Question about BenQ FP731 - 17" LCD Monitor
BenQ flat screen computer monitor is blurred
Hello, I have my BenQ 17inch computer screen monitor is blurred, pls help me to fix this!!!
  • Randall  Trahan
    Randall Trahan May 11, 2010
    You have to set the resolution to what is called native resolution. For XP: Right-click anywhere on your desktop the Display properties box willl come up. On one of the tabs will have screen resolution. Make sure the slider is all the way to the right. Then click apply and ok. If you are using Vista, let me know what version, Home Edition, Ultimate, etc. It is a different setting
5 Suggested Answers
viziks
  • 220 Answers
SOURCE: Can repairs be made to BenQ FP731 17 inch Flat Screen.
The power and Inverter board has a problem.Check Inverter transistors and the related fuse.
Posted on Feb 16, 2008
viziks
  • 220 Answers
SOURCE: benQ fp737 monitor
Disconnect the signal cable from CPU and power on.You should get a BenQ Blue screen.
If no Display,Problem is definitely monitor related ie monitor has a hardware defect most probably the power/invertor board has a few blown components.
If you are technically able,you can dismantle monitor and check components on the Invertor board which you may find on my other posts.
Please reply if you need more help.Please rate this solution.
Thanks.
Samir
Posted on Aug 25, 2008
jubag14
  • 89 Answers
SOURCE: white screen on monitor
o cant suggest anything appart from buying a new one sorry.
please rate my help to you.
thank you
Posted on Apr 22, 2009
  • 98 Answers
SOURCE: Dell 17inch flat screen monitor will not remain on, the screen go
If your Dell monitor still under into warranty, better to call Dell technical support and have them replace your monitor coz there is no way you can fix on it.
If the monitor is beyond with the warranty already, better to but a new one than taking it repair that will cost you much.
Thank you.
Posted on Oct 06, 2009
SOURCE: benq computer monitor shuts down after standby in energy saving..
There are 6 (reduced quality) capacitors in the BenQ Q9W5 which cause the screen over time to 'fail to sync' when turning on or resuming from standby.
They are;
4x 470uF 35v, and
2x 1000uF 16v.
I recommend the following replacements if you are in Australia (the ones I purchased from Jaycar only lasted 12 months);
(470uF) http://www.altronics.com.au/index.asp?area=item&id=R4865
(1000uF) http://www.altronics.com.au/index.asp?area=item&id=R5182
Posted on Aug 05, 2010
Screen is blurred
Hello there,
there are many Steps we are going to have to do to get this monitor working correctly.
Step 1: Reset the computer
Step 2: check all connections on the Monitor and computer
Step 3: update the graphics Card Driver
if the screen is still blurred let me know and we keep going thank you and don't forget to Rate
also if you need any help with more information on a step let me know
Jan 25, 2011 | Gateway 19" Widescreen Flat Panel TFT LCD...
Hi sir iam surendra, present im using benq lcd moniter & since few days im facng display prblem, when i turn on my system, some lines are comming & causing visual problem.so iam nt able to see my...
The picture board on your monitor is bad, since the lines are causing visual display, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself. in other not to complicate issues.
Nov 26, 2010 | BenQ FP71G 17" LCD Monitor
MY LCD IS DOING RANDOM BLUR WHATS WRONG WITH THIS? HELP PLS.
usually, there are bloated capacitors on the circuit boards, or loose board solder, this random blur may be the cause of failing lcd panel too..
Oct 14, 2010 | LG Flatron 563LS (White) 15.1 in. Flat...
Thank you.
Oct 06, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
White screen on monitor
thank you
Apr 22, 2009 | Dell E173FP 17" LCD Monitor
BenQ 17inc LCD Monitor
change c5707 transistors ...all 4 of them plus fuse
Feb 10, 2009 | BenQ FP731 - 17" LCD Monitor
BenQ, power is on, screen is almost black, just very dark
You can not fix this problem from the panel buttons, the problem is something to do with the circuit board. Its the inverter cicuit that has one or couple of components faulty. I susgest you bring it o the repair shop. cheers.
Nov 16, 2008 | BenQ FP731 17" LCD Monitor
BenQ fp737 monitor
Thanks.
Samir
Aug 25, 2008 | BenQ FP737S-D 17" LCD Monitor
BenQ FP7IB LCD monitor, turn black aftr BenQ logo
Try to plug into another computer and wait to see.
If it turn up to be same it somewhere defect from the main board of the lcd.
If if not the same turn up to be, you should reinstall the OS because the software is corrupted or your display card problem.
Apr 16, 2008 | MPC Computers AOC 7F 17" CRT Monitor
BenQ FP731 - 17" LCD Monitor Logo
306 people viewed this question
Top BenQ Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
Matthew Spark
Matthew Spark
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
