Question about Toshiba E-Studio 3511 Color Copier
E3co e3eo toshiba 451c
Paper jams from large feeder
  • Anonymous Mar 14, 2014
    Toshiba 451c
  • Toshiba Master
  • 643 Answers
E3C0 indicates LCF transport jam (not reaching the registration sensor).
Open the jam access cover. Is there paper in front of the registration sensor?
YES-> Remove the paper.
NO->Is the registration sensor working? (Perform the input check: 03-[FAX]ON/[9]/[E])
If NO ,
1) Check if the connector of the registration sensor is disconnected.
2) Check if the connector CN338 on the LGC board is disconnected.
3) Check if the connector pins are disconnected or the harnesses are open
circuited.
4) Check if the conductor pattern on the LGC board is short circuited or open
circuited.
5) Replace the registration sensor.
6) Replace the LGC board.
If YES:
Are the upper transport clutches (high/low speed) working?
(Perform the output check: 03-439, 440)
Posted on Feb 13, 2009
Paper jam I've cleaned sprayed,etc must be something I can't see w/o going deeper. How do I remove cover to get to paper rollers in MX340
Removing the covers is not the answer. Most jams on rear feed printers/faxes are due to some object falling in the sheet feeder. When you pull the paper back out (Very slowly) of the sheet feeder after it has jammed , you will see a nick in the paper. This is because the paper is hitting something and cant get past it. put the paper back in the sheet feeder and the nick will indicate where the object is. Find a large paper clip and unwind it and bend the top of it to 90 degrees. use this to hook the object out and then tip the printer upside down and watch it fall out. Good luck
Dec 11, 2016 | Canon PIXMA MX340 Wireless Office...
Toshiba e 255 is error code E 030
E030 indicates jam on exit...It is intermittent jam or totally jam?
U need to check the paper transport from feeder to registration then up to fuser unit, lastly exit unit...
Sep 01, 2015 | Toshiba Office Equipment & Supplies
Toshiba studio 281c paper jam beeping volume
I suggest You Go to Official Toshiba Printer Page For You Toshiba Printer Problem On Below Toshiba forum URL Link: TOSHIBA TEC 452
Feb 27, 2014 | Office Equipment & Supplies
The belt inside my scanjet 4200c has come off. How do I reattach it? I have opened the scanner. It looks to be relatively easy but I don't know how to attach the belt to the motor etc
Instructions
1 Lift the hatch on the feed tray and pull up the large green tab to the left of the roller. Remove any jammed or torn paper from under the roller and around the feed tray.
2 Pull the input feed tray out of the automatic document feeder. Grasp the feed tray with both hands and pull it straight out.
3 Check the interior of the automatic document feeder for jammed paper. Remove any jammed paper, then reinsert the feed tray into the automatic document feeder. Push down the feeder cover until you hear a click.
Mar 08, 2011 | HP Scanjet 4200c Flatbed Scanner
Paper feeder stuck
If the paper feeder stuck, do the following:
  1. Gently pull any jammed paper out from the output tray or sheet feeder.
  2. If paper is stuck inside, open the printer cover and remove the jammed paper, including any torn pieces. Then close the printer cover.
  3. If paper remains near the sheet feeder, press the paper feed roller lever inside the paper feeder to release the jammed paper, then carefully pull it out.
  4. Load the paper correctly.
  5. Press the cp_button_14.gif stop button to resume printing.
  • If the printer continues to jam or misfeed paper, and you are certain that there are no foreign objects lodged down inside the paper feed area, your printer may require service. Please call Epson technical support for further assistance.
  • Jan 29, 2011 | Epson Office Equipment & Supplies
    Toshiba 2860.. auto doc feeder keeps jamming.. seems like one side is feeing and other had side isnt or something similar. Any ideasa?
    In any doc feeder, the initial two feed rollers and one paper separator pad/roller handle most of the paper transportation. So usually if you have misfeeds, and the paper is not crumpling up, you have a problem with worn or dirty feed rollers. However, if the paper is getting crumpled up, you most likely have a physical obstruction blocking the paper path. My recommendation for when this happens is to take a thick piece of card stock and manually feed it through the paper path on the doc feeder, this usually acts to unclog any jammed paper bits or debris.
    -David.
    Oct 30, 2010 | Toshiba 2860 Copier
    False Jam at exit on a Toshiba DP3580 copier
    make sure your drawer size shows 11x17 on display if not push user interface button then select the drawer and set it to 11x17
    Jul 04, 2017 | Toshiba DP2570 Printer
    Feeding paper for scanning/faxing - e-studio350
    If u put stack of papers on the feeder, but it didnt pick well or paper jam occur, u need to check the feeder unit. Normally roller is wear and tear, foreign materials inside the feeder and etc will cause paper jam on feeder.
    Mar 19, 2009 | Toshiba e-Studio 350 Copier
    Says add paper to large tray even though it is full
    Depending on which large capacity feeder you have.
    If you have the one that is on the bottom of the machine, make sure there is a gap between the paper in the front and rear of the paper tray, There is a black plastic guide in the middle of the tray that may be being caught by the paper.
    If you have the large capacity feeder on the right side of the machine then most likely the black actuator that tells the machine the tray is full has broken or the sensor is bad,
    Feb 12, 2009 | Toshiba E-STUDIO 650 Copier
    Toshiba E-Studio 3511 Color Copier Logo
    303 people viewed this question
    Top Toshiba Office Equipment & Supplies Experts
    didi2005
    jasbo
    jasbo
    Branko Djurdjevic
    Branko Djurdjevic
    Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
