Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
Replacing ink cartridge
How do I get the ink cartridge tray to stop in place to allow me to change the cartridge? It keeps tucking away under the right han side.
  • 1 more comment
  • Anonymous Feb 15, 2009
    printer 4450
  • Anonymous Apr 17, 2009
    the ink light is on on the printer, I go through the steps printed on the machine to replace the ink but the printer will not move the ink cartridges to the place where I cange them. it just moves quicly back and forth or does not move at all.
  • Stephen Siasico May 11, 2010
    what model name is this?
  • 154 Answers
Hi, it sounds like it's not ready for a replacement cartridge yet, the printer is only LOW on ink not OUT of ink. continue to use the printer until the flashing red light remains on solidly, then the head will move to the replace cartridge position when you press the button.
Posted on Feb 12, 2009
  • 31 Answers
GET YOUR SOLUTION FROM EPSON
HERE IS YOUR SOLUTION
http://www.epson.com/printer/prob676ijt65/solution
a11
Posted on May 22, 2009
You need to press and hold down the ink button this will then allow the tray to stop just pass the desired locoation ,you then manually move the trat to the desired position
Posted on Mar 27, 2009
Change ink cartridge
tell it your changing cartridge
Jul 08, 2015 | Office Equipment & Supplies
How to change ink in HP Deskjet F480 printer???
  • Check the ink levels by opening the HP Solution Center. Click on "Settings." Click on "Toolbox." Click on "Services." Click on "Service this device." Click on "Estimated Ink Levels." A graphic will appear showing the estimated ink level in each cartridge.
  • 2 Verify that the unit is on. Open the print cartridge door allowing the print carriage to move to the far right side of the unit. Once the print carriage has stopped, lightly press down on a print cartridge to release it. Pull the print cartridge toward you out of its slot. To replace the tri-color print cartridge, remove the print cartridge from the slot on the left. To replace the black or photo print cartridge, remove the print cartridge from the slot on the right. Place the cartridge in a plastic bag as it may still contain some residual ink and may leak.
  • 3 Remove the new print cartridge from its packaging. Remove the plastic tape by using the pull tab, being careful to not touch the copper-colored contacts or the ink nozzles under tape.
  • 4 Slide the new print cartridge forward into the empty slot. Gently push the upper part of the print cartridge until it clicks into place. The tri-color print cartridge fits into the left slot. The black or photo print cartridge fits into the right slot.
  • 5 Close the print cartridge door. If the print cartridge alignment sheet prints, load it on the left front corner of the scanner glass with the top of the page to the left. Verify that there is plain paper loaded in the input tray, and then press the "Scan" button to align the printer.
  • Read more: How to Replace an Ink Cartridge in an HP Deskjet F340 ' eHow.com http://www.ehow.com/how_2303716_replace-ink-cartridge-hp-deskjet.html#ixzz16MAooFTf
    Nov 26, 2010 | HP DeskJet F380 All-In-One Printer
    How to chang ink
    When it is time to replace an ink cartridge in your HP inkjet printer, you will receive a pop up message on your computer screen. Replacing an ink cartridge is just part of owning an inkjet printer, and a tradeoff with the high quality imaging you are able to achieve on an HP inkjet. It is not something a professional needs to do; just follow these simple instructions to complete the change and get right back to printing.
    1. Allow your inkjet printer to run entirely out of ink. Unless the quality of your images is suffering, there is no problem with letting your ink run low.
    2. Open the printer door. It should fold from the top down toward the tray. When it is open, it should expose the inner workings of the printer.
    3. Press the change cartridge button. It is at the top of the printer next to the power button.
    4. Pull on the green top of the inkjet ink cartridge and remove it up and out of its holder. Do this gently so the printer is not damaged in the process.
    5. Recycle the empty inkjet cartridge or have it refilled at an ink refilling center.
    6. Carefully remove the tape from the refilled or new inkjet ink cartridge and insert the cartridge in the same orientation as the one you removed.
    7. Push on the green top until the cartridge snaps into place, press the cartridge change button and close the printer door.
    Good luck.
    Apr 26, 2010 | HP PSC 1315 All-In-One InkJet Printer
    My printer is working fine, but a message that the ink receptacle is full keeps popping up. Where is it and how do I change it? Or do I have to get a techie in to do it?
    basically it is a tray placed inside the printer at the parking place of cartridge. it is for printer cartridge self mantinance purpuse,whenever printer cleans the cartridge head it throws some ink to that tray. open the printer and remove the foam type material place in the tray and wash it with water and dry it and then again place it back. and close the printer. its done.
    dont forget to vote.
    Oct 27, 2009 | Canon BubbleJet i70 InkJet Photo Printer
    Cannot tell which inkjet color cartridge needs changing
    Disregard the monitor information and rely on the printer.
