Question about Beverly Hills Polo Club 22-710TTS
Brake light switch not meeting brake pedal
My brake light switch is not meeting my brake pedal causing my brake lights to be on all the time. the switch works fine the only way i can get it to work is by pulling my pedal up but as soon as i brake hard it clicks back into place causing my brake lights to stick on.
The brake light switch should be adjustable in as much as you can screw the switch holder around until it is the required distance from the brake pedal - the switch holder should have a locking nut, which requires undoing first then locking back once you have obtained satisfactory adjustment,thats assuming that the switch itself isn't broken or faulty.
Posted on Feb 10, 2009
How to shut off FLASH LT on g shock
Should be able to push light button again and it should go out
May 12, 2012 | Casio G-Shock GA-120A-7A GA-120A-7 Analog...
The light quit working.
One of two things could be causing the issue. If you have used your Indiglo a lot then the light source has burnt out. The other possibility is that the micro switch inside the case that turns the light on and off has broken. The only way to find out which is the cause is to take the back of the watch off and inspect the works. If you have to pay a watch shop to diagnose and fix the issue you are probably better off just replacing the watch. The labor bench charge in most shops for one hour will probably be more than what you paid for your watch. If you are not sure it might be worth contacting a few of your local shops to see what they would charge to diagnose the issue.
Mar 06, 2011 | Timex Indiglo Analog Watch
The back doesn't seem to want to snap back in
Try a very small dab of a very light lubrican on the sealing edges.
If you haven't already tried it, press the edge of the watch back using two fingers and move them appart until they meet again.
Season with a lot of parience... good luck!
Apr 19, 2010 | Timex 27191 Wristwatch
Buttons on casio pro trek watch stopped working -time still shows
Sounds like the solar back up cell needs to be replaced. You can get it repaired for rather cheap less that $30(US). You can contact www.casiosalesandservice.com to have it serviced. 877.659.0761
Jun 25, 2009 | Casio Protrek Triple Sensor Tough Solar...
Light button causes the time to reset, why?
Your battery is low and needs to be replaced, the light uses much more power than it takes to run the display
May 26, 2009 | Adidas Candy Digital watch
I have a G-Shock watch. One with Atomic and Solar recharge. They say it is water proof but after I stuck my hand in water to clean my fish aquarium everytime I twist my arm the light comes on. This causes...
Wow, you are retarded. That's a function of the G Shock watches. I don't know who would actually use the auto light function, but its there. To turn off auto light, hold down your illuminate button for 2 or 3 seconds until you hear a beep. Holding down the light button toggles between auto light on and auto light off.
Dec 01, 2008 | Watches
I can't get my light to come on on my Casio model 2608
To turn the auto light switch on and off--
In any mode, hold down (L) (light switch at 6o'clock/bottom)for about two seconds to goggle the auto light swithch on(auto light swithch on indicator displayyed) or off (auto light swotch on indicator not displayed)
Sep 26, 2008 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Set watch
I have a G Shock DW-004 made in 1997. I had this same problem, and I tried everything to change TO military time and back to standard time. I just read the bit to try and was about to do it. I pressed the top left button to get the time to flash, and hit the light button by accident (the one with the big G on it) and VIOLA! It changed to military time. So in my model, anyway, the G light button (under the display on the edge of the watch body) changed the time to military from standard and back again, when the time is flashing.
Feb 21, 2008 | Watches
Stress fracture in case
Contact Technomarine http://www.technomarine.com/
Jun 03, 2007 | TechnoMarine Ceramique Watch TCB02C
Beverly Hills Polo Club 22-710TTS Logo
98 people viewed this question
Top Beverly Hills Polo Club Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Beverly Hills Polo Club Watch Expert? Answer questions, earn points and help others
