Question about MSI K7N2GM2-LSR Motherboard
Failed Southbridge in MSI P6NGM mobo
The first sign of a problem was the usb's stopped working. I'm prepared to buy another mobo, but do I have to reinstall the OS and software after the mobo is installed? If so, should I clone my HD first? I have these concerns because I have a very intergrated setup using 2.4 quad core cpu with 4 gigs of ram OS Xp pro sp3. On this system I run a recording studio with a host of periphials, i.e. external firewire soundcard, esata ext HD. Should I buy a mobo with esata & firewire ports and do away with the pci cards? I appreciate any suggestions that anyone may offer thanks AJ.
  • 565 Answers
If you replace the mobo with the exact same one that you have now you won't have to re-install the OS. Of course, you'll want to back up all your files before doing that. You probably have most of your files backed up anyway. If you get a mobo with onboard esata and firewire, that would be an improvement, however, you'll have to re-install the OS. You could try an in place OS install, though.
Posted on Feb 10, 2009
    Problem Solver:
  • 6 Answers
Whenever changing out a MB, you run the risk of having to do a complete re-install of Windows. A few caveats: If you choose a MB with exactly the same chipset and integrated peripherals, then you may only need to update a few drivers. Sometimes a repair install will do the trick, but there's no way to know until you complete the upgrade.
I absolutely agree with your idea to clone your boot partition to another drive if possible, then use the cloned drive to test the move to the new MB and see what hurdles you encounter.
Best suggestion is exact model replacement of the MB in question. Check Pricewatch.com
Ms-7280 no usb works so i can not use the keyboard
Be sure the drivers were installed, and no other conflicts on the device manager. Since USB ports are controlled by the Southbridge chipset the problem could be the chipset.
Aug 08, 2014 | MSI Computers & Internet
My southbridge chipest gets very hot
this is normally a sign of either a power supply failure or a faulty component, it's more likely the southbridge failing, I had this issue with my ex-server, so I got a laptop heat pipe and some thermal compound, strapped the part to the southbridge and modified the fan so it ran constantly, and this sorted the problem long enough that I only had to retire the server in late 2012 after 9 years of rather intensive service, but the easiest way to resolve this is to get another board, I reccommend Asrock, Asus, the later MSI boards, and some mainstream boards, the best boad I've had was a Crosshair Formula 5, but they're expensive, for value, Asus and Gigabyte.
Feb 24, 2013 | MSI Computers & Internet
Hello I have a P6NGM motherboard which is reboot after a few second during start. I tried to remove RAM,HD and DVD but still the same.I also remove 12 volts and retain the ATX supply and It won't...
Hello from here you can download a manual:
http://www.msi.com/product/mb/P6NGM-FD.html#/?div=Driver&os=XP%2032
Try to reset the bios to factory settings
Also try to remove the cpu fan and add new cooling paste
But it could also be a harddrive failure
Are there any drivers missing (chipset) ??
Good luck
Dec 10, 2010 | MSI P6NGM-FD Core 2 Quad Socket 775...
MSI mobo with INTEL chipset won't recognize ATI card
well i know the problem so well, driver installs fine and when system runs it wont load the driver.. i had the same problem and the solution is so easy, just update the BIOS for ur mobo. and after new BIOS when system boots u will be surprised
Dec 25, 2009 | Computers & Internet
My MSI P6NGM-based system stopped working. On
Parity is a memory ( Ram problem ) try removing 1 Stick. or changing it into another slot. if you suspect Bios. remove power cable. locate The CMOS Battery. remove for 10-15 seconds, And replace it. this will reset the bios to it,s default settings. you,ll know if your asked on boot-up to run setup to change time/date.
Mike @ Compurepair.
Sep 05, 2009 | MSI Computers & Internet
My Motherboard fails todetect my WD 320oAAKS SAta Drive. I'm Forced to open the system case and hold the data cable until th computer boots up The Motherboard is a P6ngm from MSI.
If holding the cable allows it to detect the drive I would have to say you are getting a bad connection.
Try plugging into another sata connection on the motherboard, if that does not work try another cable, if that does not work it only leaves the hard drive. If it is still under warranty you can try to return it to the manufacturer for repair but be sure to back up all your data because there is an excellent chance they will just send you back a refurbished drive.
Oct 11, 2008 | MSI Computers & Internet
Unknown device
Hello the homepage is here:
if it does not help to upgrade the drivers
Disable it in the device manager
It also depends how new your current windows is
This failure comes often when you upgrade your bios
and running a old windows.
Good luck
Sep 06, 2008 | MSI P6NGM-FD Core 2 Quad Socket 775...
Cant get any display through xpert vision 8800gt with msi p6ngm
is the fan on your video card working and is the heat sink for it clean this could be an overheating problem
Aug 07, 2008 | MSI P6NGM-FD Core 2 Quad Socket 775...
Toshiba Satellite 5005-S504 3 USB Ports not functioning
I don't think a wire is the problem as they are soldered to mobo. It is more than likely a power problem. If you go to the hardware tab in device manager and go down to usb root hub>right click and properties then look at the power tab and you will see a 500MA allowance on usage. You can easily go above these if you are using them, so check that they are all active. Also go to control panel>admin tools>services and look down list for 'plug n play' and make sure it is set at automatic and 'universal plug and play' is set at manual
Jan 29, 2007 | Toshiba Satellite 5005-S504 Notebook
MSI K7N2GM2-LSR Motherboard Logo
99 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
