Question about Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop
Battery problem I hve a laptop of Nseries 76A model, with in warrenty period I replaced my Battery, but after 1 year I found battery is not charging at all, now I m only using my laptop with direct AC power only, so this is my 2nd time problem so plz suggest me what to do? what is the price of new original battery, now I can't purcghse new battery one year after one year if this type of problem occurs.
  • 3,940 Answers
Batteries in portable systems on average last approximately 300 to 500 recharge cycles (Roughly 12 to 18 months) and are considered a consumable item (Hence the 1 year warranty when the rest of the system can have a 3 to 5 year warranty). So your battery replacement is not entirely unusual. If a replacement battery is detected and recharges normally, then stops working after 12+ months of heavy use, the failure is normally the battery.
One thing to check is to see if the battery is under recall:
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=BATT-LENOVO
Google shows that Lenovo batteries run about $100 for a N-Series system (4400 mAh) which is about normal pricing for a laptop battery.
Posted on Feb 10, 2009
Why doesn't my hp notebook charge?
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Apr 08, 2013 | HP Pavilion Computers & Internet
I have HP Pavilion Dv4 1030ee laptop From Last 1 week i have seen that 'plug in but not charging'.my laptop battery is not charging bt working fine on connecting to ac
Feb 19, 2013 | Computers & Internet
Acer model zlr wont work unless pluger in to charger cord
Jan 21, 2013 | Acer Computers & Internet
I cant able to on my laptop when is not connected with ac adapter,but when is connected it starts power on but shows plug in not charging?please help me?
Dec 24, 2012 | Computers & Internet
Will a laptop battery become damaged if you use the computer while it is plugged in? I do a lot of photo editing, and leave the computer plugged in for long periods of time, so that it doesn't di
Laptop batteries vary from laptop to laptop. i suggest you Google the Internet for a battery for your model laptop.
Oct 25, 2012 | Acer Ac Adapter Charger For Extensa...
My laptop is under warrenty period and laptop battery is not charging model no: 6720S (KL420PA)
1. Try a different power cord that is similar in brand and size. You could have a bad power cord. I would also remove the battery from the system while it is plugged in. If you system loses power, then you for sure have a bust power supply.
2. Check the battery connections. Remove your battery and look at the gold contact points. If you see any rust, discoloration or debris, I would suggest cleaning those points with a microfiber cloth and see if that fixes it.
3. Most computer vendors consider the battery a wear and tear item. As such, they have different policies for replacing a battery. If your computer is brand new, call up HP and explain that they gave you a dud battery. They will usually UPS you a new one at no charge. Depending on the age of the computer, and how much you use it, they might replace the battery for a price. Do a search online for the same make and type of battery before you call. If you can get a better deal from an honest vendor (amazon.com , newegg.com, buy.com ) then do it.
Good Luck!
Aug 19, 2011 | HP Computers & Internet
1. beeps at startup with black screen 2. After installation new fresh OS XP SP3, logging in to use. I can move the move or pointing and clicking on any icon. Its still vibrating looks like virus...
1. Please enter into BIOS and set Load default settings. Remove any cds/dvds in CD/DVD ROM, remove pen drives.
2. Install the Touch pad drivers from the toshiba site. and check again .Check with External mouse and check , there may be touch pad problem.
3. Battery may be faulty. If your battery is under warrenty(one year warrenty from date of purchase) ask for replacement from manufacturer. Otherwise go to new battery.
4.Remove the battery and power on laptop with AC power. then check everything is working fine.. then try in re-insert the battery and charge it..
Hope this helps
Jun 28, 2011 | Toshiba Computers & Internet
When my sansa died for a long time, i just now found the charger and now it wont come on. how do make it come on?
Try charging overnight. Then do a 'reset' by holding the 'on' slide up for at least 20 seconds. If that doesn't work, connect it to a computer with the USB cable and see if the computer 'sees' it as a drive. If none of that works then contact Sansa. Pray it is in warrenty (1 year). Sansa will replace defective players in warrenty but has NO repair option if out of warrenty. I've had two players just quit working (no power at all). One started working again for a while. I was able to replace one (in warrenty) the other is out of warrenty. Seems Sansa Clips have either a battery defect or more likely a connection to the battery/power circuit that breaks. No user fix I've found. Good luck.
Mar 03, 2010 | SanDisk Sansa Clip MP3 Player
How to get the warranty period to be expand as allready in warranty period of three years but my dealer is given for 1 year.
Hai, mostely all laptop except toshiba comes with under 1 year warrenty but you can extend your laptop warrenty periods by paying extra money . Please click on below given link to get more detials.
http://secure3.tx.acer.com/findsystem/FindSystem.aspx?title=Activate%20Your%20Acer%20Advantage
If this answer is helpful, please rate this answer
Feb 26, 2010 | Acer Aspire 5920-6335 Laptop
HP Ipaq does not turn on
Ufortunately, the battery is likely the culprit.
You can try removing the battery overnight, then leave on charger for at least 12 hours.
These batteries generally require replacement every 1-3 years. They deteriorate quite rapidly if left unused/uncharged for extended periods of time (like a year!)
Jun 25, 2009 | HP iPAQ HX2490 Pocket PC
Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop Logo
176 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
