Question about Sanyo DS31590 31" TV
My sanyo ctv has no power?
I have sanyo ctv with model number st21g1. and a chassy number ac5-g. the problem was no power. theres no voltage in its2ndary. i try to change its regulator but it doesnt operate also.. so please can you help me ?????
Does not deplay a picture
Posted on May 20, 2010
COULD someone help me..what is the value of the ceramic capacitor next to the horizontal output transistor it actually connected to the midle leg oF the HOT..my tv brand is sanyo st-21kx2 chassis,...
It might vary to 3500pF2000Vdc to 9500pF 2000Vdc. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
CTV circuit diagrams are given. you can refer it.
Oct 29, 2014 | Televison & Video
St21g1 tv diagram
Circuit diagrams are in PDF and cannot include by this window. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 14, 2014 | Sanyo Televison & Video
Power Issues with Sanyo DP50749
Main board is most likely but that is an educated guess--problem with all these is you can only check so many things and then have to guess and try a board.
Apr 22, 2012 | Sanyo DP50749 50 in. Plasma TV
Sanyo tv model ST21G1 chassis AC5G, will you please help me find the value of R617,power suppy section,thanks.
look for the colour code on the resistor and then look it up on a chart ,different values between a silver band and a gold band but the value is the same its just the % tollerance ,gold band is a lower tolerance
Jan 25, 2011 | Yugo GV Cars & Trucks
Hello my Sanyo dp42849 42 inch has no picture and no sound. when i turn on the tv a green light in the bottom right hand corner comes on and occasionally flashes off and then back on.
First, you need to know the sub-model of your TV.
It is called "chassis" and is shown on the back of the TV on the label where the model number is shown.
For example it can be "P42849-00" or "P42849-01".
Then search at www.coppelltvrepair.com/search or just go to www.coppelltvrepair.com and enter the link for SANYO DP SERIES to search for that.
Here's an example of a repair service (note it may NOT be the one for your exact model though!):
http://www.coppelltvrepair.com/p/41/sanyo-dp42849-p42849-00-does-not-power-on-repair-service
Hope this helps!
Jul 16, 2010 | Sanyo 42 in. LCD TV
Beko 32inch L C D model no 32WLK53OHID I NEED POWER SUPPLY PIN OUTS (wich line to wich part and voltage of each line ) from power supply
Hi.
I have problems locating the chassis number correspondent to this model number. I will need chassis number to locate service manual.
Please double check the model number and check if there is chassis written on service tag.
Here manuals for different Beko chassis.
See also here.
Jun 02, 2010 | Televison & Video
Sanyo TV Chassis Series AC5-C20 no sound
check power supply to ic,, it will be 12v from smps..may be fusable resistor has gone
Mar 21, 2010 | Sanyo DS27910 27" TV
Problem
deko, heres the number for Sanyo parts, 800-877-5032, you can order the service manual there, part number for manual is KTDS27425. I`m sorry I don`t have it to look up the IC but it will be very usefull to have the manual, I think it`s around $20.00
good luck with it, BMW Rider
Jan 14, 2008 | Sanyo DS27510 27" TV
Sanyo tv tuner identification
I have the sanyo part # 6450526084 . There is another number but could not find it online. There is a place called www.tiptoptuner.com that might sell you the tuner outright as they mostly rebuild them . The are the cheapest place i know of . You want to use the contact link and tell them the part # and see if they can cross it for you as i gave you part number. The ID # you refer to is on the tuner shield that you say is missing . Or you can google the part # to see what you can find should start with 1AV4FBAM???? . Good luck
Jan 13, 2008 | Sanyo DS31520 31" TV
Sanyo DS31590 31" TV Logo
517 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
