Question about Denon ASD3W IPod Networking Dock Docking Station
Cannot connect to Internet
Just bought the Denon ASD-3W. When trying to set up the networking, after I choose the SSID and enter the WEP encryption key with DHCP ON, it says IP address unknown. I have verified that the encryption key is correct, also the SSID. Any solutions? Thanks!
  • rbrowland Apr 16, 2009
    Exact same problem
    Sergeant:
    Novelist:
  • 198 Answers
Set the "Mode" on the "Details" as "Infrastructure" if you are connecting to a wireless access point/router
SSID is case sensitive, ensure that you have it entered exactly the same as it is on router
On WEP Key, use the 10 Hexadecimal key (for 64-bit WEP) or 26 Hex if (128-bit WEP) that is set on the router (0-9 and A-F characters on Key 1. Key 1 is selected as the default network key on the router).
Also, ensure that the DHCP is enabled on the router so it will issue an IP address to your device.
Once everything is set, power cycle your devices to synch your wireless connection (power off the router and the device and turn them back on in that order).
Hope this helps.
Posted on Jun 24, 2009
How do you connecct the wireless printer to my wirelss router
  • On the printer,push the MENU button,push the up or down button to go to select network then press the OK button.
  • under network menu go to WLAN then press the OK button to confirm the selection.
  • under WLAN menu go to setup wizard then press the OK button
  • when Network I/F switched to wireless is displayed ,press OK to accept.the printer will search for available networks.
  • select your SSID or network name on the list it will display then press OK.If it only showed your SSID then just press OK.
  • Use the a,b and OK buttons to choose the one of the options below:
  • no authentication or encryption or password , select open system ,press OK then choose none for encryption type.press OK.
  • No Authentication with WEP Encryption:Choose Open System, then select and press WEP for the Encryption Type and press OK.
  • Authentication with WEP Encryption:Choose Shared Key and press OK.
  • Authentication with WPA/WPA2-PSK (TKIP or AES) Encryption:Choose WPA/WPA2-PSK and press OK
  • after selecting the correct option,press OK.Always remember,WEP or WPA keys are case-sensitive.You can use the ? and ? keys to move the cursor left and right. For example, to enter the letter a, press the 2 key on the dial pad once. To enter the number 3, press the 3 key on the dial pad seven times.The letters appear in this order: lower case,upper case and then number.
  • press OK after entering the password.
  • the printer will attempt to connect to the router.If it successful,it will display the word connected on the printer.
note: you need to know the encryption type and password type (wep or wpa) for the wireless setup to be successful.you can get the info you need from your router account page or GUI.
Jul 17, 2011 | Brother MFC 490cw Color Inkjet...
Have bought a new t v {panasonic viera} also bought a wireless LANadaptor to link up with my rooter for internet accessbut keeps asking for encryption key
Ken,
You need to use the same encryption key that you provided when you connect any other wireless device to your wireless network. If you have never set up any device to connect wirelessly, you should do so now. On page 12 & 13 of the manual, you'll find detailed instructions on how to set up and more importantly, secure your wireless network with a 64 or 128 bit WEP key. Once you have logged in and see the screen shown on the bottom of page 12, do NOT click on "Run Wizard". Instead, simply click the "Wireless" button. Make sure you make note of the SSID (or change the SSID) and enter a new WEP encryption key (do not leave the keys unchanged or blank!) before navigating away from this page. If you choose a 64 bit key, you can provide a 10 "string" consisting of digits 0 - 9 and a - f. I like to use a telephone number because they are the correct length and there are plenty I know "in my head" and never forget them. You can pick whatever you like. You might want to write this info on a piece of paper and tape to the router for easy reference later. You should not change any other values in the router's settings or you may not be able to connect to the internet.
If you have previously set up other devices to connect to the router wirelessly, you'll have to update them with the new WEP key and SSID (if you changed it).
Read page 30 of the manual to learn how to change the Username and Password from the default settings.
That's it. I hope this helps & good luck. Please rate my reply. Thank you.
Apr 05, 2011 | D-Link AirPlus DI-524 Wireless Router
HOW DO YOU GET ON LINE WITH A PSP
Step1 – Go to Settings and then select Network settings
Step2 – Select Infrastructure Mode and start a [New Connection]. By setting up in Infrastructure Mode, you will be able to take advantage of the more exciting features of the PSP, such as browsing the Internet and playing games online with your friends.
Step3 – Access the WLAN Settings and select scan to search for an SSID of nearby access points. If you find more than one access point, simply connect to the one with the strongest signal.
