Question about Roper RAX4233PQ Top Load Washer
Cold water wont quit runnin after machine fills up
I have a roper washer and the cold water will not stop running after the machine is full you have to turn it off on the wall i was just wondeirng what would be a possible simple way of fixing this thanks
  • SSRS May 06, 2009
    I have the same much is it to replace? can i do it myself? how long does it take to fix?
  • 135 Answers
You'll have to replace the water inlet valve. Hope this helps!
Posted on Feb 10, 2009
  • Grady Bledsoe Jun 05, 2011
    how can you be sure it is not the level switch?
My Roper heavy duty 8 cycle 2 speed combination washer does not fill up on rinse cycle
when in rinse washers use just cold water so clothes don't wrinkle,try this,set the washer to just cold,start it and see if it fills or fills slowly if so you have a bad water valve on washer or no cold water going to washer.
Dec 04, 2017 | Roper Washing Machines
Washer filling problem
Check to hose to the water level control. It goes from the outside of the tub up to the control which is located in the same area as the timer. It's usually round with the end of that tube and at least 2 wires connected to it. Disconnect the hose and blow air through it. Reconnect and try again. Still no fill, try filling with that tube disconnected. Watch it the entire time as with the tube off the water should not stop. If it fills all the way with the tube off the water control unit has a problem.
Jan 07, 2014 | Roper Washing Machines
Roper washer model RAS8245EQ1 not working, buzzing noise
Her you'll find your answer..
Mar 08, 2013 | Roper Washing Machines
Roper washer stops at rinse circle
Turn off your water to the washer.
Remove the hoses from the valve at the rear of the washer and clean the trash out of the filter screen.
You have a cold fill rinse washer.
If it can't get water it stops advancing the timer.
Mar 08, 2009 | Whirlpool LSB6200KQ Top Load Washer
Washer won't stop filling
if you can turn the washer off while it is still filling. and the water continues to enter the machine you have a bad inlet valve.
Do me a favor turn the washer to fill, with the washer still running unplug from the wall. If the water is still entering the unit you have a bad inlet valve
Jan 05, 2009 | Roper RAS8445KQ Top Load Washer
Roper washer
I have the same damn issue with my Samsung washing machine(Top Loader) Not quite sure why it does it.Help please really annoying.
Jun 05, 2008 | Whirlpool LSB6200KQ Top Load Washer
Washer not filling
plz dont take this wrong but you say it fills and WONT STOP?? does the unit over flow on the floor?? or you need to let me know because the last part of your question states a diffrent the hot water valve on?//plz answer my questions and we can go on.
Feb 17, 2008 | Roper RAS8445KQ Top Load Washer
Washer leaks when running full loads
This could mean the fill level is not working properly and there is an overfill situation. Generally[I don't know 'Roper'] the fill level is controlled by a 'bottle' like device at the fixed to the outside of the drum at the bottom with, with a fine tube leading to a disk like thing near the top of the machine- with wire coming from it to the controller. The 'disk' thing is the pressure sensor. and the bottle thing is supposed to fill with water and the air pressure in the tube actuates the switch in the 'disk' Overtime the 'bottle' will get clogged with crud and need cleaning out. This will mean taking it off and giving it a good cleaning. Hope this helps.
Jul 07, 2007 | Roper RAS8445KQ Top Load Washer
Roper RAX4233PQ Top Load Washer Logo
91 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
