Question about Lands Phones
I'm on Orange with a Samsung E250. Recently, I bought a 4GB microSD memory chip and inserted it into the expansion slot at the side of the phone. The phone recognized that a memory chip had been inserted by showing a logo to that effect on the opening screen. However, when I try to access the extra memory, I either get "Not allowed" or 0MB available. I tried formatting the chip with my computer using FAT32 without effect. Files can be loaded on to the chip from the computer, so it works as a memory, but the phone will not recognize the space it should be providing.
  • 2 more comments
  • Dave Jones Feb 10, 2009
    It was suggested that the memory chip is not compatible with the phone. However, the memory chip was sold as "E250 Accessory", so I assume that it should be compatible.
    Suggested to format card in "Phone settings" Tried that and there is no "format" option offered. The only reference to memory is "shared memory" not the memory card.
    Suggestion that 4GB is too large for my phone. This may be true as I have been unable to find a definitive maximum memory size in the phone specifications. However (1) There is a comment in the phone specifications that by use of a memory card "the capacity of the phone can be expanded "virtually as far as you wish" I took this to mean that if you can purchase a chip, the phone will accept it; and (2) the memory adverts offer chips compatible with the E250, up to 8GB, again suggesting that 4GB should be acceptable. They even give how many minutes of video are possible with each size of chip up to 8GB.
  • Priya darshan May 11, 2010
    HI,
    Try this:
    1. Switch the mobile off. 2. Remove the card. 3. Switch the phone back
    on without the memory card in. 4. Insert the memory card when the phone
    is fully booted. BEFORE the phone has a chance to say "memory card
    inserted" press the button to take a picture. A message appears "memory
    card inserted..do you wish to continue?"..say "yes" and take the
    picture. You can then delete the picture and the mobile should
    recognise the memory card (until the next time you switch the phone
    off, then you have to do this again)
    Master:
  • 416 Answers
It can be several issues:
1, Card is not compartible with phone. Technical infor says that 2gb cards are recommended
2. Card is faulty damaged
3. SD card slot is fault
Good Luck
Posted on Feb 10, 2009
  • Grigory Zyryanov Feb 10, 2009
    Just check 2GB card.
    If it not working too there is hardware or software problem insude the phone
    Good Luck
  • 728 Answers
Your memory card is too big for phone which is causing it not to read it. From my readings, your phone can support memory cards only up to 1gb of memory. That is as much that can be read from the expansion slot on your phone.
    Scholar:
  • 61 Answers
If you have tried to format the 4GB card in the computer, and still getting an error, "Not allowed" etc..
I did some research and found that this particular model of phone can only handle up to 1GB memory card. Try with another memory card, format it in the phone. You'll be golden!
If you are trying to save pictures or other multimedia, check with your mobile service provider see if they have a plan you can store your pictures on a web site. Instead of on your phone.
    President:
  • 2,110 Answers
Bcoz your mobile don't support 4 GB so try 2 GB card..
  • 153 Answers
Actually the supports only 1gb memory
when u use 4gb the phone wil be not recognising tat space uso u better replace the card to 1gb tats the good idea ur mobile is fine
and the card is also fine the problem is the memory is too high for tat mobile to support
    Sergeant:
    Champion:
  • 289 Answers
Hi..try to reset your phone once.u have formatted
your chip and it has no virus but at the same time
u have to check that your phone is free from viruses.
In your case viruses are there in your phone.so scan
your phone using the data cable and then insert your
memory chip onto it.
check this out..
thank u..
  • Hariharanath V Feb 10, 2009
    hi..no u should get the one which is exactly
    compatible to it,replace it immediately and
    get the correct one which supports it.
    thanks..
    hi..the best solution to your problem is by
    replacing the card.Get the card which has
    the compatibility to your phone.
    thanks..
  • 19,396 Answers
You need to format the card using the command on phone settings menu.
  • Ginko
    Ginko Feb 10, 2009
    The truth is that this phone does not take over 2GB memory card, that is the maximum size allowed, read website below:
    Cellular Phones: Micro SD card?, 2gb sd card, samsung e250
    The problem is common to many users, this phone does not take over 2GB.
    Do not forget to leave us feedback on this problem.
    Thanks.
    Genius:
  • 1,913 Answers
I think your momory card chip is not supported by your phone.
Installing additional memory into my Jitterbug smartphone--How do I do it?
Per the Jitterbug Smartphone manual, on page 124:
https://www.greatcall.com/docs/default-source/pdfs/jitterbug-smart-user-guide.pdf
Adding more Memory Your Jitterbug features a microSD expansion slot to add up to an additional 32 GB of memory. The following is how to add more memory:
1. Remove the Back Cover using the Back Cover Release notch found on the bottom corner.
2. Locate the microSD expansion slot, which is below the External Speaker, and carefully insert the microSD card into the expansion slot until it clicks into place.
3. Replace the Back Cover.
IMPORTANT! Do not remove the SIM Card located opposite of the microSD expansion slot. Tampering of the SIM Card may cause issues with connectivity to the GreatCall network.
