Question about Makita Drills
Wiring diagram for makita 6510 LVR drill
Cant remember the wiring for trigger and cord, can anyone help?
  • kenkrk Feb 13, 2009
    It has two wires coming from the field..a smaller size black and a white...
  • 2,176 Answers
I can't find the wiring schematic online but if you can bear with me I will make some phone calls thurs. and get one faxed to me. It has been so long since I had one apart that I can't remember.
Posted on Feb 11, 2009
  • David Ford
    David Ford Feb 12, 2009
    got wiring schematic but need to know what type your drill is, they made some ongoing design changes to it. Does your field have 4 wires or 2 coming from it. Let me know and I will get you the right one.
  • David Ford
    David Ford Feb 13, 2009
    OK sounds like your tool is a type 4. Now for the wiring from the schematic I have the white from the field should be going to a terminal block to the white from the reversing switch, if so continue with the following make a rectangle schematic of your switch and from the back view the wiring would be lower left is white from the cord, lower right is black from cord and upper left is black from the field the switch might be marked with line and load on the side the line side is the cord and load is field. If your tool has anything different don't plug in, let me know and I will send other info but I think this will work
My Makita 6402 drill stopped working. I press the trigger and it does not make any noise at all
You will need to have someone take it a part and see where the problem lies.
Start with the electrical plug, both the wall plug and inside the drill where the wire attaches to the switch.
Often, the switch is the problem, but the wire itself can be bad, if the cord is worn.
There is such a thing as the wire separating inside the cord.
We will hope the unit is not "toast".
God bless your efforts.
Oct 25, 2016 | Makita Drills
My Makita impact driver led light stays on soon as the battery is clicked in. Any idea whats wrong and how I can fix it?
the light is normally activates by the trigger, so either the switch has gone faulty or the wires running to bulb are contacting.
press the helpful button and check link below
Makita BTD142 Trigger Switch Replacement
Jan 23, 2016 | Makita Drills
Drill keeps spinning when trigger is released use to stop when trigger was released
the break is out or the brushes are worn excessively. I would think the brake is out and for that you would need to replace the switch. MAKE a wiring diagram before removing the switch it is polarity sensitive. You can go to makitausa.com for a parts diagram and also order from there or they have a service locator also where you can find parts locally. Let me know if you need more assistance.
Aug 29, 2011 | Makita Bhp452hw 18-volt Cordless Drill...
My jig saw will not run when i pull the trigger. sometimes it works when i shake it. the cord seems to be in good shape. it just doing it out of the blue
Sounds like you need a new trigger. Open up the handle,and check if you have power to the trigger. If you put a jumper wire to both sides of trigger,it will tell you if it's the trigger. If that dosn't solve the problem you have a break in the cord.
Aug 28, 2011 | Bosch Garden
I dont know whats wrong with my valor 169T dvd player i can hear it but i cant get to see it in my monitor
You have to disable the emergency brake bypass. From what I remember there are two wires on the back of the radio one for the brake and one for the emergency brake. One of the wires is a blue yellow and the other one may be a light green. But you have to trigger the brake wire twice and trigger the emergency brake wire once in order for the video to play. The brake has a positive trigger and the emergency brake has a negative trigger.
Mar 10, 2011 | Alpine CVA-1003 Car Video Player
I was cleaning my ts400 and cant reinstall the trigger can anyon e help please?
Use a pair of long nose pliers, and the trigger enough to align the wire with the slot, a drop of oil on the slot will help the wire to snap in.
Feb 12, 2011 | Saws
Drills Logo
993 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
