Question about Datamax M-4208 Thermal Label Printer
Datamax dmx-m-4208 give me position fault
Press MENU then enter(cancel) then FWD(feed) appear sensor type then press ENTER(cancel)
then choose continuous >>>
Posted on Feb 12, 2009
Errors= head cleaning fault. position fault
head cleaning fault, you need to remove the option for head cleaning.
The position fault may be due to either a wrong label size, wrong detecting sensor selection or your printer sensors needs callibaration
Aug 15, 2011 | Datamax M-CLASS DMX-M-4208 Label Printer
My printer DMX M-4208, can not print when i try to "Test Print" from the machine, could you help me to solve it
doni_s: After printing some labels, test print can not function properly. Reboot the printer and try the test print again.
Roberto Martinez
padrino99@prodigy.net.mx
Jul 28, 2011 | Datamax M-CLASS DMX-M-4208 Label Printer
We use the Datamax Printer to print labels with labelview. The printer itself however keeps saying :position fault" how do I fix that?
Position fault or Out of stock when the printer is loaded with paper stock can usually be solved by calibrating the printer.
Press & hold the FEED button. Let the printer cycle 8-10 times. Should feed to the right position and say Calibration Complete in the window.
Hope this solves your problem.
Jul 12, 2010 | Datamax DMX-I-4208 Label Printer
Position fault
Position Fault is common on Datamax printers with the LCD Display. Press "FEED" one time and this should clear it out. If not, "PRESS AND HOLD FEED" for about 5 seconds and release. This is called a Quick Calibration. Make sure the label sensor is in the correct position as well.
Jan 13, 2010 | Datamax DMX-I-4208 Label Printer
Where can I download a programmers manual for a DMX-I-4208
datamaxcorp.com should have what you are looking for if it's available.
Oct 31, 2009 | Datamax DMX-I-4208 Label Printer
Will not feed full length of label. display reads "ribbon fault" datamax i-4208
You may need to take out the whole ribbon assembly by removing 3 screws. The ribbon sensor looks like a L shaped clear plastic glass.
If still not working. buy the ribbon assembly.
Aug 12, 2009 | Datamax DMX-I-4208 Label Printer
Datamax dmx-i-4208 (ribbon fault)
Re-calibrate the printer. If still not working, take out the ribbon assembly by removing 3 screws and check the sensor ( "L" shaped plastic glass). If still not working, buy a new ribbon assembly.
May 15, 2009 | Datamax DMX-I-4208 Label Printer
Datamax i - 4208
If you use ms-access you must have installed the windows driver, therefore you must enable the cutter in the printer properties. Position fault is that it does not detect the label, must be press the FEED key or to calibrate, press the FEED key for 5 seconds to calibrate the sensor label.
Sep 01, 2008 | Datamax M-4208 Thermal Label Printer
Datamax M-4208 Thermal Label Printer Logo
1,609 people viewed this question
Top Datamax Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Starnley Johnwells
Starnley Johnwells
Joseph Mueller
Joseph Mueller
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
