Question about Maytag MSD2756G Side by Side Refrigerator
Can't unlock my ice dispenser
I need the combination to unlock the ice and water dispenser on the front of my Maytag side by side
  • deenaholee Mar 16, 2009
    My lock button has always been able to turn off and on just fine, but today I accidentally pushed the lock button and now it won't unlock. I've even tried removing the plate and unhooking the wires, then reconnecting it and putting the plate back on, but no luck.
Press the lock button three times in a row
Posted on Apr 06, 2009
Maytag mfi2568aes control panel
If the refrigerator water dispenser is not working the water supply tube in the door may be frozen. This will be difficult to track down. Look for a connection point at the bottom or top of the door, try removing the hose and blowing air through it and out the dispenser. Next it could be the water valve that sometimes has twin valves for ice and water combined, third is low pressure into the line (bad main valve) or clogged filter... you need about 20psi for function. Last is the door switch, when the freezer door is opened the freezer door switch does two things, it turns on the light in the freezer and turns off the ice and water dispenser. If the door switch fails the dispenser will not turn on. The switch can be checked for continuity with an Ohm meter. If it doesn't have continuity it should be replaced.
May 16, 2014 | Maytag MFI2568AES Stainless Steel Bottom...
Front door drip
Inside the refrigerator there is a coil of clear tubing that goes to the water dispenser. Pinch off this line and then you can have ice once again
Jan 23, 2014 | Maytag MZD2669KEW Side by Side...
Maytag side by side refrigerator with freezer on the bottom water is spraying everywhere when the ice machine comes on. It has the ice / water dispenser on the front. Any ideas?
Check the water line leading to the ice maker for kinks. Also check the filer and ice tray end of the waterline for obstructions or ice that might be deflecting the water to areas other than the ice tray. Let me know how you make out. :^)
May 01, 2012 | Maytag Refrigerators
How to unlock water dispenser
ther is no unlock . need a better understanding of the problem to help .... if no water or no ice there several ans . to the prob. if no water to disp but it does make ice then look at the water valve .. mm hope this helps // feed back pls //
Jul 10, 2011 | Maytag MSD2756G Side by Side Refrigerator
Unlock water and ice machine
OK from what I understand for some reason ice and water appears to be locked. This information is in the service manual for your model but also results in test that you will need to do there at the dispenser control. It will be listed on page 108 of manual and section 2-8 of the manual. I will assist you if you like, Sea Breeze
Mar 24, 2010 | Maytag MSD2756G Side by Side Refrigerator
The switch on Maytag water and ice dispenser hangs
Need to enquire from the agents if that dispenser switch is available as a spare part. If so, switch off and strip carefully as logic shows you.
Sep 24, 2009 | Maytag MSD2756G Side by Side Refrigerator
My maytag MSD2556ae side by side refrigerator water/ice dispenser may be locked. Is there a method or code to unlock. The water dispenser started shooting water out with no warning and the dispenser light...
I have a Maytag model 2556 AE refridgerator. The ice maker works but the ice and water dispenser, the light and everything else on the front of the unit doesn't work. Is there a fuse that operates this or is there other problems? Thank you Bob
Jun 10, 2009 | Maytag Dual Cool 25 cu. ft. Side-by-Side...
Can't unlock ice water depenser on maytag side by side
On most brands all you have to do is hold the lock button until it unlocks.
Jun 10, 2009 | Maytag MSD2756G Side by Side Refrigerator
How do I get the filter light off after changing the water filter?
PRESS THE LOCK AND LIGHT BUTTONS AT THE SAME TIME UNTIL LIGHTS BLINK.THEN IT WILL RESET FOR 12 MONTHS OR 44O GAL.HOPE THIS HELPS
May 31, 2009 | Maytag MSD2756G Side by Side Refrigerator
Ice and water dispenser
Has someone pressed the lock button on the front of the fridge just above the dispenser, next to the crushed & not crushed ice button, if so there is also an unlock button next to it.
Jan 04, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Maytag MSD2756G Side by Side Refrigerator Logo
692 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