Step4 – Once an SSID is found, select it (make sure you don’t rename it) and move to the WLAN Security Settings. You should note that if the access point is using WEP encryption, you will need to enter the WEP key manually (when the access point is detected, it will display the type of encryption it is running. WEP key should be displayed on your router. If it displays none, simply move onto the next step.
Step5 – Now you have a couple of choices of either Easy or Custom in Address Settings menu. I suggest you selecting the Easy option which will complete the Infrastructure Mode set-up automatically.
Step6 – Choose your Connection Name and enter it. A Setting List will be displayed. Press x button to save settings.
Step7 – Test Connection to make sure everything works. If all is okay, Network Settings will display Connection Name, Signal Strength, SSID, BSSID, Channel, Security and IP Address.
In a nutshell there we are, 7 simple steps to connect your PSP to the internet using a wireless router to enable you to start surfing the internet, playing games online with friends, exchanging pictures and downloading your favourite RSS channels.
Mar 05, 2010 | Sony PlayStation Portable (PSP) Console
I can't get the internet for my psp
FOLLOW THESE 7 STEPS
Step4 – Once an SSID is found, select it (make sure you don’t rename it) and move to the WLAN Security Settings. You should note that if the access point is using WEP encryption, you will need to enter the WEP key manually (when the access point2_bing.gif is detected, it will display the type of encryption it is running. WEP key should be displayed on your router. If it displays none, simply move onto the next step.
Step7 – Test Connection to make sure everything works. If all is okay, Network Settings2_bing.gif will display Connection Name, Signal Strength, SSID, BSSID, Channel, Security and IP Address.
Nov 29, 2009 | Sony PlayStation Portable (PSP) Console
How do I get wifi on my psp
Nov 24, 2009 | Sony PSP (Piano Black)
I WANT OT PUT PASWORD TO MY WIRELESS BROADBAND ROUTER SO ONE CAN ONLY OPEN OUR COMPUTER AND SELECTED PEOPLE CAN ONLY USE THE WIRELESS CONNECTION.HOW CAN THIS BE?
Log into your router by opening your web browser software, for example Internet Explorer. Type in the address field the ip address of your router. The ip address depends on the manufacturer, but it should look something like this - 192.168.1.1 . A window should appear asking you for your user name and password. If the router is set to default settings, the user name should be ADMIN and the password should be ADMIN. Hit enter. This should bring you to your routers configuration window. lynksisssid_thumb.jpgSSID screen.Go to your wireless tab / basic wireless settings. Enter a SSID (wireless network name). The SSID may be on a sticker on the router or you could make one up. Choose a wireless channel. Disable your SSID wireless broadcast. Save or apply changes.
linksyswep_thumb.jpgWEP / WPA screen.Go to your wireless tab / wireless security. Choose enable. Choose either WEP or WPA encryption, the latter is a more secure choice. Choose 64 or 128 bit encryption, again the latter is a more secure choice. Enter a passphrase and write it down so you can enter it when it is called for when installing the wireless software on your wireless computer. A hexadecimal WEP/WPA key should be generated. Save or apply changes.cheers
Dec 03, 2008 | Edimax 4 Port Wireless AP Broadband Router...
Denon ASD-3w ipod dock not being recognized by denon 3808
I successfully connected the ASD-3W to the Denon 3808CI using the supplied AV/Control cables (dock control, L & R audio, S-video). I used the video and audio input connectors marked VCR (iPod) on the 3808CI and used the default settings. I used the connector marked Dock Control for the control cable. These VCR (iPod) connectors are different than the input connectors marked VCR. I turned the source selector to VCR/iPod Stereo and operated the GUI using the ASD-3W remote control. I was able to play music and video.
Nov 16, 2008 | Denon ASD3W IPod Networking Dock Docking...
How do i get on the internet with my psp
Ok First you have to make sure that you are in a WiFi (Hotspot) area because that is how the psp gets online.
  1. Step1 – Go to Settings and then select Network settings
  2. Step2 – Select Infrastructure Mode and start a [New Connection]. By setting up in Infrastructure Mode, you will be able to take advantage of the more exciting features of the PSP, such as browsing the Internet and playing games online with your friends.
  3. Step3 – Access the WLAN Settings and select scan to search for an SSID of nearby access points. If you find more than one access point, simply connect to the one with the strongest signal.
  4. Step4 – Once an SSID is found, select it (make sure you don’t rename it) and move to the WLAN Security Settings. You should note that if the access point is using WEP encryption, you will need to enter the WEP key manually (when the access point is detected, it will display the type of encryption it is running. WEP key should be displayed on your router. If it displays none, simply move onto the next step.
