Question about Acer Aspire 4315 Notebook
Automatic shutdown, crashing applications & no startup repair
My pc automatically shutdown, on its own and the start up repair is already failing. Does this require a reformat or reset it to factory setting. I hope you can assist me on this. Thank you.
I have lg laptop,always shut down while playing games or scanning for virus , a suddenly shut down , have a window vista home preium installed os and ram 2gb and hdd 180. can pls help.....
Posted on Jun 01, 2010
  • 741 Answers
Yes, sounds like some of you applications may have become corrupted. It happens over time. Find the backup program if XP >start>accessories>system tools>backup on Vista just type "backup" in the start box. You will see and option to back up all of your docs., email, web favorites, etc. Back them up then use the Windows disc reload the operating system You will also, have to reload your applications. That will take care of it. Good luck and let me know if you have any questions. Don't forget to rate this solution with 4 stars before you log out.
Posted on Feb 10, 2009
Error code 0x0000034
Try this
Press f12 then advanced options, then Automatic repair or other options listed below:
From page 115 of your user manual-
Advanced options
Choosing this option presents you with another set of
options:
System Restore
? System Restore allows you to use a Restore point to
return the computer to a state at which it was performing
properly. Restore points are created:
? When new hardware or software is installed
? Manually by the user
System Image Recovery
Windows® will "Recover" the Operating system using a
specific image provided by the user.
116 If Something Goes Wrong
The Windows® operating system is not working
Automatic Repair
This feature automates the repair process. The Operating
System will automatically look for problems and repair them
if possible.
Command Prompt
The command prompt is a very powerful tool for advanced
users.
Startup Settings
In previous Operating Systems the majority of the options
found on this menu were available by pressing the F8 key
during the Windows® boot process:
? Enable low resolution video mode
Restarts Windows® using your current video driver at low
resolution. This allows you to reset your display settings
in the event they have been improperly set.
? Enable debugging mode
Starts Windows® in an advanced troubleshooting mode
? Enable boot logging
Creates a file that lists all the drivers that are installed
during startup
? Enable Safe Mode
Starts Windows® with a minimal set of drivers and
services. If the computer starts and runs in Safe Mode,
you will know the Operating System is most likely
working properly and that you should look to third-party
applications or drivers for the source of your problem.
? Disable driver signature enforcement
Allows drivers containing improper signatures to be
installed
? Disable early-launch anti-malware protection
Allows drivers to initialize without being measured by the
Anti-malware driver
? Disable automatic restart on system failure
Prevents Windows® from automatically restarting if an
error causes it to fail. Choose this option only if
Windows® is stuck in a loop where it fails, attempts to
restart, and fails again repeatedly.
SOLVED Recovery Your new PC needs to be repaired Boot configuration error...
Feb 15, 2015 | Toshiba Satellite C55T-A5123 Celeron N2820...
Primavera softawre not login
Problems: App Crash Problems usually happens when the computer overloads with to much data, or when certain system files become missing or broken. This is a critical sign of an unstable system that is typically caused by improper maintenance of the computer. dialog_warning.png Symptoms:App Crash Problems symptoms can include program lock-ups, slow PC performance, system freezes, blue screen, shutdown or startup problems, and installation errors.
Recommendation: To scan, diagnose and repair your computer, use the Free Download Advanced System Care from iobit.com
Nov 20, 2013 | Computers & Internet
Disable auto shutdown
Restart the Computer and keep tapping the F8 key till you see the advance boot options, You should be tapping the key as soon as you see the manufactures screen. Once you get the advance boot options -> Select the option which says Disable Automatic Startup on System Failure.
Good Luck!!!
May 16, 2013 | Toshiba Satellite Computers & Internet
Message on screen: Windows failed to start. A recent hardware... It then cuts to startup repair and attempting repairs. Have gone through this a dozen times only to end up where I started. What do I...
I assume you've already tried pressing F8 on startup to get into the start-up options screen (from there you can attempt "Restore System to a previous date.").
If you can't get anywhere with the F8 options, try starting up your system from a Windows Install disk. (Unfortunately, few computers come with this. Some have a Restore mode using either a special startup hot key or a set of optical disks, but this usually involves formatting C: and wiping out everything before setting it back to factory original state.) Once you have the Windows Install disk going, watch for the Automatic System Repair option to come up. This is different for each version of Windows, so I can't give you more than that other than to follow the on-screen instructions.
Note: virus infections can disrupt the hardware registry and produce the symptoms you have. By now, your backup registry is corrupted (that is why the automatic repair fails). I've found the easiest virus fix for a desktop computer is to remove the hard drive and install it as a second drive in a known-good computer, then have that system scan the problem drive for virus infections and file system corruption. If you have a 2.5" - 3.5" drive adapter and can remove the drive easily, you can also use this tactic on laptop hard drives. You will probably still need to repair the operating system damage.
Nov 14, 2011 | Computers & Internet
I having a promblem trying to load o/s,it start well to load but after just a moment before it coping files it gives me an error 1773
Error 1773 error symptoms can include slow PC performance, program crashes, system freezes, startup/shutdown problems, and file errors. Risks that can result from not repairing your computer include blue screens, file corruption, and hardware failure.
Fixing Error 1773 is easy. Download and install PC Health Advisor, a Microsoft Windows tool that will analyze your registry for missing, obsolete, and corrupt entries resulting from failed installations, incomplete un-installations, disabled drivers, and spyware applications.
Nov 09, 2010 | Computers & Internet
I have a compaq presario laptop with windows vista, 2 weeks ago it was working fine and now it loads up fine but crashes everytime i try something, what can i do appart from wiping off and starting again
Hi. I think the best to resolve this issue is to restore again your system to its factory settings or reformat again your system, then after doing it you should disable the automatic updates from the control panel so that you're system would not automatically update itself, because most of the time Vista crashes because the updates it made and sometimes you tend to shutdown your system without finishing the updates from microsoft then it would cause that crash the next time you open up your system. To disable the automatic updates just go to control then click classic view on the upper left side then look for the Windows Update icon on the control panel, and from ther just turn off the automatic updates. I would also suggest that if you to maintain the automatic update you should make sure that the updates are already finish before you shutdown your computer or you could change the schedule of the updates depends on what date have you chosen. Hope This Helps
Jun 03, 2010 | Compaq Presario 700 470024-192 Notebook
Pc keepestarting after normal shutdown
Try to deselect - automatic restart by doing the following:
start/right click - my computer/properties/
advanced - tab/
startup and recovery- section/settings/
system failure - section/
deselect - automatically restart/if already on/
click ok/
click apply/
Let me know if this helps.
Jan 30, 2010 | Microsoft Computers & Internet
Keep getting error 7191 can't download
Error-7191 error symptoms can include slow PC performance, program crashes, system freezes, startup/shutdown problems, and file errors. Risks that can result from not repairing your computer include blue screens, file corruption, and hardware failure.
Fixing Error-7191 is easy. Download and install Regcure, a Microsoft Windows tool that will analyze your registry for missing, obsolete, and corrupt entries resulting from failed installations, incomplete un-installations, disabled drivers, and spyware applications. Click on the link below for your free download.
If you do not like Regcure / You can find another registry cleaner or backup and format and reinstall the OS.
Email me for you have questions @ support@rdptechs.net
Dec 14, 2009 | Microsoft Windows Vista Ultimate Edition
When power cable is plugged in, If i try to shutdown my laptop it shutdowns and starts automatically
access the system bios at startup and change the automatic restart after a power outage option
Dec 30, 2008 | HP Compaq Business nc8000 Notebook
Acer Aspire 4315 Notebook Logo
122 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
