Question about Philips GoGear HDD1830 MP3 Player
My gogear got wet and it turn 0n an but the key don't work
The screen shows and only turn on with the reset bottom the screen show up but i can not play songs i can do nothing with it can some help me please
OK going to sound wierd but it maybe your only hope here put it in a bag of rice uncooked dry rice just plain rice and the rice will **** the mosture out after a while and may fix you right up handy trick for cell phones that take a swim as well
Posted on Feb 12, 2009
Philips gogear connect 3 shows only a white screen and its not working
Try resetting your tablet. Google search your make, model and reset. Follow the instructions from one of the results provided.
May 12, 2012 | Philips SA3CNT08K 8 GB GoGear Connect 3...
PHILIPS GOGEAR 8GB STUCK on the screen showing that Go gear & if I press the reset buttan it wont works what should i do?
read owners manual,you can look inside manual also for technical support number they will help you.any time you buy devices they have instruction manual that tell you how to operate device.
Nov 13, 2011 | Philips GoGear Micro Jukebox 8GB...
My model is Philip SA1MXX02W/97 GoGear Mix 2 GBMP3 Player.When I on it, it shows updating 20 percent, then updating 40 percent ; hang there for few seconds and suddenly off by itself. Pls help.
It shows there is some problem with the inbuilt device firmware.The only solution is to do a reset on your device.Please follow the instructions below to reset your Philips SA1MXX02W/97.
1.Insert a pen tip or other object into the reset hole located at the bottom of the GoGear Mix. Hold until the player shuts down.
If the reset option is unsuccessful, follow the steps below to recover the GoGear Mix with the Philips Device Manager:
1.On your computer, select Start >Programs > Philips Digital Audio Player > GoGear Mix Device Manager > Philips Device Manager to launch the Philips Device Manager.
2.Turn off the GoGear Mix before you continue.
3.Press and hold the volume button + while you connect the GoGear Mix to your computer.
4.Keep holding the key until the Philips Device Manager acknowledges the GoGear Mix and enters the recovery mode.
5.On the computer, click the Repair button and follow the instructions of the Philips Device Manager to complete the recovery process.
6.When the recovery is completed, disconnect the GoGear Mix from your computer.
7.Restart the GoGear Mix.
Hope you are satisfied with my solution.Thanks for choosing Fixya.
Jun 26, 2011 | Philips SA1MXX04P/02 GoGear Mix MP3 Player
I have a phillips go gear MP3 player and when i turn it on it freezes only the words www.phillips/welcome.com screens shows. how to i fix this?
Hello
Your GoGear is freezing because there is an error in the operating system and can be fixed by resetting the device. Resetting the GoGear is similar to rebooting your computer. You will not lose any of the data uploaded to the device. To reset the GoGear, press the "Reset" button located on the left of the device. The screen will go blank for a few seconds and then turn back on.
If the GoGear freezes after uploading a file to the device or if one song or sound file freezes the device each time you play it, the file is likely corrupt and needs to be removed from the GoGear. Connect the GoGear to a computer and delete the file from the device.
Sep 02, 2010 | Philips SA3025/37 Flash MP3 Player
G1 got little wet but it dried out and screen shows all but now triangle and cant get touchscreen to work....what do i do?
If it got wet it might still be wet from the inside and that is why your touch screen wont work, You would need to open it and clean it from inside. Or it could have a bad digitizer and that is a second reason why the touch screen wouldnt work. You can try doing a hard reset if you says it just shows a triangle on the screen.
Turn the G1 off. If it’s frozen on, take the battery out and put it back in the unit.Hold the Home and Power keys down at same time for about 25 seconds. You will see a yellow triangle screen with exclamation point in the middle
Now to wipe the device clean:
Press Alt+L. Press Alt+W for a factory reset.
Press the Home and Back keys again for about 25 seconds.
The device should then reset again and the hard reset is complete.
Jun 15, 2010 | HTC G1
It just says gogear on the screen and it will not show anything else. i can't turn it off it seems as if none of the bottons are working. the battery lookes to be charging then this Gogear will just come...
It just says gogear on the screen and it will not show anything else. i can't turn it off it seems as if none of the bottons are working. the battery lookes to be charging then this Gogear will just come back on till the battery runs out. what can i do.
Sep 15, 2009 | Philips GoGear HDD1830 MP3 Player
Philips GoGear 8GB stall at update screen
I just repeated the steps above on more than one computer until it finally connected and showed the songs, then I deleted everything, restarted it and voila` all the menu's showed up. Then the first thing I did was reset to factory settings. After that it worked perfectly. I don't really know what combination really fixed it, but I kept hitting the reset button, restarting while holding down the volume + key and the <loop> key until it eventually responded.
Sep 06, 2009 | Philips GoGear SA5285/37 Digital Media...
Error message File System Error
Whenever I go to turn on my Philips Gogear audio video mp3 player, it shows the welcome screen but it doesn't go to the GoGear or the updating screens. Also, whenever I plug it into my computer through the USB cord, the charging screen doesn't show and it does not show that it is connected on 'My Computer'
Aug 20, 2009 | Philips GoGear SA3125/37 MP3 Player
Mp3 philips hdd082/17 not charging and not connected when connected to usb
WARNING: this process will erase all songs off the GoGear.
Disconnect the GoGear from computer.
Turn the GoGear off.
Hold in the volume + button.
Reconnect the GoGear while holding in the volume + button.
Continue holding the volume + button.
After 5-50 seconds, Windows will pop-up a "Found New Hardware Wizard." - complete the wizard (BTW, you can take your hand ff the volume + button now).
Good To Go (Gear)!
-Tha Mp3 Doctor
Mar 24, 2008 | Philips HDD082 MP3 Player
Philips GoGear HDD1830 MP3 Player Logo
59 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
