Question about Epson Stylus C66 Photo InkJet Printer
Can any one tell me where the chip is located in the epson c66
I have cleaned ink pads and will be using overlfow thank the sscutility say to take out the chip befor resetting the couonter but i don't kow where it is lacated and how to use the utily i have downloaded the sscutilty and now need help to reset the counter
  • n_makvana Mar 17, 2009
    THANKS IT WORKS!!!!!!!!!!! :)
  • 353 Answers
The counter you need to reset using the ssc utility is the "Protection Counter". Once you have reset this, turn the printer off and back on and it will be working again.
Please rate this solution if it has been helpful
Posted on Feb 15, 2009
  • Gerry Millward
    Gerry Millward Mar 17, 2009
    I'm pleased to be of help. Would you rate my solution please - thanks.
Epson Stylus C66 PRINTER KEEPS ON FLASHING RED LIGHTS ON THE INK BUTTON AND PAPER BUTTON
Check the status monitor on the PC, this will tell you the error. If service error it need the wast ink pad counter resetting
Mar 13, 2010 | Epson Stylus R265 InkJet Photo Printer
Epson Stylus C66 has been sitting idle for about 2 years. I replaced the printer cartriges with new ones and all that prins s blue. I have run the clean the heads process several time to no avail. I expect...
You might not be able. The ink wells might be plugged. Don't spend too much money on ink.
Hello, In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. That sounds like your problem. Also in Purchasing the Brother's . Color that should be Yellow, will turn out Green, etc. These printers have a chip, that will detect if it is Generic or Genunie. When using Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, but you have to fill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. Don’t waste too much ink in cleaning it.
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Jan 21, 2010 | Epson Stylus C66 Inkjet Printer
Both red lights are flashing on epson stylus c66. I saw some responses that said to reset ink counters. Not sure how to reset ink counters...
well it shall depend on your operating system. there is an available download on the epson website and it is called the ink pad reset utility. if this process tends to detect and install your printer it will work again
the website is www.epson.com/ipr
Sep 23, 2009 | Epson Stylus C66 Inkjet Printer
Hi, epson c66 has 2 red lights on. no paper stuck and cant move the cartridges to change. any idea
hi dude
your printer's ink waste pads are full and the counter needs resetting Try this site and software
It allows resetting of the counters, and gives much more control over cleans etc. (Also will allow cleaning when the red Ink light is flashing)
Aug 10, 2009 | Epson Stylus C66 Inkjet Printer
C66 - service required
This message indicates that your waste ink pads are full and require replacing. Replacement is costly, messy and requires the printer to be taken completely apart. Most often the counter has "jumped" to the end of life number, this especially happens where 3rd party or refilled inks have been used. If you believe this to be the case and there is no sign of ink leakage and the pads look fairly clean then you can just reset the counter using special software called the SSC utility. See these sites:
http://www.ssclg.com/epsone.shtml
http://inkjetprinterhelp.us/epsonSSC.html
More information about this issue and the official resetter is available from the Epson web site, please read this link:
http://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp
Please take a moment to rate this solution. Thanks.
Apr 06, 2009 | Epson Stylus C66 InkJet Photo Printer
Epson stylus c66
The Waste Ink Pads are saturated and the waste ink counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utility - download from
and reset the Protection Counter. This will stop the red lights flashing and restore normal operation. However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer.
The C64/66 service manual can be downloaded from here:
http://www.eserviceinfo.com/downloadsm/12748/Epson_C64%20and%20C84.html
Should you decide to have a go at changing the waste ink pads, let me know and I can supply some notes on opening the case - it's a pig and the service manual is not that helpful.
Oct 22, 2008 | Epson Stylus C66 Inkjet Printer
Epsom stylus C66 inkjet printer
Hi
This problem is probably caused by a blockage in the ink waste pads. Over time, particularly with increased nozzle cleans the pads get saturated. These can be replaced by an Epson Engineer at a cost of about £30-£40 but probably more effective to buy a new printer. This usually happens when the printer is between 2-5 years old.
Hope this helps
Sarah
Oct 10, 2008 | Epson Stylus C66 Inkjet Printer
My Epson C66 Only Prints In Yellow Ink No Other Colours, I really Need Some Help! It Says That All The Other Ink Catrages Are Full But Still Wont Print In Them Colors... Reply Please x
See my previous post about intensive head cleaning. That should get you going again in no time.
See the post HERE.
http://www.fixya.com/support/t138226-printer_not_printing
Sep 25, 2007 | Epson Stylus C66 InkJet Photo Printer
Epson stylus c66
If your having an error that says "Parts inside the printer are at the end of there Service life" it means that you ink pad is full/ what you can do is change your ink pad and then download an ink pad reset utility so that you can reset the settings/ Make sure to change ink pad before you reset it becuase ink will leak if you don't change it. For the flashing lights, try to check for obstructions inside the printer if not, make sure that ink clicked in and the cover for the tray is closed
Mar 27, 2007 | Epson Stylus C66 Inkjet Printer
Epson Stylus C66 Photo InkJet Printer Logo
88 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
