Question about Intel Motherboard
Pentium 2 motherboard 10 common problems
I need to know what are the common problems of p2 motherboard 64MB RAM 433MHz CPU and if i can install windows XP on it?
  • cristchelle Feb 10, 2009
    thanks!! am, can u help me know the 10 common problems of pentium 2 motherboard with 64 MB RAM and 433 MHz CPU?
  • 1,179 Answers
Windows XP requires at least a pentium III cpu to run. Sorry.
Posted on Feb 10, 2009
  • Roy Lonsinger
    Roy Lonsinger Feb 10, 2009
    I can't help you there. I stopped repairing Pentium 2 machines after the P4 dual core came out a few years ago. You could try Google to see if anyone still has tech info on them.
The comp is experiencing booting problems
Open the back cover of cpu cabinet. Then reconnect RAM memory and both connection to harddrive . Pull cmos cell from motherboard for 10 minutes then put it back reconnect all connection to motherboard and ATX connector, make sure RAM is working fine and harddrive recognized in bios . Make sure motherboard doesnot ground with cabinet. Reconnect pci card if any. Let me know if you need further assistance. Thanks for using FixYa.
Sep 22, 2011 | Intel Compaq Deskpro EN Pentium 3 1Ghz /...
It is common for most motherboards to beep to let you know
that something is not right: for example, missing/incompatible
RAM modules (or RAM modules not properly installed) or
missing Graphic Card or CPU improperly installed or overheating
beyond specs...If it's a new motherboard, lay it out outside the
case, installed with the minimum one RAM module, a Graphic Card
(if no built-in Video), the keyboard and mouse. Plug in the power
supply and CPU power coonectors and make sure you can post it
without any error. If there are, check your CPU and its socket, check
for thermal grease. Check for properply installed RAM module. Check
for Graphic Card if any. Of course, assuming that all your components
are compatible with your motherboard (consult user's manual or
manufacturer's website)
Jul 12, 2011 | Intel Motherboard, G33, Core 2 Quad, MATX,...
Hi, I need standard spec info of VGA built on Asus P5GC-MX 1333 whether 64 Mb or 128 Mb. Many thanks & regards, Richard
you can use up to a maximum of 224 mb of your computer's RAM for the onboard video chip to use. You can install a video card with any amount of memory (which would give you a lot better video performance).
Jun 18, 2011 | ASUS P5GC-MX 1333 BULK C2D LGA775 945GC...
Cpu speed for ddr 400 ram
cpu speed has nothing to do with ram. they are completely independant. ram speed is important to the FSB (front serial bus) this is the speed at which your motherboard communicates with the devives attached to it. cpu speed refers to how fast a cpu can process info. or how fast it "thinks". most motherboards have the capability of upgrading cpu's. your mobo (motherboard will support the following cpu's:
any pentium 4 up to 3.0 ghz
it supports the following ram
ddr (nott ddr 2 or 3) up to 2 gigs (1 gig each slot) of 533mhz speed (or less)
it also supports up to 2 gigs of sdram either pc133 or pc100
you are using 400 speed ram as you stated i would upgrade to a 533 speed ram as it will be faster, but this is not necessary. as for the cpu just get any P4 (pentium 4) that is 3.0 ghz or less and it will work.
Jun 27, 2010 | ASUS P4S533-MX Motherboard
Computer Information Manufacturer: JETWAY Model: System Information Chipset: Intel 945G/GZ/P/PL Express Memory Controller Hub PCI standard host CPU bridge Motherboard: LakePort CPU: Intel(R)...
U may always refer to it motherboard to get to know the supported hardware that plug to it. Since u are mention about Intel 945G/GZ/P/PL family motherboard, each type of the motherboard (type G, GZ, P, PL) have their own specification, but the same thing is their are design to support Intel Core 2 Duo. Pentium D or Pentium 4 processor. And all can support DDR2 memory. Here you can refer to the manual of the motherboard for more details e.g. pg17 (availability 2009Nov16):
YBC (/)
Nov 14, 2009 | Intel Computers & Internet
I have dell pentium 3.ram is 256 and i want to install 1 gb ram does it work in my cpu.
cpu does not choose the RAM , its the motherboard that you should look into.  if you can give us the exact model of your dell pc, or better yet the Exact model of your motherboard, we can easily tell you if its supported... usually Pentium 3 computers use SDRAM modules
Feb 02, 2009 | Dell Pentium 3, 650 MHz (67EXF)
My motherboard wont work on Pentium processor.
change cpu suply capastors with new one's and check jumper setting
Nov 25, 2008 | Computers & Internet
Problema con cpu
Su placa madre apoyará los procesadores siguientes:
(Your motherboard will support the following processors:)
Pentium III 450~500MHz
Pentium II 233~450MHz
Celeron 266~433MHz
Buenos Dias
Oct 22, 2008 | Pc Ware M748LMRT Motherboard
Hi 1. Does anyone know
hi Have a nice day!
1. Memory
Max. 2GB DDR
2 x DDR slots, DDR333/266
2. CPU Socket 478, Intel Pentium 4( Northwood/Prescott )/Celeron
FSB 533/400 MHz
If you need any other info youre welcome.
Mar 19, 2008 | Computers & Internet
Intel ASUS P4 845 GL Motherboard
Hi, For an ASUS P4BGL-VM Intel 845GL Chipset Ultra ATA100 MATX CPU Type: Intel Pentium 4 478-Pin (OEM), the Asus site specifies max of 2 x 184-pin DIMM Sockets support max. 2GB PC2100 / PC1600 non-ECC DDR or SDRAM memory but not "and". Personally, I find it more practical to install 2 X 1Gb rather than a single 2Gb. Hope this gives you some idea. Kind regards.
Aug 07, 2007 | Intel ASUS P4BGL-VM 845GL Chipset Ultra...
Intel Motherboard Logo
135 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
