Question about Grundig Satellit 800 AM/FM/SW Radio
Grundig 800 Satellit
Radio works fine on FM, but on AM and SW Bands it oscillates, though the stations are received, the oscillation makes it impossible to pick up the audio. I have the same problem. Good FM but nothing elsewhere apart from atmospherics. Help....................
  • 1 more comment
  • philip1302 Feb 12, 2009
    There are no batteries inserted unless there is an internal battery? Is there?
  • philip1302 Feb 13, 2009
    Thank you but alas, it is still not the solution. I can hear FM perfectly and after a lot of button pushing, I managed to tune AM also but, SW and LW are beyond me. Just atmospherics. Any other ideas?
    Hi Robert. Hoped that would be the solution but of the two capacitors I can see, they appear to be perfect. I'm in Israel and doubt if there is any service dept., for this unit and I'm not in this field. Any other suggestions? Hammer maybe?
  • Grundig Master
  • 19,396 Answers
The AM tuning is performend by a chip that is replacing the variable capacitor used on old radio sets.
This has a problem and that is the reason why you get no signal on AM.
Another possible reaso is a broke solder joint on internal board.
Both problems can only be fixed by having a technician working at the radio.
Posted on Feb 13, 2009
  • 4,806 Answers
Hi there
Do you live near electricity pilons or a radio or mobile phone mast? Any of these could be causing interference with the long wave and short wave frequencies, all you will get in this case is atmospheric noise.
Good luck and thanks for using Fixya!!
  • Lee Hodgson
    Lee Hodgson Feb 13, 2009
    Am bands are terrible for interference, even if you have it close to TV is will have interference, this because of the static electricity in the air. I suggest to try moving the radio to a different location to see if the interference clears up.
    Good luck
  • 4,234 Answers
THese units use FETs for the front end IF amplifier stages. If any of them are noisy (beginning to fail) the result will be as you describe. Usually this shows up as AM working but the others not. I don't know the exact design of your specific unit, but this is not likely to be traced remotely. In order to determine the cause, a signal will need to be traced. This is done with a signal generator that can generate the IF signals directly. Each stage in the unit will need to be traced. Unfortunately, yu will need to send this is to a service center. Most local shops will not have the required test equipment for tracing this.
Dan
    President:
  • 2,110 Answers
Must be a breakdown of the RF amplifier stage for the AM reception. I would get another one. Highly technical
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
If the unit was functioning before clearly on the AM & SW bands, then it would be a hardware fault internal to the frontend of the tuner/receiver; could be a preamp transistor of the 1st mixer/oscillator.
If the unit is new and the AM & SW has never worked before, then 2 possibilities are:
  • insufficient antenna;
  • RFI (radio frequency interference).
One way to improve reception is with the use of an external or enhanced antenna. The interference on the other hand could be addressed by either removing the source of the interference (florescent lamps, wireless phones, lamps with electronic ballasts, lamp dimmers and others of the such).
Would appreciate a postback. Good luck and thank you for using FixYa.
    Brigadier General:
  • 5,158 Answers
Your problem is a bad or leaking capacitor. remove the case and feel the tops of them... replace any that feel rounded at the tops
Robert
  • Roberta Smith
    Roberta Smith Feb 13, 2009
    hammer is tempting... there should be more then two... did you run your finger along the tops of them... i had one bad capacitor on a monitor i worked on and i almost missed it with just a visual inspection.
    Robert
  • Roberta Smith
    I won't complain to much if you want to send it to me instead of using a hammer on it tho lol
  • 10,594 Answers
If there is strong AC appliances noise nearby radio, it will make impossible to listen AM and SW band station sound.
You can confirm your radio to take it some where else and check AM and SW reception there.
Posted on Feb 12, 2009
  • 679 Answers
Remove the battery for 10 minute and reinsert.
Posted on Feb 10, 2009
  • rockfixya
    rockfixya Feb 10, 2009
    It seems there is a problem with the antenna, for AM and SW bands  stronger antenna is needed, so try replacing the antennae with a bigger one.
    thanks.
  • rockfixya
    rockfixya Feb 12, 2009
    yes there is internal battery check that.
Why no am reception on grundig 800 millinium satelite radio
It depends on your location. Set reception mode to AM waves. Dial in the frequency of the station or enter it using the keypad. To tune in on a station, rotate the radio.
Jul 19, 2014 | Grundig Satellit 800 AM/FM/SW Radio
SW reception is very poor. Can receive no Ham operators only powerful broadcasts like Havanna. AM not bad, FM fair.
SW transmission depends on an atmospheric layer called the ionosphere. The density of ionized atoms present in the layer is dependent on the light from the sun and on solar activity. The rule of thumb is to tune in to the larger meter bands ( 49m, 41 m, 31m, 25m ) in the evening and at night and the shorter meter (31m, 25, 21, ...16, 10) bands in the day.
To tune in to a particular signal you need to know the exact frequency and the broadcast time. You can search the Internet for the frequencies of a particular radio station and the times when that station is broadcasting in direction of your region.
Apr 06, 2011 | Grundig Satellit 800 AM/FM/SW Radio
Grundig Satellit 800 LCD display doesn't work correctly
If the radio uses memory batteries, try changing these with new alkalines. The microprocessor needs this power to drive the display.
Jan 30, 2010 | Grundig Satellit 800 AM/FM/SW Radio
Grundig Satellit 700 World Receiver. AM bands are dead.
Ist Local Oscillator (PLL) stops working. It's desiged with bare minimum feedback to keep it's output reasonably clean. Removing (De-soldering) the screening box reduces losses, but it's still marginal. Something in the osc. circuit is temperature sensitive, so squirting it with freezer spray - or putting the set in the 'frig will get it going again. Have one like this, "Repaired" - been going for about 5 years and just quit again! If I get any better luck next time, I'll re-post this!
Aug 15, 2009 | Grundig Audio Players & Recorders
Grundig Satellit 800 powers on but no sound on any bands or modes. It appears to have a signal on AM but nothing on FM. It's completely dead and the MAIN large tuning dail will not function either. All...
HI,
THE FIRST THING YOU HAVE TO LOOK FOR IS WHAT KIND OF ADAPTER 9V 1AMP YOU SHOULD
HAVE FOR THAT PARTICULAR RADIO AND ANTENNA FOR SW AND FM SHOULD BE CONNECTED.IT MUST BE THE ADAPTER THAT'S ON THE OUTS NOT ENOUGH VOTAGE TO POWER THE RADIO.
Jun 30, 2008 | Grundig Satellit 800 AM/FM/SW Radio
Repairing Grundig Radio receiver Satellit 3400
GRUNDIG SATELLIT ST 1400 SL
Diodo Zener ST601 Volt ?? (SU ALIMENTAZIONE)
HELP Simon
Feb 27, 2008 | Grundig Satellit 800 AM/FM/SW Radio
Can u give me the pincode of that area
Feb 04, 2008 | Grundig Satellit 800 AM/FM/SW Radio
Grundig Satellit 500 loses reception
Hi
I had such a pb.
IC 103 CX7961 stopt to oscillate after ~30s ...
so the plls ref was out
I changed it without results
In fact the plastic trimmer C138 (4-20pf) was bad???( insulation?)
Since changing (10 years ago) : no problem
Good luck
Dec 13, 2007 | Grundig Satellit 800 AM/FM/SW Radio
Grundig Satellit 800 AM/FM/SW Radio Logo
209 people viewed this question
Top Grundig Audio Players & Recorders Experts
k24674
xxxxxx xxx
Are you a Grundig Audio Player and Recorder Expert? Answer questions, earn points and help others
