Question about Sony Cyber-Shot DSC-R1 Digital Camera
My Sony DSC-R1 refuses to read memory sticks
My R1 refuses to read the memory stick. I have to remove and reinsert several times before it reads the stick which is terrible as I am a professional photographer. Otherwise it just says "Insert Memory Stick".
I had one before, same camera, that had almost the same problem, except that R1, when you held the camera and if there was pressure on the memory stick cover, it wouldn't read the stick at all.
Can someone please help me with this?
  • 80 Answers
The first think I would do is connect the memory stick to the computer and reformat it.
Posted on Feb 10, 2009
My sony dsc-w180 has a problem. whenever i open it, it just display the "reinsert memory stick" and i already did it for the hundred time. i also remove the battery and put it again. but it just...
The next thing to try would be a different memory stick. If it is just a bad memory stick, and not a problem with the camera, this would resolve it. Or if a different stick makes no difference, it would confirm that the problem is in the camera.
Another way to test the stick would be to try to read it in a memory card reader attached to a computer. This could establish whether there is a problem with the stick without you having to obtain a new one.
Nov 03, 2010 | Sony Cyber-shot DSC-W180 Digital Camera
13:01 error
The C:13:01 error code indicates the issue with the Media used in the Camera.
This may be due to the:
Format Error of the Internal Memory.
Un-formatted Memory Stick Duo.
Broken Memory Stick Duo.
Memory Stick Duo type error.
When the Camera cannot Read or Write the data in the Memory Stick Duo.
This can be resolved by Formatting the Internal Memory and Memory Stick Duo.
If not resolved, try inserting a new Memory Stick Duo which is supported.
Try power resetting, remove and reinsert the Memory Stick etc.
This will resolve the issue, if not the Camera may require service.
Aug 06, 2010 | Sony Cyber-Shot DSC-F717 Digital Camera
C:13:02
After having formatted the memory stick with the cardreader on my laptop which runs on winxp I tried to use the stick in my sony dsc-p5 but all I got was the C:13:01 error message. So I tried to format it again but eith FAT instead of FAT32 which is the regular format on winxp. Now the disc adapter which I use on my desctop to read the memory sticks worked again with the stickt, my camara still gave me the message of not being able to read the stick so I removed the stick, got into the setup mode, reinserted the stick and formatted it with the camara. This worked, I hope this can help you.
May 09, 2010 | Sony Handycam DCR-DVD92 DVD Camcorder
Getting an error code c:13:01 on my sony t900 camera
“Memory Stick Duo” is unformatted.
“Memory Stick Duo” is broken.
“Memory Stick Duo” type error
The camera cannot read or write data
on the “Memory Stick Duo”.
Format the “Memory Stick Duo”.
Replace a new “Memory Stick Duo”.
Insert a supported “Memory Stick Duo”.
All above are solution for your quiry
Jan 21, 2010 | Sony Cyber-shot DSC-T900 Digital Camera
My camera dsc-w80 says to reinsert the memory stick, its is in right and i tryed to few the pictures on the memory stick on my card reader and there is no proplem how to i get the camera to read the...
yes i believe that the memory stick is the only problem. i also have the same problem and i tried to put in with another memory stick and the camera works just fine. the battery does not haf any affect either on the memory stick...sigh i need my pictures back ! :(
Nov 05, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
I GOT THE PROBLEM IN MY CAMERA FORMAT ERROR C:13:01 MODEL DSC-P31 THE PROBLEM CREATED WHEN I TRYIED TO DOWNLOAD PICTURE
The Error message C:13:XX indicates that the Camera cannot read or write data on the Memory Stick or an unformatted Memory Stick is inserted in the Camera or the inserted Memory Stick cannot be used with your Camera or the data is damaged.
1. Try reinserting the Memory Stick several times.
2. Format the Memory Stick in the Camera.
*Formatting a Memory Stick will delete all the data saved in the Memory Stick.
Insert the Memory Stick in the Camera, Turn ON the Camera. Press MENU -> Memory Stick Tool -> Format -> OK.
Memory Stick compatibility information for you Camera:
http://esupport.sony.com/perl/support-info.pl?&info_id=12&mdl=DSCP43
3. Try with different Memory Stick.
Good Luck!!!!!!!!!!!!!!!!!!!!
Aug 28, 2009 | Sony Cyber-Shot DSC-P43 Digital Camera
I have problem with my memory stickproduo 8GB
Sounds like the memory stick is damaged, if you cant read it in a reader or the camera there is not much hope try a new memory stick to see if the problem reoccurs on the new one, if so then the camera itself is damaging the stick when it writes the file
Jun 23, 2009 | Sony Memory Stick PRO Duo (2GB) for PSP
Keeps telling me to reinsert my memory stick
I will forward a link to a page where you can get the information about this issue.
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C166567
Also please check whether you're using a Compatible Memory Stick with the Camera.
It's not recommended to Format the Memory Stick in the Computer.
The Memory Stick should be Formatted in the Camera only, other wise such error messages can occur.
Please try using a different Memory Stick and check whether the issue persists with the other Memory Stick.
This is to check whether the issue is with the Memory Stick.
Apr 14, 2009 | Sony Cyber-shot DSC-W300 Digital Camera
Sony cyber shot DSC H50 keeps reading "turn camera off and on aga
The error you are getting is because of either System Error or Internal Memory Error.
I think you might need to take it to Sony since it is brand new. But Before that, I suggest that you take out its memory stick, the battery etc and keep the camera like that for about 15 minutes. Then only reinsert the battery (fully Charged) and try to power on. If you are lucky, you might not need to go to Sony
Mar 05, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Memory Stick
i got the same problem, if i had a sony office/sales shop around i'll go give them to take a look,
Oct 10, 2007 | Sony Cyber-Shot DSC-P32 Digital Camera
Sony Cyber-Shot DSC-R1 Digital Camera Logo
121 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
