Question about Lexmark X1240 All-In-One InkJet Printer
Blue Print with Lines
When I print from the internet the print is very small and is blue, with blue lines all thru the document. It is not ledgable. I have put a new black toner cartridge, what is wrong with my printer?
    Sergeant:
  • 287 Answers
YOU NEED TO CLEAN IT. YOU CAN USE Q-TIPS AND RUBBING ALCOHOL TO CLEAN THE INSIDE. REMOVE CARTRAGES WHEN YOU CLEAN IT AND CLEAN THROUGHLY. THIS SHOULD DO THE TRICK.
Posted on Feb 10, 2009
Why blue lines when document printing?
You need to do a head clean you should be able to find this in maintenance section of the printer program.
They get a little dry spots or dirt on the cartridge.
This is a ink eater so uses a heap of ink could take 2-3 head cleans to clean it.
Regards Craig
Feb 11, 2018 | Office Equipment & Supplies
Bizhub c200 printing with streaks of red and blue lines what to do
If that lines are consistent with the red and blue and it does not appear during black and white print that means the cleaning blade in the affected color units need to be replaced
May 16, 2014 | Konica Minolta bizhub 250 All-In-One Laser...
Why is there a black line on all documents that i print?
The 2 most common causes for lines on this machine areA) Dirty **** Glass ( This would only affect copies not internal or computer printed jobs)B) Worn Drum Unit
First make a copy off the large glass and see if you get a line still, if not try running it through the document feeder. If the line is present through the feeder but not off the large glass. Clean the small strip of glass to the left of the large copy glass and this should resolve the line.
If lines show up regardless of how or what you print/copy open the left door of the machine and you should see in the lower area a handle with a blue sticker on it. By grabbing both the front and rear handle of the unit remove it by pulling straight out and lifting slightly. If this blue/green cylinder has any tan colored lines or marks on it then the drum is worn and needs replaced.
Mar 15, 2012 | Canon imageRUNNER 1023iF Black and White...
Red and blue lines across printouts
open printing preferences and click on maintenance. Run the print head alignment utility. Sometimes this will remove the horizontal banding. I had this same problem and had to uninstall the printer and reinstall just like it was new, running the alignment feature before it was corrected. Worked ok for a few days then started again. I assumed that the printhead is bad. To costly to repair and bought a new printer.
Jun 27, 2009 | Epson Office Equipment & Supplies
I have horizontal white lines (non print lines)
Slide the small blue tab on the toner cartridge side to side 10 times.
Jan 22, 2009 | Brother MFC 8500 All-In-One Laser Printer
Hp 5550dn ( I am getting a 49.2fcc and 49.4b1a error
Upgrade firmware on the printer as a first step, 49 errors are often an issue with firmware
Nov 12, 2008 | HP LaserJet 5550DN Printer
Lexmark x5470 printer printing blue horizontal lines on coloured documents
hi
try to perform maintenance of your printer
on the setting
and open your printer clean up the nozzle
use alcohol and cotton buds and then placed it back properly!!
Nov 10, 2008 | Lexmark X5470 All-In-One InkJet Printer
Hi ,My Hp5000 printer started out of the blue printing continuous lines down the left margin .Sometimes its seven lines & now 2 to 3 lines.How can I stop this & what caused it ? I'm needing to...
Hi Barry,
Thanks for the posting in FixYa.
If only the blue color is not shown after printing may be the Color Catridge having problem or may be getting empty.
Try after inserting a new Catridge. Otherwise clean the roller of the printer may be they get struck with the ink.
Regards
ELLIN
Sep 17, 2008 | HP Office Equipment & Supplies
Lexmark X1240 All-In-One InkJet Printer Logo
160 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
