Question about RCA DIRECTV Satellite Remote Control
Bought a new 32" Flat screen. Can't get Direct TV remote to work . Some instructions say to use a 5 digit code but the only ones I can find are 3 digits and how do I program them in?
  • 57 Answers
Here are a list of five digit codes for your RCA Direct Tv Satellite Remote:
//2getdtv.com/directv/directv_receiver_codes.html
I am not certain which instructions you are referring to. I hope this solution is helpful.
Posted on Feb 13, 2009
Have RCA L32HD31R flat screen TV. Codes for DirecTV sat. service do not work for their remote. Do you have any additional codes for this TV?
Need 5 digit codes for Direct TV remote, not 3 digit. I have a RCA flat screen and tried all 16 codes as per instruction from online PDF manuel and none of them work for me either.
Jan 05, 2010 | RCA DIRECTV Satellite Remote Control
Bought LCD Emerson 19'' Flat screen, Manufactured May of 2008. I have tried all of the available codes to get the direct remote tocontrol the volume & turn TV on & off. Can you advise me.
if you have a universal remote control that you are trying to program . the newer ones have a 4 digit code .. the older ones have only a 3 digit code .. the ones with 3 digit codes often wont work with newer equipment ... the new type universal remotes cover a lot more types .. ... if you are trying to get the remote that came with the TV working .. then you can remove the batteries for 10 min .. when you put them back in it should default to original factory settings ..
Nov 29, 2009 | Emerson LC195EM9 19 in. LCD TV
I have a SOYO-DYLT032B...32in LCD and I need a main module...not hopeful based on research...any clues?
what is the code for soyo tv 32" lcd to activate my digital remote to use it for all functions instead of using two remotes one to turn off and on and the other to navigate.
Nov 07, 2009 | Soyo DYLT032D 32 in. LCD Television
Can't get universal remote or cable remote to work with my tv.
I need programming instructions for proscan universal remote control. I have code.
Feb 20, 2009 | Proscan 32LA25Q 32 in. LCD TV
Envision remote codes
Try
10813
11365
10032
10039
10019
Feb 18, 2008 | iLO 3200 32 in. LCD Television
Need remote control code for 32" X2GEN tv
Good luck. I have the same issue. No codes are available for the X2Gen. To make matters worse, it appears to use a non-standard frequency for the carrier signal, maening that other remotes won't work with the TV.
I purchased a learning remote, thinking I would just "teach" it the codes directly from the X2Gen TV remote. This didn't work either.
There appears to be no way to use any remote other than the one supplied with the TV. Whatever you do, don't lose it!
Jan 24, 2008 | Televison & Video
Direct TV remote, need code for Westinghouse Flat Screen 32" itsdon458@yahoo.com
Try these codes listed for Sony.  10080 11100 10111
 One of these should work.
Jan 06, 2008 | Westinghouse 16093 Remote Control
Reomte code
gital lifestyles tv will work with LG codes 11423 for Direct Tv with this you can control volume, to control power put remote in tv mode
Dec 23, 2007 | Digital Lifestyle FA1B32Z 32 in. LCD...
Remote code
Use the search function, but don't give up. It takes about 20 minutes to find the correct code.
Here are the instructions
  • Set the "Mode Switch" to the desired mode such as TV for a Television.
  • Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
  • Enter the code "991" followed by the "device number"
    1. for Televisions
    2. for "AUX 1" devices - VCRs or DVDs
    3. for "AUX 2" devices - Audio
  • You can step through the setup codes for this mode by pressing the "Channel Up" key to go forward through the codes or pressing the "Channel Down" key to go back to the previous codes.
  • You can try out each code by pressing one or more function keys such as power, volume or digit keys.
  • When you've found the setup code that works for your device, press the "Select" key.
Sep 12, 2007 | Televison & Video
RCA DIRECTV Satellite Remote Control Logo
330 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
