try bootin the system with the new piece of memory on its own to see if there is a problem with that stick, trial an error of both sticks individually, will give a positive result
MEMORY ecs_buttom_03.gif Single-channel DDR memory architecture ecs_buttom_03.gif 2 x 184-pin DDR DIMM socket support up to 2 GB ecs_buttom_03.gif Support DDR400/333 DDR SDRAM
Nov 02, 2008 | EliteGroup ECS P4M800-M Socket...
High density memory
need low densisty on ebay 35 buck eash 1 gb ok works on picky mobos way better
Feb 07, 2008 | Dell (E210882) Motherboard
Type of memory for e210882 motherboard
the memory you're about to purchase will not work. the maximum gig that the computer can handle per stick is only 1 gig. this system is not designed for 4 gig barrier.
hope this helps.
thanks.
Feb 05, 2008 | Dell (E210882) Motherboard
Windows xp
hi
is this your motherboard? http://shop.pcmag.com/shop/product_specs/Intel+D915GAG+BLKD915GAGL10+Motherboard/22673983.aspx
if so, it is ok for you to upgrade your memory up to 2gb. btw, just be sure to properly install the rams to the slots.
since youve purchased 2 x 1Gb ddr400 , put on color blue slots.
hope this helps
Jan 23, 2008 | Intel D915GAG Motherboard
3x 1GB DDR400 Problem on booting!
the details for your case can be obtained in this site.....................
http://www.memory4less.com/m4l_results.asp?ref=mem&modelid=800121
read carefully to understand the limitations that arise with your motherboard.
cheers....................
Jan 22, 2008 | ASUS P4S8X Motherboard
E-Machines T3990 (RBT3990) PC Desktop Logo
326 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
