Back to:
Tags:
Texas Instruments TI-89 Calculator
Origin of Newton's "G" and "J"
By M0nica L - usenet poster
I assume to maintain consistency with previous versions of the
standard, within an acceptable margin of error, so that retooling
would be minimized. We generally don't ask industry to invest billions
of dollars in new taps, dies, micrometers, thread gauges, and scrapped
material just to make teaching a little easier. I can't imaginge
anyone relished replotting all the geophysical data either (which you
at least should appreciate), or republishing all the maps, or changing
all the road signs.
Someone has way too much time on his hands.
Same as SI. The kilogram is the unit of mass; it is equal to the mass
of the international prototype of the kilogram. (Originally it was the
mass of a cubic decimeter of water). The platinum-iridium
international prototype is kept at the International Bureau of Weights
and Measures under conditions specified by the 1st CGPM in 1889.
Dare I ask why you are asking this?
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 01, 2007
Not Rated (0)
kioner
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
quite inconsistent with the original foundation of the kids.
no errors are acceptable in the kids mathematics or physics.
yes the longer it is put off the more costly it gets for the kids.
Whose we? You and your terrorists? Maybe you should have been a
politician instead of a cave dweller because when it comes to
correcting errors in the kids calculators, jillions of dollars is
insignificant.
yea, and georgia-pacific et al would have to make a 2"x4" stud measure
2"x4". i replot all of my maps after each well is drilled anyway, as
do all geologists and geophysicists, so what's the big deal? like i
said, when it comes to kids being taught errors, cost is
insignificant.
yes, it gets more costly daily which is why i am here to save kids
money.
here i am
ONE GOD = 1.000... A [EXACTLY] + -
One God = 0.999... A [Exactly] +
one god = 0.000...1 A [exactly] - i am
here under c i am not
1/c = 3.333... E-09 s/m [Exactly]
+ = 9.999... E-09 s/m [Exactly]
here c i am
c = 3 E+08 m/s [EXACTLY] i am
here c FOUR i am
c^4 = 8.1 E+33 m^4/s^4 [EXACTLY] i am
here under c FOUR i am not
1/c^4 = 1.23456789... E-34 s^4/m^4 [Exactly]
1/c^4 = 1.23456790... E-34 s^4/m^4 [Exactly]
1/c^4 = 1234567.89... E-40 s^4/m^4 [Exactly]
1/c^4 = 1234567.90... E-40 s^4/m^4 [Exactly]
1/c^4 = 123456789.BangE-42 s^4/m^4 [Exactly]
1/c^4 = 1234567901... E-42 s^4/m^4 [Exactly]
here i am
EUCLID'S ELEMENTS (fl.c.300 B.C.)
Let the following be postulated:
1. To draw a strait line from any point to any point.
(see above)
2. To produce a finite strait line continuously in a strait line.
(see above)
3. To describe a circle with any centre and distance.
[power point (first ".") -40 round curved]
4. That all right angles are equal to one another.
[power point (first ".") -40 right angles]
5. That, if a straight line falling on two straight lines make
the interior angles on the same side less than two right
angles, the two straight lines, if produced indefinitely,
meet on that side on which are the angles less than the
two right angles.
1/c^4 = 123456789"."...E-49 s^4/m^4 [EXACTLY] - i am
1/c^4 = 1234567901234567"."...E-49 s^4/m^4 [EXACTLY] +
here i am
Genesis seven fold... want to see the 2.000... universes reverse? i am
which some ONE = 1.000... [EXACTLY] + -
One = 0.999... [Exactly] +
one = 0.000...1 [exactly] - i am
2.000... [EXACTLY] + + - -
me or both of us kids
What's NIST current SI definition for kilogram?
Because the United States already unified the Four Forces of nature
and we are going to get you you mother fucking cock sucker Usama Bin
Laden...
"R. Baldwin" <
Superforce = speed of light in vacuumed free space
quadrupled (c^4) divided by Newton's
universal gravitational constant (G)
Superforce = c^4/G
1.216216...E+44 kg-m/s^2 = (8.1E+33m^4/s^4)/(6.66E-11m^3/kg-s^2)
1.216216...E+44 kg-m/s^2 = (1.216216...E+44kg-m/s^2)
[See SI SYSTEMS new unit definition for metre and kilogram]
unless you can prove me wrong,
Garry W. Denke
Geologist/Geophysicist
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Origin of Newton's "G" and "J":
I don't want to Accept this solution
Solution #2
Not Rated (0)
Putty
Rating: 0%, 0 votes
In talk.origins, Garry Denke, Geologist
< wrote
on Sat, 10 Aug 2002 22:17:09 +0000 (UTC)
Who says 'G' should be anything? We have defined
the terms "meter", "kilogram", and "second".
