Question about Compaq Presario C700T Notebook
Touchpad cumputer is six months old and the colour on the touchpad has worn any solutions Touchpad surface worn after 3 months of use. although it works ok, it sticks with the finger and gets badly marked. the touchpads on acer notebooks are so much much better.
  • la_show_em Apr 03, 2009
    Surface of my touchpad left mouse button is scrapped (by my fingernail?). I'd like to touch up the surface, but don't know what to use.
Get this:
http://www.notebookreview.com/default.asp?newsID=3496
Posted on May 05, 2009
  • 38 Answers
You could clean it.
Personally I plug a USB Mouse, Cos I cannot be Bothered with a lot of wasted energy in using a touchpad. Far faster with a mouse. The other answer is Statutery rights.
Posted on Feb 10, 2009
Microwave oven touch pad problem
The keypad very well could be worn from use and be working intermittently. Replacing the keypad (and the keypad face if it is a separate piece) is the most logical solution.
Aug 22, 2012 | GE Microwave Ovens
My aspire D255E netbook is only about 2 months old, the mouse pointer moves, but i am not able to select anything using the touchpad or the touchpad buttons. I was wondering if there was a solution for...
Check if the drivers for the touchpad is installed. Usually you can find an icon at the system tray for your touchpad. Check device manager if there is a problem under mouse and other pointing devices. You can also try double clicking the device under that category and try to roll back the driver if possible. If it still does not work, try running a hardware diagnostics on the touchpad. It could be a hardware problem.
May 12, 2011 | Computers & Internet
My laptop is only a few months old, and the touchpad randomly stopped working....what can i do?
If you have already tried another mouse and works fine in Windows OS then the problem gets narrowed down to the touchpad being faulty and would have to replace it but don't discard the touchpad could be accidently disabled in the control panel of the mouse properties. Dell laptops usually have a driver chipset and driver for the mouse touchpad specifically which you can get on support.dell.com
try reinstalling before getting new touchpad part for your laptop. Dell has spareparts where you can buy a refurb one and install yourself. Instructions on how to take apart your laptop is on the same site.
Dec 22, 2010 | Dell F3534 Touchpad
Acer laptop Aspire 5732Z touchpad not working...have been using mouse all along and touchpad was working now it isnt...did the fn f7 no help...checked the device manager all seems fine...tried to update...
I have the solution...
u see where the switch on button is ? next to it there are two buttons ...ones for stopping internet connection ...thats the one on the right. the one on the left is the one for locking the touchpad
if that button has a orange light blinking on it it means its locked ..
so just push the button and see if it works :) .
Jul 19, 2010 | Acer Aspire 5500 5570-2609 Laptop
My jenn-air electric range is about 18 years old. sometimes for no reason f1 and beeping occured but pushing cancel stopped it until next time.about 9 months ago when beeping wouldn't stop and touchpad...
Here is some wisdom for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Here's a simple explanation of what's going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode.
This is equivalent to 350°F in the oven.
The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms.
The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness,
harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad.
If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously.
If the F1 code is given immediately (instead of during or after a heat cycle),
remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes,
then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner.
The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied,
the surface material can break down causing shorts.
If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
-don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
%$#E
Mar 04, 2010 | Jenn-Air JES9750AAS Electric Kitchen Range
Advent 5401 left touchpad button broken
Had a similar problem a couple of months ago, The left button started playing up, not working with every mouse click, it gradualy got worse till it was nearly unusable.. I suspected that the microswitch under the silver button had some dirt in it. After taking a deep breath I removed the battery and the screws that hold the case lower and upper halves together and was able to seperate the case front by about 3/4 of an inch. Then using a contact cleaner Servisol Super 10 and supplied flexible straw I squirted cleaner into both mouse click buttons. After waiting for cleaner to evaporate and resecuring case halves and replacing battery I switched on .... The button works 100%..
Feb 02, 2010 | Advent Netbook
Touchpad is jerky, not smooth like it used to be.
Try touching the case of the A/C adapter to a metal part on the computer casing.
If the condition improves, you have a grounding issue with the power adapter.
Jan 06, 2010 | Dell F3534 Touchpad
F1 code
Mar 21, 2009 | Amana ACF4225AS Electric Kitchen Range
Kenmore oven model # C970-555331
Jan 18, 2008 | Kenmore 47834 / 47832 / 47839 Electric...
Touchpad
the only solution i can think of if you're not wanting to spend big money on it is to hook a wireless mouse to your system. I use both keyboard and mouse on my laptop as i kept touch that touchpad when i was typing. I do hope this does help you out.
Jan 12, 2008 | Computers & Internet
Compaq Presario C700T Notebook Logo
87 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
