Back to:
Tags:
Radio Shack Pro-95 Handheld Scanner
Pro-95 dual trunktracking handheld scanner (by 2 users)
posted by memere on Aug 01, 2007
I had my scanner programmed at Radio Shack(that is where this police/fire scanner comes from) and it has this annoying beeping sound when a frequency comes in. It also has this hissing sound.
I had this problem couple years ago and some at a Radio Shack knew what to do and corrected it. Now I went to several Radio Shack and nobody know how to operate a scanner.
It has to be something minor, but I've been trying and cannot solve the problem without locking out my primary city fire/police frequencies. It is mainly only on that channel that this beeping comes in during a transmission.
Could you please help.
Gloria
Manchester, NH
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Sep 12, 2008
same end of tranmission anoyying beeps
Solution #1
posted on Jan 04, 2008
Not Rated (0)
sir fixalot
Rank:Guru Guru
Rating: 91%, 137 votes
Here is the online programming tutorial:
http://support.radioshack.com/support_tutorials/communications/200-0523/67345.htm
Here is the full manual Should include Quick guide:
http://support.radioshack.com/manuals/ome20-525.pdf
Here is FREE programming software for the PC:
Includes hardware info. You can buy programming cable at Radio Shack to connect to your PC.
http://www.starrsoft.com/freeware/win95/default.asp
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Pro-95 dual trunktracking handheld scanner:
I don't want to Accept this solution
Can you Help with these Radio Scanners problems?
every time i turn on my scanner it say says wired
Is there someone out there that can help me with a Pro-64...
I program the scanner and when I pressed some button I...
I was given this scanner and have gone thru a few issues....
i have a yupiteru mvt 7000 scanner i have had problems...
Loading problems.
Repair Service
Find Radio Scanner Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