    On the left panel of the printer are your indicator lights and buttons. Push the button immediately to the left of the 'ink drop' light [looks like a little tear drop]. Open the cover and the printhead assembly will move to the left and stop. Look very closely and find that little 'ink drop' imprinted into the plastic in the very middle of the printer where the printhead assembly stopped. That 'ink drop' will line up wih the ink cartridge that needs replacing. Push that button on the left again and the printhead assembly will either return to the 'replace' position, or move to the next ink cartridge that needs replacing. Keep pushing that button just once at a time until the printhead assembly identifies all cartridges that need replacing and moves into the 'replace' position. This 'replace' position will be on the right side of the printer where the opening occurs that allows the top cover of the printhead assembly to open.
    Change the appropriate cartridges and you should be good to go.
    Mar 18, 2009 | Epson Stylus CX4800 All-In-One InkJet...
    Change printer ink
    Turn on the printer.
    lower th epirnter's output tray, pull out the extension, and open the cover.
    press and release the ink button.
    if your ink lights is on or flashing, the printer head moves to the left, and the cartridge that need to be replaced stops under the ink out mark.
    open the cartridge cover
    Pinch the back tab of the empty cartridge as your left it out of the printer.
    shake the ink cartridge 4 to 5 times while it is still in the package.
    unwarp the new ink cartridge and lower it into the holder. Push down gently until the cartridge is firmly seated.
    repeal the procedure if more than one ink cartridge is out.
    close the cartridge cover.
    close the printer cover and press the ink button.
    The green power light flashes and the printer makes noise. charge takes about a minutes. When it's finished, the green power light stops flashing and stay on, and the red ink light should go out.
    Oct 10, 2008 | Epson Stylus C66 Photo InkJet Printer
    Replacing black inkjet cartridge
    are you trying to change the cartridges while the printer power is in the ON position? If not, plug the printer in and open the cartridge cover and the bottom bar should move down and then open the top cover over each ink cartridge and pull the ink cartridge toward you.
    Good luck
    Aug 02, 2008 | HP Officejet 7210 All-In-One InkJet...
    Changing the ink cartridge in Epson Stylus CX4200
    1. Make sure the unit is turned on, and not printing. The POWER light should be on, but not flashing.
    2. Lower the OUTPUT tray, and lift the scanner portion to access the ink cartridges.
    3. Press and release the INK button. The print heads will move to the left, and the cartridge that needs to be replaced will stop directly beneath the OUT OF INK symbol. Make a note of which cartridge requires replacement.
    4. Press and release the INK button again. If more than one ink cartridge is empty, the next cartridge will move under the OUT OF INK symbol. If no other cartridges are out of ink, the print heads will now move to the REPLACEMENT POSITION.
    5. Open the CARTRIDGE COVER. Pinch the front and back tabs of the empty cartridge as you lift it out of the unit. Dispose of this cartridge.
    6. Before you remove the new cartridge from its package, shake it four or five times.
    7. Remove the new cartridge from its package, and lower it into the cartridge holder. Push down gently until the cartridge clicks into place.
    8. Repeat steps 5-7 for each cartridge that you need to replace. Close the CARTRIDGE COVER once all of the necessary ink cartridges are replaced.
    9. Carefully lower the scanner, until it clicks into place
    10. Press and release the INK button.
    The ON light flashes and the printer makes noise. Charging takes about 30 seconds. When it's finished, the ON light stops flashing and stays on steady.
    Caution: Never turn off the EPSON Stylus printer while the ON light is flashing, unless the Stylus printer hasn't moved or made noise for more than 5 minutes.
    May 15, 2008 | Epson Stylus CX4200 All-In-One InkJet...
    HP C3180 all in one printer won't realign
    We've encountered several problem like this. Hope this gives an idea; I understand the cartridge will not moved back to park tray or flash ink tray back and forth because the return pick-up guide were not properly placed into each original position. It will block the ink tray moving back and forth. You can roll back the roller into the original place by removing the back cover if it has, then turn the pick-up roller slowly allowing the roller to turn and backed to its original position. Removed also remains of jammed paper pieces.
    Best regards,
    Rosener Guyano
    Nov 29, 2007 | HP Photosmart C3180 All-In-One InkJet...
    The printer must be powered ON before you lift the scanning unit.
    The cartridge holder will move to the left after you lift the scanner. Pull the scanning unit support down to hold it in place. Now you can replace the old cartridge.
    Nov 19, 2007 | Canon PIXMA MP170 All-In-One InkJet...
    Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
    204 people viewed this question
    Top Epson Office Equipment & Supplies Experts
    Alun Cox
    Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
