Question about Toshiba 65H84 65" Rear Projection HDTV
Can't control tv with remote can control it from front pannel
Sometimes the remotes work and sometimes they don't. I have more than one remote when one won't change the volume or chanel the other one won't either. I've checked the batteries. I can operate tv from front panel
can you help me with my problem please
  • michellehwoo Feb 11, 2009
    I have a universal remote and the one from the tv. when it doesn't work it doesn't work on all of them. sometimes it will work, but it is not working more often than it is I don't think it is the remotes at all I think it is in the TV. thank you for you comment
    Problem Solver:
  • 8 Answers
If you have universal remotes check the coding.
Posted on Feb 10, 2009
At power up, tv scrolls uncontrolably through channels, power light flickers
1. Take remote control far away from tv - 3rd or fourth room. Then switch on tv. If uncontrollable scrolling stops , then cause may be remote button (Ch+ or Ch-) has got dirt inside and its shorting.
2. If taking remote far away doesn't stop scrolling then (Ch+ or Ch-) button on front pannel has shorted. Take a cutter plier and care fully remove button from its circuit board. ( If you know desoldering, it is far better than cutting). If scrolling stops then you can operate channel change with remote.
Jan 27, 2014 | Samsung LN46C600F3FXZA 46in Lcd Tv 1080p...
My RCA Truflat T.V won't turn on and the FPA lock is turned on, I have the original remote. what should i do?
TV won't turn on • Press the TV button. Make sure the TV is plugged in.• Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else.• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions on page 26.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).Buttons don't work
• If you're using the remote control, press the TV button first to make sure the remote is in TV mode.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).• Unplug the TV for two minutes and then plug it back in. Turn the TV on and try again.TV turns off unexpectedly • Sleep timer might have been activated. Go to page 24 for instructions.• KidPass might have been activated. Go to page 21 for instructions.• Wake-Up timer turned on the TV and no remote or front panel buttons were pressed for two hours.• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then
turn on again. If this happens frequently, the voltage in your house may be abnormally high or low.
• Unplug TV. Wait five minutes. Plug it in again.
Sep 16, 2011 | RCA 20F420T 20" TV
Remote lights but does not do anything else replaced battery
clean the front bottom panel of your TV with damp cloth then dry well with paper towel. Do the same for the front of the remote. It should work.
Otherwise, you will need to buy a Universal Remote control.
Or order a replacemet Samsung unit off of e-bay. One is below. They all work, you don't need the exact same model (the case changes slightly or you may get one with an extra button. In the end, they all work on all Samsung TVs.
One person is currently selling an exact replacement for $10 plus $4 shipping. Note: sometimes, it is the TV receiver that is bad, not the remote. Try your remote on a friend's Samsung TV to make sure it is bad (if you friend lets you borrow his/hers, try there remote on your tv to make sure it works).
Sep 09, 2011 | Samsung Bn59-00673a Remote Control
I have a Hitachi Ultravision TV Model #50ux53k v7h002332. The remote is working and also changed the Batteries. The Tv is not reacting to the remote like it should. It randomly will not turn on or off and...
if you have to hold the remote very close it is likely a bad remote receiver in the front control panel; the only other reason would be a dirty lens there or at the top of the remote.
Let me know if all manual front buttons work normal.
Apr 28, 2011 | Hitachi Televison & Video
How do I code my Toshiba TV to work in a samsung 00053A remote
3ktr670957r is the serial number of my tv which has requried the pannel code which i have forgot
Jan 16, 2011 | Samsung TV Remote Control
My remote fell 5 days ago and now my tv can gon on but it has a little padlock on the top right hand corner and I can only switch the tv on or off
off the tv and while you on it just press all the buttons on the tv front pannel randomly after tv gets on, if not solved.then off the tv after you on it again.just press the volume up and down button together on the remote or at the front pannel of tv. if still not solved   off the tv and on it and press the channel changing front and back button together. if still the same problem then  off the tv and as you on it press the  ---F --- function button in the remote and --- MENU ---  button in the remote togetrher  for 1 minute.
Mar 09, 2009 | LG Televison & Video
the sensor for remote has fallen off its usually connected to a 8 inch wire which fell back into system pull the sensor wire forward the way to get into tv 3 ways front pannel pops off sensor is set at front
there the back of tv
then theres threw the
Mar 19, 2008 | Apex Digital GB5108 51" Rear Projection...
Front controls mixed up & remote doesn't work
the channel down button is stuck on, you need to replace this switch internaly to the set.
Nov 14, 2006 | Sony KV-36FS100 36" TV
Toshiba 65H84 65" Rear Projection HDTV Logo
54 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
