Question about Casio Exilim Zoom EX-Z80 Digital Camera
Dropped my camera...
Hello, I dropped my camera and it has stopped working, I've tried recharging the battery but it's not that, it just won't turn on at all. Any help?
Thanks, Celia.
There is unfortunatly nothing you can do except from either going to the company to get it repaired or buying a new camera sorry
Posted on Feb 10, 2009
Hello My Canon powershot sx20 not working. I have tried new rechargeable batteries new expensive batteries and new cheap batteries. It has been dropped many times i know.
should you open it, check whether any disconnection with the battery power, there is a small fuse on the battery circuit, check the continuity with a multi meter.
Dec 29, 2015 | Canon Cameras
Stopped Working All Together
Hi, bring to your nearest service center to repair it.
May 18, 2013 | FUJIFILM Instax 210 Film Camera
I haven't turned the camera on for a couple of years. I've tried charging the battery, but I can't get it to power up. Do I need to replace battery or is it something else?
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Nov 06, 2012 | Samsung i85 Digital Camera
I dropped my camera and it won't turn on unless plugged in
Sadly there is nothing FIXYA can do for you here . we all have had accidents that turn out costly
Oct 10, 2017 | Kodak Cameras
I dropped my canon powershot SD 4500 IS and now it won't turn on! It's survived countless other falls just fine, and would turn on immediately then. All times, including this time, have been when...
Really!....you've dropped your camera "countless" other times and now you're concerned because this time, it won't turn on!!! You're not sure what else to do?!!! How about not dropping your camera. How about using the wrist strap. Your dropping luck has run out...your camera does not have nine lives.
Aug 23, 2011 | Canon PowerShot SD4500 IS/IXUS 1000 HS...
I accidentally left my camera on, and the battery died. Later, when I plugged it in to charge, the charger light just binks orange continuously. The camera won't turn on at all, and I can't get the...
I think the battery was already damaged,a rechargeable battery once you use it,it needs to recharge again so that the battery memory will stay longer.use a new one,regards....
Jul 03, 2011 | Samsung SL102 Digital Camera
No power on Canon SD750
Here are some simple things to try first for a camera that won't power on. They won't work for every case, but they're worth a try:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
Jan 22, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
C913 Kodak won't turn on
check the battery where you insert on camera kodak has an error on mine <+> should be where the <-> is and<-> should be where the<+> is
Nov 26, 2008 | Kodak EasyShare C913 Digital Camera
Vivitar viviCam 5286 issues. Help?
My camera did the same. I had the same brand. What I had to do was buy rechargable batteries. Rayovac[spelling] or Energizer as seemed to be the cheapest and the best. Do not use disposable batteries in these cameras if you can inform anyone else. It will do the same after awhile if they have used it, or if you use rechargable ones, dont go back to disposable ones. Just, disposable ones = ** lol
Mar 08, 2008 | Vivitar ViviCam 5386 Digital Camera
Cuts on then back off
Sound like it was dropped and somone lied about it. Mine got dropped and it behaves in a similar fashon...something about a plastic pin that hold the parts of the telephoto lens together.I had a computer wonk guy lok at mine andit is the little pin on the bottom of the lens assembly inside the ring that snaps on and off. Mine would work if you help up on te bottom of the lens but the it stopped again...lotsa luck
Aug 16, 2006 | HP Photosmart M417 Digital Camera
Casio Exilim Zoom EX-Z80 Digital Camera Logo
87 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
