EliteGroup P4VXAD Motherboard Logo
Posted on Feb 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
AUDIO SOUND I CAN'T FIND AUDIO SOUND IN MY PC
krishna Singh
Level 3:
  • Master 407 Answers
  • Posted on Feb 10, 2009
krishna Singh
Master
Level 3:
Answers
407
Questions
17
Helped
108214
Points
1057
Plz install your motherboard driver...............
No sound from pc
check the volume bar, sound card driver , and or do restart your pc. also check the audio jack plugged properly to audio output ( green color).
C795 my audio driver is delete i have a no sound in my laptop
Sir.install Sound driver OR Download and install
http://h30434.www3.hp.com/t5/Notebook-PC-Sound-and-Audio/Audio-Sound-Driver-For-Compaq-Presario-C700-CTO-Notebook-PC/td-p/204990
1helpful
2answers
MY DELL PC HAVE SOUND DRIVERS WHICH ARE NOT WORKING AND ONCE I INSTALL NEW SOUND DRIVER THEY SOUND AT A VERY LOW VOICE EVEN WHEN THE VOLUME IS ADJUSTE TO THE HIGHEST
Hi antonykionyo
DELL OPTIPLEX GX60 DESKTOP PC AUDIO/SOUND DRIVER
You don't say which Operating System you use, so my answer will be presented in general, Windows terms. If yours is a non-Windows Operating System, consider applying the logic and principles involved here to your own Operating System and, if in doubt, please feel free to add a Comment or Clarification to this Question, including information about your Operating System.
Check the status of the Audio Device and the Audio Driver in Device Manager.
Start > (My) Computer > (System Properties) View System Settings > Device Manager
This will tell you if the Audio/Sound Device is installed and functioning properly and if the Audio/Sound Driver is installed properly. If a red 'x' or a yellow question or exclamation mark appears next to the Audio/Sound Device, then there is probably a settings anomaly, fault, error or conflict with the Audio Device and/or its Driver.
AUDIO DEVICE SETTINGS
For your Audio/Sound Device to function properly, it must be set as the Default Device:
Start > Control Panel > (Hardware and Sound) Sounds Speech and Audio Devices > Sounds and Audio Devices > (Manage Audio Devices) Audio > click on the Drop Down Menu to the right of "Sound Playback - Default Device" (preferred Default Playback Device) > select "ADI 198x Integrated Audio" > Apply > OK > Restart computer.
AUDIO/SOUND DRIVER PROBLEMS
Re-install the correct Audio/Sound Driver that relates to both the Audio/Sound Device (ADI 198x Integrated Audio) and your Operating System, then restart the computer. Install the Audio/Sound Driver either from the Dell Drivers and Utilities CD or from the official Dell support website here:
http://support.dell.com/support/downloads/download.aspx?c=us&cs=19&l=en&s=dhs&releaseid=R71579&SystemID=PLX_PNT_CEL_GX60&servicetag=&os=WW1&osl=en&deviceid=2430&devlib=0&typecnt=0&vercnt=3&catid=-1&impid=-1&formatcnt=0&libid=3&typeid=-1&dateid=-1&formatid=-1&source=-1&fileid=92933
If your Operating System is not the original Windows 2000 or Windows XP for which this PC was designed, then it is highly probable that no Audio/Sound Driver exists for that Operating System.
If you are committed to both this PC and an unsupported Operating System but all the other Devices and their Drivers are functioning normally except the Audio Device or you are using Win 2000 or Win XP but the Audio/Sound Problem remains unsolvable (faulty Audio/Sound Chip), then consider buying and installing either an internal 5.1, 7.1 or 8.1 PCI Sound Card or an external USB Sound Card that is pre-confirmed as being compatible with your Operating System. They can all be inexpensive. See examples here:
http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=5.1+7.1+8.1+pci+soundcard&x=5&y=17
I hope this helps.
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it. Doing so helps Solution Providers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can. If you need further help, please do not hesitate to post another Question or add a Comment to this Question.
Thanks for using FixYa.
After my PC reformat, the creative sound blaster l...
Pl load the audio drivers again and reboot the PC after that, before enjoying the sound again.
1helpful
I have a Gateway DX4300 and want to use my LED TV with surround sound on a receiver as the monitor. No HDMI slot on computer so I have Y-connector in headphone jack on front of box and I plan to connect...
Open your sound contol monitor (the speaker icon in the system tray) and makes sure there are no checks in the boxes for audio output. Also make certain the audio out device is set to your sound device. eg "realtek HD Audio" or whatever your PC sound card is. Make certain the slider buttons are about half way up for the Audio output. If your sound card is installed ok. your sound should now work.
3answers
No audio on pc problem
Check the Sound and Audio settings to make sure that the proper output device has been selected. Go to your Control Panel then Sound and Audio Devices, then the Audio tab. In that tab make sure that Default Sound Playback is set your sound card.
1helpful
2answers
4helpful
8answers
I have no sound in my pc!
change from windows to xp,but sound driver was not loaded/installed so there is no audio sound in
my pc.from where n what driver to install in window xp for free.kindly
advice n thanks.
1helpful
4answers
Presaroio sg3043il sound driver lost
Yound appears to be a Realtek HD Audio Codec, Try one of these links:
ftp://152.104.238.19/pc/audio/WDM_R183.exe
ftp://202.65.194.211/pc/audio/WDM_R183.exe
ftp://61.56.69.18/pc/audio/WDM_R183.exe
Top EliteGroup Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