We can combine them in interesting ways; for example,
1 joule is the energy expended in accelerating
1 kg of mass using a uniform force of 1 newton
through the distance of 1 meter. (1 newton itself
is the force required to accelerate a 1 kg mass
on a frictionless surface to a speed of 1 m/s in
1 second.)
Given the conventional (to scientists; I'm not about
to go into Imperial units) units we know today, the value
of G, the Newtonian gravitational constant, is
G = 6.673 ?? 0.010 * 10^-11 m^3 / (kg * sec^2)
assuming that this is the constant you're referring to here,
as opposed to some other completely different 'G'.
We were to use different units, G would be a different value.
I have no idea what your 'h' is, although it appears to
be a dimensionless number of about 0.01 or so.
#191,
It's still legal to go .sigless.
Thank You!
Solution #3
Not Rated (0)
kcw573
Rating: 0%, 0 votes
Shouldn't that be 6.67259... E-11 N-m^2/kg^2?
No!
"G" should be 6.666... E-09 m^3/hkg-s^2 [Exactly]
But UBL says it costs too much,
"J"
Thank You!
Solution #4
Not Rated (0)
paulrmc
Rating: 0%, 0 votes
This guy's posts were so unusual I did a search and came up with:
Apparently, Mr. Denke believes that the Ark of the Covenant is buried
under the heelstone of Stonehenge, and that he is its sole owner under
British law.
He has also apparently published:
Herkommer, Mark A.; Denke, Garry W., 1982
Stratigraphy and Hydrocarbons, Parker County, Texas; in Petroleum
Geology in the Fort Worth Basin Area, Texas; Charles Martin, Ed.,
Dallas Geological Society, Dallas, Texas, pp 97 - 128.
Thank You!
Solution #5
Not Rated (0)
Lizzy
Rating: 0%, 0 votes
What makes you think kids had anything to do with it? The metric
system was recommended by the Paris Academy of Sciences to the French
National Assembly in 1791. The platinum standards for the meter and
kilogram were deposited in the Archives of the Republic in 1799. The
obvious benefit over the multiplicity of national standards were (a)
it was decimal, resulting in simpler calculations, and (b) since it
was originally derived from geodetic measurements, it would better
support cartography. At the time, universal public education was still
a dream.
Huh? Where do you get this nonsense? Surely, a geologist would
comprehend the meaning of acceptable margin of error when it comes to
metrology.
How so? Just where is the cost for kids?
What makes you say this? You do realized, don't you, that the
calculators contain errors regardless of the unit of measure or its
basis? I'll assume for now that you are not entirely ignorant of how
floating point arithmetic works.
There are errors in measurement regardless of the standard, due to the
accuracy and precision of the measurement device. This is not the same
as kids being taught errors.
How does this save kids any money?
What is this gobbledygook intended to demonstrate? If it _does_ mean
something, you haven't made it very clear.
Since when do kids make measurements involving the speed of light?
Last time I checked, in elementary school they use wooden meter
sticks. Also, what makes you think a relativistic universe is
Euclidean?
mass of the was the mass of a
Thank You!
Solution #6
Not Rated (0)
Phoebe
Rating: 0%, 0 votes
quite inconsistent with the original foundation for the kids
maybe you should have been a politician instead of a cave dweller
because when it comes to correcting errors in the kids calculators and
teaching the kids to ignore errors in the kids calculators jillions of
dollars is insignificant
like i said when it comes to kids being taught errors cost is
insignificant
I can't imagine anyone relished replotting all the geophysical data
either (which you at least should appreciate), or republishing all the
maps, or changing all the road signs.
yes it gets more costly daily which is why i am here to save the kids
money
here i am
here c i am
here c FOUR i am
here i am
(see above)
(see above)
two right angles.
Genesis seven fold... want to see the 2.000... universe flip ?
just wondering how far off the foundation it was UBL
Thank You!
Can you Help with these Calculators problems?
I cannot figure out 'how to enter r2' on a TI calculator,...
I am a mathematics instructor helping a student with a...
i need to find out how to add and subtract feet and...
Hey, I have recently been doing many Hexadecimal...
I changed batteries in TI-89 titanium; now the whole row...
Loading problems.
Repair Service
Find Calculator Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
