Question about Microsoft Excel for PC
VLOOKUP Formula I want to look at a column that details the number of members per month and then depending on how many members, charge the appropriate fee. My problem is the fees are stepped and for every additional 2500 members the fee increases for the additional members (so if there are 5000 members, the first 2500 will be charged at say $30 and then the next 2500 will be charged at $20). I can get my VLOOKUP formula to caluculate the value if it wasn't a stepped rate, however I can not get my formula to take into consideration the stepped rate (there are four stepped levels of fees for each additional lot of 2500 members).
  • beeseearr May 11, 2010
    Can you describe what your vlookup is doing?
    Is the sheet made up of rows of members, and then it's going and grabbing the fee from another range? I think you may be better served by different commands or a macro, but need to understand your worksheet layout better.
  • 407 Answers
Using IF function or filter to generate the membership type and create a VLOOKUP for that..... Or using filter function you could create a pivot and insert the specific formula per type in that.
Posted on May 25, 2009
Dont understand how to use vlookup in excel 2007
This tutorial also helped me much to understand how vlookup works:
http://www.myhowtoos.com/en/excel-howtoos/84-how-to-match-values-in-excel-using-vlookup
Feb 18, 2009 | Microsoft Computers & Internet
Formula Help - Maybe VLOOKUP formula
you please send your excel file to me including data's which you wanted to solve.
My e mail address is santosh714@yahoo.in
i will send back to you after solving the sum
Feb 12, 2009 | Microsoft Excel for PC
How to use vlookup in openoffice using different sheets
=VLOOKUP(A2;Sheet1.$A$3:D27;2;0)
The cell I created this formula in was Sheet 3 Cell C9 - to show the different sheets
A2 is the cell I want to look up
Sheet1.A3:D27 is the range of cells that contains the data I want to return, The first column relates directly to cell C9 is Sheet 3. I locked the first cell in my range as I wanted to apply the same formula across other cells hence the $
2 is the number of the column that has the data I want to return, I had a choice in this formula of 4 columns
0 is the value to complete the formula
Feb 11, 2009 | Microsoft Excel for PC
How to use vlookup
you can a tutorial here.
please rate.
Feb 06, 2009 | Microsoft Excel for PC
Need to use the VLOOKUP formula for more then one column
You probably need to organise your pricelist sheet so that you only have 2 columns, product and price. If this doesn't fix you, please provide the syntax of your vlookup code.
Dec 10, 2008 | Microsoft Excel for PC
HELP with macro config
Hi Hss Holdings,
The easiest way to do this is to use a formula called vlookup. You need to have the raw data some where in the workbook, but it can be a separate sheet. Put all the raw data in a table, make sure the account number is on the furthest left column, then start entering the formulas
vlookup(value_to_find, table_to_check, column_index_number, range_lookup(true/false))
value_to_find = the value you want to find on the left most column of the table
table_to_check = the table you want to find the data from
column_index_number = the column number of the data field you want to return into this cell, 1 = the left most column.
range_lookup = false for an exact match, true for the nearest match
Say the table is on sheet2 between A1 and E300
B15 is whatever you type, so no formula needed here
B12 =VLOOKUP(C1,Sheet2!A1:E300,2,FALSE)
G12 = B12 =VLOOKUP(C1,Sheet2!A1:E300,3,FALSE)
etc
Jul 12, 2008 | Excel (SS8SATAS5128400R)
Excell vlookup formula
Suggest you do some debugging in steps:
1. Open the 'bills up to 022908.xls'
2. Use an empty cell to "=CONCATENATE(D3,L3)". That way you can see what values are being generated.
3. Copy the values of that cell and see if you can find them in Col G of 'bills up to 022908.xls'.
Once its broken down into pieces you can usually see "the error of your ways."
Hope this helps.
Mar 09, 2008 | Microsoft Excel for PC
Lookup,s
If you can move your name column (C) to the first column, you could leverage the VLOOKUP formula pretty easily.
To do this, do the following:
1) Move the C Column to be the A Column, shifting all other columns to the right.
2) (optional) Insert a new row at the top of the sheet (to hold the formula & seach value)
3) Use A1 as your search field.
4) In A2, enter the following formula:
=VLOOKUP($A$1,$A$2:$C$6,3,)
Describing above parameters, in the formula:
$A$1 -> the search field (name your looking for).
$A$2:$C$6 -> The table/grid you wish to search and return values from. The left most column (A) must contain the values to be searched.
3 -> is the column number (A=1,B=2,C=3, etc) within the table/grid to return.
If you cannot make the name column your first (A) column, there are more complex ways to do this. For instance, create a new sheet which redisplays the info in the structure easier for this method, and perform the VLOOKUP on that data. Other options might exist in creating a complex formula that would get you what you want.
Also, if you can sort column A (names) it would find results faster, if your data set is large.
Feb 03, 2008 | Microsoft Excel for PC
Function
VLOOKUP is to Searches for a value in the leftmost column of a table, and then returns a value in the same row from a column you specify in the table. Use VLOOKUP instead of HLOOKUP when your comparison values are located in a column to the left of the data you want to find. The V in VLOOKUP stands for "Vertical." Syntax VLOOKUP(lookup_value,table_array,col_index_num,range_lookup) Lookup_value is the value to be found in the first column of the array. Lookup_value can be a value, a reference, or a text string. Table_array is the table of information in which data is looked up. Use a reference to a range or a range name, such as Database or List. If range_lookup is TRUE, the values in the first column of table_array must be placed in ascending order: ..., -2, -1, 0, 1, 2, ..., A-Z, FALSE, TRUE; otherwise VLOOKUP may not give the correct value. If range_lookup is FALSE, table_array does not need to be sorted. You can put the values in ascending order by choosing the Sort command from the Data menu and selecting Ascending. The values in the first column of table_array can be text, numbers, or logical values. Uppercase and lowercase text are equivalent. Col_index_num is the column number in table_array from which the matching value must be returned. A col_index_num of 1 returns the value in the first column in table_array; a col_index_num of 2 returns the value in the second column in table_array, and so on. If col_index_num is less than 1, VLOOKUP returns the #VALUE! error value; if col_index_num is greater than the number of columns in table_array, VLOOKUP returns the #REF! error value. Range_lookup is a logical value that specifies whether you want VLOOKUP to find an exact match or an approximate match. If TRUE or omitted, an approximate match is returned. In other words, if an exact match is not found, the next largest value that is less than lookup_value is returned. If FALSE, VLOOKUP will find an exact match. If one is not found, the error value #N/A is returned. Remarks If VLOOKUP can't find lookup_value, and range_lookup is TRUE, it uses the largest value that is less than or equal to lookup_value. If lookup_value is smaller than the smallest value in the first column of table_array, VLOOKUP returns the #N/A error value. If VLOOKUP can't find lookup_value, and range_lookup is FALSE, VLOOKUP returns the #N/A value.
Aug 30, 2007 | Microsoft Office Standard for PC
Vlookup
Hi Ralph, On the first table If the name is in column A and dept is in B. Suppose the new names are in column D here's the formula =vlookup(D1,A:B,2,0) Note a few things - 1. You will only receive the 1st departament. 2. In case that the name in D doesn't appear in A you'll get N/A. This can be solved using the following formula: =if(type(vlookup(D1,A:B,2,0))=16,"",vlookup(D1,A:B,2,0)) Let me know if there's anything else. D.
Aug 27, 2007 | Microsoft Office Standard for PC
Open Questions:
See all Microsoft Excel for PC Questions
Microsoft Excel for PC Logo
314 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
