Question about Canon BJ-W9000 Copier
Canon BJ-W9000 Error code
Hi
I don't have a user manual for the Cannon BJ-W9000 large format printer and I have an error code that i can't seem to shift (B800A) - can anyone tell me what this code means and if possible how to resolve it?
Thanks
    Problem Solver:
Hi Dan,
I have a user manual at home, sorry I am at work at the moment.
I am not sure if it has your code in there but I will have a look, if so I will get back to you.
Sorry this does not fix your problem straight away.
I have a problem that you may be able to help me with?
My fiery controller has crashed!
I need a copy of the disc for the controller, it a Image Pass-W20 print controller, I believe this is the standard print controller sold for this model.
I run PC computers with XP but i think the controller run NT, so i am not sure how they manage to talk to one another?
Any help would be appreciated.
Thanks
Steve
info@thecopyshopuk.co.uk
Posted on Apr 09, 2009
    Problem Solver:
Why not download a manuel, I did, it's a free download
Posted on Aug 29, 2009
2 Suggested Answers
SOURCE: Canon BJ - W9000 Error code: B800A
The BJW 9000 manuel is available as a free download I have downloaded it my self but dont have it at home why not do the same
Tony (withtrader)
best of luck
Posted on Jul 14, 2009
When making On, the printer displays a message W7100
this error code, stand for print head trouble.
You can try following:
1. Visual inspection:
Press down the BJ print head set locking lever to set it in a proper position if the
lever is pulled up.
Install the BJ print head if it is not installed.
2. Carriage unit
Visually check and replace faulty BJ print head set components or BJ print head
locking lever.
3. Replace the head controller.
4. Replace the system controller.
Hope that helps!
May 30, 2011 | Canon BJ-W9000 Copier
Have been looking for a BJ-W9000 user manual for several days now and STILL cant get any help!!
I have the bjw 9000 manuel on my desk top
email me at anthonyaorr@yahoo.com and i will send you a copy
Tony
Oct 16, 2010 | Canon BJ-W9000 Copier
How do I reset the language to english? It is a Canon W20 BJ-W9000
Eat some magic mushrooms and the language suddenly becomes clear, understandable
Sep 28, 2010 | Canon BJ-W9000 Copier
Hi I don't have a user manual for the Cannon BJ-W9000 large format printer and I have an error code that e2102
Print-position sensor calibration warning
Error occurred when calibrating the print-position sensor before the paper-width
detection sequence.
cHECK SENSOR
Jun 23, 2010 | Canon BJ-W9000 Copier
Cannon mp150 printer error
sorry, i don`t actually know but i think you should just use genuine catridges
May 16, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Tony (withtrader)
best of luck
Feb 10, 2009 | Canon BJ-W9000 Copier
Reset ink level meter after refilling bj-w9000
At this stage we have found 2 ways that might work but not guaranteed to work with all machines.
Method #1
  1. POWER off printer
  2. Hold RESUME button then press and hold POWER, the beeper will sound once
  3. Hold POWER and release RESUME
  4. Press RESUME twice
  5. Release POWER button
  6. When the indicator light is steady press RESUME three (3) times. Indicator light should be orange
  7. Press POWER to set data
Oct 01, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon BJ-30 Bubble jet printer F-12 error
Hi, According to my BJ-30 & BJC-70 user manual, if F12 is blinking, it is required for this Error code to get in touch with a Canon Service Centre. I had this in the past and being curious I removed the printer chassis from case the and found the problem to be a loose ribbon cable in the connector on the main board from the touch pad circut board . I also had the identical problem with my BJC-70. These printers are very reliable and compact, it seems to be a problem which I think comes about from these printers being so portable. It took me about 15 minutes to fix the problem for which I have made a small modification to hold the cable in place. Having said this, it may not necessarly be your problem but it is a starting point. Canon to my mind have not made another portable printer this good, so if you value it and can find a trustworthy technician get it fixed. If you want further info contact me here.
Regards Roger D
Jul 29, 2008 | Canon BJ 30 InkJet Printer
ERROR MESSAGE FOR CANON BJ-W9000
Hi Caroline here is the problem defonition
E7260
: Nozzle check sensor unit error
E7270 to E727b/W7280/E7281/E7290/ E7291
:Nozzle check error
<Cause>
The position of the nozzle check sensor unit was faulty.
An abnormal condition occurred in the nozzle check sequence.
An abnormal vibration in the printer, the BJ print head is abnormal or no ink was
delivered to the BJ print head.
<Probable faulty component>
BJ print head, nozzle check sensor ***'y, linear scale, encoder sensor unit, carriage
controller, head controller, system controller.
<Action>
1. Check the ink filling status:
Execute "Fill Ink" from the Service Mode when there is no ink in the ink tube of
the carriage caterpillar component. Execute cleaning when the carriage air buffer
is filled but the ink tube of the BJ print head locking lever is empty.
2. BJ print head:
Replace the BJ print head if the above procedure does not solve the problem.
3. Nozzle check sensor check:
Re-install the nozzle check sensor holder unit if the installation condition is
incorrect.
If the installation condition is correct, select "Nozzle Check Position" from the
Service Mode, turn the power off and on, and obtain the updated and appropriate
nozzle check position.
4. Replace the nozzle check sensor ***'y.
5. Check the linear scale:
Visually check the linear scale for abnormal conditions, such as stains or damage.
6. Replace the carriage controller.
7. Replace the head controller.
8. Replace the system controller.
9. Replace the carriage unit.
I hope this helps
If not please get back to me
Thank You
Jun 13, 2008 | Canon BJ-W9000 Copier
Canon BJ-W9000 Copier Logo
306 people viewed this question
old marine
old marine
