Question about Samson C01U - USB Studio Condenser Microphone Consumer Microphone
SAMSON CO1U recordings sound like they're underwater on my MAC
Hey, my Samson CO1U records at a very low level, it sounds foggy, like the sound is underwater. I have tried to adjust the sound level in the System Preferences, but it still sounds horrible.
What do I do? Any advice?
Thanks!
IMac 2.66 GH Intel Core 2 Duo
Os X 10.5.6
  • 4,234 Answers
The behavior you describe suggests that the mic is not getting power. Since it is a condenser mic, it requires what is usually called "phantom power". This should be provided thru the USB port. Check to be sure that the USB port is supplying that power. Check with another port for example. If that fails, you may have a defective mic.
Keep us posted.
Dan
Posted on Feb 10, 2009
I am running Windows 7 with Audacity and a Samson CO1U USB mike The mike is recognised in Windows and have set Audacity for the Samson input and adjusted input level. The sound recorded is very...
Did you try opening the sound properties page in the control panel...look for the recording tab in sound properties..here you will find sliders for the inputs on the sound card(as for recording)..you may need to set these up also to make everything work properly...there also should be a sound mixer built in to windowsthat you can access by clicking the speaker icon on lower right side of screen(if you have icons enabled)..right click this to open and when you get to the mixer there should be a tab at the top for advanced controls..here you will find the recording controls..make sure the input is turned up and make sure the input in not muted..there should be a box for mute and it should not be check marked
Jan 21, 2011 | Samson C01U Consumer Microphone
I can't hear myself while recording. I can only hear what I have recorded AFTER the fact. During recording I cannot hear anything at all. Is there a solution to this problem when using the Samson CO1U?
Depending on what audio production program you are using you will need to have the monitoring function engaged. Comment with what program and I can walk you through it. Good Luck, Cody J.
Dec 19, 2010 | Samson C01U - USB Studio Condenser...
Im gettin only one side when i record a vocal wit mixcraft 3
Make sure your recording onto a Mono track in your software, don't choose stereo when creating the track.
Feb 20, 2010 | Samson C01U USB Condenser Microphone...
Cant get any sound from mic!!!!
Go into Play control on your computer. Click on options then properties. Look at your settings for playback and recording. Check play control and your source eg. microphone. To reach this double click on the speaker icon in your toolbar or you can find it under sounds and devices in your control panel.
May 23, 2009 | Samson C01U Consumer Microphone
Static with playback on samson-gtrack with windows xp
i have the same problem with my g-track on a macbook im just going to take the thing back
it works for a feww min when i first start recording the is falls apart
Jan 10, 2009 | Samson G-TRACK USB RECORDING MICROPHONE...
Sound quality not good at all
open up the sound icon on control panel...select recording......select samson mic....make sure set to default.....go into properties ...and boost main volume slider....most mics after install are set quite low and you have to go in and adjust the vol input level
Jan 03, 2009 | Samson C01U - USB Studio Condenser...
My microphone sounds muffled
Check wind screen. Make sure output level is not higher than volume level.
Dec 09, 2008 | Samson C03U Professional Microphone
No good sound quality
ARE YOU RECORDING IN STEREO OR MONO
Sep 01, 2008 | Samson C01U - USB Studio Condenser...
SAMSON CO1U USB MIC FAILURE
Your first issue is vista... it just sucks. I would have to be there to figure this one out but im going to state the obvious, does it have an installation cd you didnt use? does it have online drivers you can find? Try looking around in your control panel and messing around with some of the options, good luck.
May 01, 2008 | Computers & Internet
Samson co1u recording issue
you first 3 people are idiots... maybe if you had worked with the hardware you would know how the mic works because its obvious you don't. The 4th person is correct because this is exactly how i use the mic and it captures sound in stereo format beautiful when set up rite. Using it in mono, whether use keep on one channel or two drastically reduces the crisp sound that this mic can record.
Mar 18, 2008 | Samson C01U - USB Studio Condenser...
Samson C01U - USB Studio Condenser Microphone Consumer Microphone Logo
888 people viewed this question
Top Samson Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
Jerry Umali
Are you a Samson Audio Player and Recorder Expert? Answer questions, earn points and help others
