Question about Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150 will not boot. Flashes amber light
Hi All, I tried to remove an old anti-virus from my Dell XP Pentium based Tower PC. Just as it was about to be removed using (Add or remove Programs), the PC went off and an Amber light started flashing on and off.
I spoke to a PC technician who thought it was the power supply so I gave the power supply to be fixed. According to him the power supply was worked on but the same amber lights flashes and the PC does not boot and one can not even here the Power Supply Fan working when the power on button is pressed. The only thing seen is the flashing lights.
This PC is about three years old. What could be the problem? Is it the Power supply unit or something else?
  • Keith of York
    Keith of York Feb 11, 2009
    The green light flashing on power button. PC difficult to boot. Have decided to leave computer on all the time.
    Problem Solver:
  • 3 Answers
I had the same issue with my Dell Dimension 5150 and I replaced the front I/O USB Audio Panel and it booted right up.
Posted on Jul 09, 2009
    Master:
  • 441 Answers
Blinking amber states that the power supply is receiving power from the source but is unable to properly distribute it to the components. Most likely the power supply gone bad already. If your Dell system is still under warranty, Dell can still replace your power supply and send you a service tech. Check the Diagnostic Lights found at the front panel of the system. If your system is working fine, normally you will see light 1,2,3,4 lit saying that your system is able to complete the POST process.
Posted on Feb 10, 2009
I have a Dell Dimension 5150 desk top computer which I have moved to another room & now won't switch on, just flashes an Amber light to the front of the hard drive. Is this something I can fix...
A flashing amber power LED indicates that the power supply is not providing the correct voltage.
  1. make sure if there is a voltage switch on the power supply that it is set to the voltage of your country (120 VAC for North America) maybe cycle the switch from 120 to 240 and back
  2. If the switch is set right and you are using a power strip/battery backup, by pass it and plug directly to the wall.
  3. Make sure the black and yellow 4 pin connector for the processor is connected on the motherboard.
  4. if all the above have no effect, replace the power supply in the tower
Sep 02, 2011 | Dell Dimension 5150 (DIM515MIN) PC Desktop
My Dell Desktop Dimension 5150 does not start sometimes
loose connect or mother board problem (is your os & HDD is OK ?)
Jun 24, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Tower power button flashes amber but will not start
Flashing Amber power LED indicates a bad power supply.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817822008&cm_re=atx_power_supply-_-17-822-008-_-Product
May 13, 2010 | Dell Dimension™ E510 PC Desktop
Dimension 5150 computer wont boot up -flashing amber light
While the system begins booting --before the xp logo shows, if it gets that far for you, hold down the F8 key. This will bring up a menu. Choose "start windows in safe mode with networking".
The OS will start in safe mode. run a virus scan, defrag and scandisk, then restart the system. If is still wont boot normally, do the same thing then run a registry fixing program such as uniblue registrybooster, then reboot. If it still won't boot you may have to format the drive and reinstall the OS. good luck.
PLEASE RATE THIS ADVICE WITH SOME THUMBS UP!!!
Apr 22, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
PC will NOT turn on;flashing amber lights
The power LED Flashing AMBER indicates the power supply in the tower has failed and needs replacement.
You can get a replacement here:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817165004
Dec 20, 2009 | Dell Dimension 5150 Intel Pentium 4 w/HT...
Only amber light is on when start...no green lights...
its a power problem. Your power supply is not giving enough power
Dec 08, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Blinking amber light and wont boot up.
if the power button was blinking amber, unplug your tower, and hold the power button for 30 seconds to 1 minute, to use any excess power stored in the capassitors in the pc. this was told to me by a dell tech, it is a small issue with the 3100=E310, and 5150=E510 Dimension desktops
Sep 24, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
Amber Flashing Power button on bootup
i would change the battery first of all. this is the reason for losing date and time
Jul 31, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150 automatically turns off
That flashing amber light is usually a sign the power supply is failed or is failing. I would suspect the power supply is the problem in yours. It is the better of the two problems connected with the flashing amber light..the other is motherboard is failing. Arrrr!
hope this helps (it takes a standard- oh say 350 watt 20-24 pin power supply unit.)
Hope an answer helps.
Please leave rating, thankyou
May 05, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
DVD/CD ROM problem (Dimension 5150)
you cleared the bios settings by removing the battery.
Go into the dell bios at startup F2
make sure it sees the cd rom drive
then save and exit
should fix the issue
Jan 26, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150 (DIM515MIN) PC Desktop Logo
1,846 people viewed this question
Alun Cox