  5. Step5 – Now you have a couple of choices of either Easy or Custom in Address Settings menu. I suggest you selecting the Easy option which will complete the Infrastructure Mode set-up automatically.
  6. Step6 – Choose your Connection Name and enter it. A Setting List will be displayed. Press x button to save settings.
  7. Step7 – Test Connection to make sure everything works. If all is okay, Network Settings will display Connection Name, Signal Strength, SSID, BSSID, Channel, Security and IP Address.
Sep 09, 2008 | Sony PlayStation Portable (PSP) Console
How can i put internet in my psp?
To connect to the internet;
  1. Check that you have your PSP® (PlayStation® Portable) system set up for Wireless (WLAN) networking in Infrastructure Mode.
  2. Make sure the WLAN switch on the left side of the PSP® is turned on so that the PSP® can connect to the internet.
  3. Make sure you are within range of a wireless access point (or hotspot) that allows connections to the internet.
  4. Select icn_www.gif (WWW) under icn_network.gif (Network) from the home menu and press icn_btnx_color.gif.
  5. Use the up and down buttons to select the address bar and press to display the on-screen keyboard.
  6. Use the on-screen keyboard to enter the address for the web page you want to display.
  7. When you have finished entering the address, highlight the Enter button and press icn_btnx_color.gif.
  8. Select a connection and press icn_btnx_color.gif.
  9. The web page will be displayed.
  10. To hide the on-screen menu, press icn_btntriangle_color.gif.
Setting up Infrastructure Mode;
Infrastructure Mode allows you to connect your PSP® (PlayStation® Portable) system to the internet through a wireless network (WLAN) access point.
Required items:
  • A PSP® with system software version 2.0 or later.
  • A wireless network(WLAN) access point with internet access, such as:
    • A Wi-Fi hotspot (such as those at cafés, hotels and airports).
    • A home wireless network, which might include:
      • A subscription to an Internet Service Provider (ISP)
      • A DSL or cable modem
      • A wireless broadband router
  • Settings used for the SSID, WEP/WPA-PSK encryption and WEP/WPA-PSK key, as specified when the wireless access point was configured.
To set up Infrastructure Mode on your PSP®:
  1. Make sure the WLAN switch on the left side of the PSP® is turned on so that the PSP® can connect to the internet.
  2. Highlight icn_settings.gif(Settings) from the home menu.
  3. Select icn_networksettings.gif(Network Settings) and press icn_btnx_color.gif.
  4. Select Infrastructure Mode and press icn_btnx_color.gif.
  5. Select New Connection and press icn_btnx_color.gif.
  6. Use the on-screen keyboard to enter a name for the connection, then press the right arrow button to continue.
  7. To set the Service Set Identifier (SSID) for the access point, select one of the following:
    • Scan: searches for and then displays a list of access points (or wireless networks) and displays the SSIDs.
    • Enter Manually: allows the user to enter the SSID using the keyboard. Select this option if you know the SSID of the access point.
  8. If you choose the Scan option in the previous step, select the access point to be used and press icn_btnx_color.gif.
  9. Confirm the SSID and press the right directional button.
  10. To enter security information for the access point, choose one of the following:
    • None: does not set security information.
    • Wired Equivalent Privacy (WEP), WPA-PSK (TKIP), WPA-PSK (AES): all set security information. Press the right arrow button to move to the screen for entering WEP or WPA (Wi-Fi Protected Access) keys. Note: The WEP and WPA key fields display eight asterisks no matter how many characters you enter as the key.
  11. After entering the security information, press the right arrow button to continue.
  12. To select the address setting method, choose one of the following:
    • Easy: the following information is automatically set
      • IP address settings: Automatic
      • DNS settings: Automatic
      • Proxy server: Do Not Use
      • Internet browser: Do Not Start
      Note: Most home networks will allow you to use the Easy address setting, which is recommended.
    • Custom: you can manually enter detailed setting information, such as when you are using a static IP network. For details, see the instructions supplied with the network device or the information provided by your ISP.
  13. After selecting the address setting method, press the right arrow button to continue.
  14. Check the settings, using the left arrow button to return to previous screens to make any necessary corrections.
  15. To save the new connection, press icn_btnx_color.gif.
  16. To test the connection, select Test Connection and press icn_btnx_color.gif.
  17. If the connection is successful, information about the network connection will appear. Press icn_btncircle_color.gif to end the connection test.
You can also check http://www.us.playstation.com/support/psp
for more information.
Jun 17, 2008 | Sony PlayStation Portable (PSP) Console
Denon ASD3W IPod Networking  Dock Docking Station Logo
435 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
