Question about Panasonic NN-S961 Microwave Oven
NN-A574SBBPQ - Microwave fans & turntable not working
I have a Panasonic NN-A574SBBPQ, which suddenly failed with a small 'pop' sound.
Device is just out of warranty, so opened it up and checked fuses ...found 2, both OK. Switched back on and tried a few things;
The control panel/timer, grill & microwave all work OK, but the turntable* & fans are not working.
*n.b. I disconnected the turntable motor, wired up separately and it turned OK.
So, it seems to be a fault with whatever powers these components and theoretically simple to fix, but I don't know which specific part has failed or what it is called, so that I can order & fit a replacement ...Any ideas?
  • 52 Answers
2 fuses in a panasonic does not sound enough.
have you checked the main incoming power protection fuse normally 10amp or higher.
most panasonics have approx 4 fuses so keep on looking
Posted on Feb 21, 2009
2 Suggested Answers
MicrowaveSvc
  • 9086 Answers
SOURCE: Microwave - fans & turntable not working
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so.
Posted on Feb 15, 2009
Panasonic Dimension 4 Genius problem
An internal fuse may have blown or the magnetron may have failed
Apr 09, 2013 | Panasonic Genius Prestige Nnsd997s -...
Panasonic nn ct766 turntable locked
If everything cooks as normal but the turntable does not turn then I would say that either the turntable motor has failed or the supply for the motor, either way this is not a problem you could fix yourself & so I would recommend taking to a microwave repair centre or service engineer.
Dec 26, 2012 | Microwave Ovens
Panasonic NN-A755
It does sound like the magnetron is failing, when it shuts down it is because the thermal fuse is detecting to much heat from the magnetron and shutting it down, I might add this part is the heart of the system, rough cost would be in the area of $100.00 maybe cheaper. Intallation of this part is very tricky and there is the danger of high voltage, I recommend a pro for safety and correct installation.
Apr 12, 2012 | Panasonic Microwave Ovens
Panasonic microwave NN-S666BA
No! the main fuse is okay because you would not have any power. I would check all door switches because they control light, fan, and turntable. If you are handy with a meter, set to ohms, disconnect one wire on side of switch, use meter to test, readings should show open/short when pressing the button and releasing it, replace wire to switch and repeat, if you hit one with the same readings pressed in or out, change the switch.
Mar 06, 2012 | Panasonic NN-S666BA Microwave Oven
I purchased a panasonic nnsd797s inverter microwave in Febr 2010. The turntable appears to have been the source of noises for the past few months. It quited down for a while, but is not louder than ever...
The turntable motors cannot be lubricated, only replaced. The popping noises you mention, is that from the motor or from the microwave arcing??? Unplug the turntable motor and put a cup of water into the unit and run it for a little bit and listen, if it is stil popping you may have other issues.
Oct 06, 2017 | Panasonic NN-SD797S Microwave Oven
Panasonic NN-S740BA Microwave oven
In all likelihood the mangnetron is failed or failing, or perhaps even the Power Supply is faulty. You need to have it serviced by a reputable service centre/man.
Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one
Jan 27, 2010 | Panasonic NN-S740BA Microwave Oven
Panasonic Microwave NN-S935BF turntable and light do not work. Microwave still works. Bulb and turntable motor okay. No power to light or turntable. Any ideas?
Your description seems to be confusing turntable and light do not work
Bulb and motor OK
Which is it?
They could be separate incidents. The drive motor could be fused and the globe just blew its life away..
Aug 15, 2009 | Microwave Ovens
Feb 10, 2009 | Microwave Ovens
Microwave -- Panasonic NN-S543BFR
I would say either the high voltage transformer or a component on the inverter board has failed.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
Aug 04, 2008 | Microwave Ovens
Open Questions:
Panasonic NN-S961 Microwave Oven Logo
460 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