May 19, 2017 | Cell Phones
Sandisk micro memory chip not working in my lg620g cell phone
The LG620g works with microSD cards. Your 4GB card is actually a microSDHC card. While it fits into the slot, it's electronically incompatible and will not work in this phone. You need to use microSD cards, 2GB and smaller.
Nov 30, 2012 | SanDisk 8gb Micro Sd Memory Card Class4...
Cannot transfer videos from pc directly to external memory, samsung star
To transfer pictures (via a memory card) to a PC requires a microSD Memory Card, Memory Card Adaptor & Memory Card Reader. The microSD memory card MUST first be formatted, by the phone, in order for the phone to create the destination folders. Please note that the minimum size limit for the microSD memory card is 32MB.
This phone will support the use of a microSDHC 16GB capacity memory card. However, for optimal performance Samsung recommends using a card no larger than 2GB.
To learn how to format the microSD memory card, using the phone,The plug-in microSD memory card and its contents can be easily damaged by scratches or bending. Use caution when inserting or removing the card and keep all memory cards out of reach of children.
Warning: Formatting a memory card will permanently delete all current content.
To format a microSD memory card follow the steps below:
  1. Insert a microSD memory card into the memory card slot, located under the battery cover
  2. From the standby screen, press Menu
  3. Press Settings
  4. Scroll down then press Memory Management
  5. Press Memory Card Details
  6. Press Format
  7. Press Yes to confirm formatting the microSD Memory Card
Caution!: Do not repeatedly format a Memory Card as this shortens it's service lifeWARNING: Formatting the microSD Memory Card will permanently erase all data
To transfer pictures (via a memory card), from the phone, to a PC follow the steps below:
  1. Insert the formatted microSD memory card into the memory card slot, located under the battery cover
    1. When correctly inserted, the memory card icon microsd2.gif is displayed
      1. From the standby screen, press Menu
      2. Press My Stuff
      3. Press Pictures or Videos to view the contents
      4. Press Manage
      5. Press either Move or Copy
      6. Press each image to check their box or press All to check All boxes
      7. Press either Move or Copy
      8. Press Memory Card
      9. Press either Pictures or Videos
      10. Press Paste Here to Move or Copy the Photo(s)/Video(s) to the microSD memory card
      11. Remove the microSD memory card from the memory card slot
      12. Insert the microSD memory card into the memory card adaptor
      13. Insert the memory card adaptor into the memory card reader
      14. Insert the memory card reader into the USB slot on the PC
      15. Navigate to the desired Photo/Video destination location, using Windows Explorer, then paste the Photo(s)/Video(s) into the destination on the PC
Regards.
Jun 18, 2011 | Samsung Star GT-S5233 Cell Phone
Can I use a 4GB micro SD memory card on my Samsung SGH E250 cellphone?
Yes. Open your memory slot on the left side of your phone, near the bottom. Make sure you remove any memory that might be inserted already. Slide your card into the slot label side up.
Mar 14, 2011 | Cell Phones
A 4 GIG MEMORY DOESNT WORK IN ,MY E250
The Sansa e250 uses microSD cards. Your 4GB memory card is actually a microSDHC card. While it fits into the slot, it is electronically incompatible. You need to use microSD cards, 2GB and smaller.
Jan 29, 2011 | SanDisk Sansa e250 MP3 Player
I have a Samsung Intensity cell phone. I bought a
The Intensity has a slot for a MicroSD card -- is that the kind of removable memory you bought? (Anything bigger won't fit.)
Turn your phone off, and then pry off the back cover by using the little slot at the top of the phone (near the camera). There's a little groove where you can slip your finger in and pop the back cover off.
When the cover is off and you're looking at the phone's battery, the MicroSD slot is to the left, just above the camera button on the side of the phone. Stick the memory card in the slot (it should only fit in one way) and then reattach the back cover and turn the phone on.
Jun 08, 2010 | Samsung SCH-U450 Cell Phone
My computer nor samsung alias wont read my 4gb pny microsd chard
I doubt that your phone accepts the 4GB version of the micro sd card, try the 2GB
Feb 22, 2009 | PNY 4GB microSD High Capacity Mobile Media...
My samsung E250 mobile will not accept my memory card
You should check your manual most probably your phone cannot work with SDHC micro SD card. The only thing you can do is buy a 2GB micro sd card.
Jan 08, 2009 | SanDisk 4GB microSD High Capacity Memory...
MicroSD memory chip
You need some form of memory card reader to interface with your computer. If you do not have a slot for it on your PC, you can purchase one for relatively cheap from any major computer retailer. Or, anyone who sells memory cards for that matter. Ensure it supports microSD (according to the photo and topic headline)
Jan 03, 2009 | SanDisk 2GB microSD Memory Card
I have a Samsung R500. Also I have a MicroSD how do I put the MicroSD into the slot?
hi,
Holding by the edges, insert memory card into digital device slot(the edge with a slight cut must be on right side when you insert the card into mobile).. Do not apply pressure to the center of the card.Please note that Memory card can only be inserted one way..thank you!!..
Jul 01, 2008 | Samsung Cell Phones
Lands Phones Logo
27 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
