Question about Sony Televison & Video
STR 50115/50115A? may i ask if STR 50115 just the same with STR 50115A?
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    STR 50115 and STR 50115A are almost same but little difference in output wattage only.
See the datasheet
Posted on Jul 29, 2012
  • 36 Answers
Both STRs are almost same and can be utilized as replacement part.
Posted on Feb 10, 2009
Power out rms- 4 o 8 homs?
I can see why you're asking for help on this. It almost seem this unit has been 'disappeared' as far as online information is concerned. Even Sony has nothing on it.
I founs some articles and For Sale posts:
http://toronto.kijiji.ca/c-buy-and-sell-electronics-Sony-STR-4800SD-Stereo-Receiver-135-OBO-W0QQAdIdZ243602516
"Sony's STR-4800SD receiver was extensively, and positively, reviewed in Stereo magazine's Fall '77 issue. In their introduction, they found the 4800SD bettered its published f.m. sensitivity specs "by a wide margin...it has exceptionally smooth frequency response, very low distortion(especially in the midband), and excellent quieting. No exotic claims are made for the power amp section, either (35 watts/channel,15.4 dBw at 0.2% THD). But our tests indicate much more capability than that, and a distortion of only one-tenth that spec."
The power consumption figure shown in a photo below says "145W", which would be consistent with a 35 watt amplifier.
http://www.oaktreevintage.com/web_photos/Stereo_Receivers/Sony_STR-4800SD_Stereo_Reciever_collage.jpg
Jan 02, 2011 | Sony str-4800sd stereo receiver with...
Create a program that asks for a sentence. Your program will then check if the sentence is a palindrome or not.
Palindrome using C#.net
using System;
using System.Collections.Generic;
using System.Text;
namespace ConsoleApplication1
class Program
static void Main(string[] args)
string str=string .Empty ;
Console.WriteLine("Enter a String");
string s = Console.ReadLine();
int i = s.Length;
//we can get the Length of string by using Length Property
for (int j=i -1; j >= 0; j--)
str = str + s[j ];
if (str == s)
Console.WriteLine(s + " is palindrome");
else
Console.WriteLine(s + " is not a palindeome");
Console.WriteLine(str);
Console.Read();
Nov 30, 2010 | Computers & Internet
Have a sony trinitron tv which turns off automatically and sporadically on average every 15 minutes
Hello
Most of the sony Tv power supplys are based on STR type regulators. Regulation of an STR is very accurate and if any overload inside the ciruit board of the TV, will be sensed by the STR and will shut off all the supply to the system itself. From your complaint we understands that there is some sort of short, not a direct short, is in your tv. Usually it may related to horizontal output transistor. At first it will work fine, but as time pass on, it will get over heated, passes more current, and place a short like circustance to the power supply rail itself, and as described above, STR will sense it and will shut down the system. After some time, say after 10 or 15 minutes, after the heat generated has gone off, the TV will again switch on, and the cycle will be repeated. You just call a technican and keep this in mind, and ask him to repair the same.
Oct 18, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony STr-DB790 problem
please check your speakers cable for internal short circuit-disconnect all speaker cables and test if everything is fine continue to connect speakers one by one until you find the bad one when you find it change its cable first and test then the speaker itself.if the problem still after disconnection ask for help from good service center.
Jul 19, 2008 | Sony STR-DB790 Receiver
HDMI Input not recognized
With the power on, load a DVD and wait until it starts playing the movie. Press "Voutput" button - HDMI output (480, 720, 1080) will light upt and you should have video.
Dec 27, 2007 | Toshiba D-R5 DVD Recorder
WIN VISTA Ultimate does support Philips SAA7130 TV Tuner/FM Radio/Video...
I couldn't get to work in Vista. So I tried in linux and My SAA7130 is working great in Ubuntu linux. bye vista.
Dec 26, 2007 | Philips TV Tuner Video Capture PCI Card -...
About flash 8
Here is the small sample code. This will convert the lower case letter to upper case letter from left to right character by character.
TextField.prototype.caseAnimation = function(str) {
    var tf = this;
    tf.upperIx = 0;
    tf.str = str;
    var id = setInterval(moveUppercaseLetter, 100);
    function moveUppercaseLetter() {
        var str1 = tf.str.slice(0, tf.upperIx);
        var str2 = tf.str.charAt(tf.upperIx).toUpperCase();
        var str3 = tf.str.slice(tf.upperIx+1, tf.str.length);
        tf.str = str1+str2+str3;
        tf.text = tf.str;
        tf.str = tf.str.toLowerCase();
        tf.upperIx++;
        if (tf.upperIx>tf.str.length-1) {
            tf.upperIx = 0;
this.createTextField("animated_txt", 1000, 0, 0, 500, 25);
animated_txt.setNewTextFormat(new TextFormat("_typewriter", 16));
animated_txt.caseAnimation("pack my box with five dozen liquor jugs");
Oct 18, 2007 | Macromedia Flash MX
Str reg.
No need to take the front screen out. The power deflection board is messing up with that red light.
Nic
Aug 19, 2007 | Toshiba 65H81 65" Rear Projection...
Televison & Video Logo
256 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
